Tracking device on gas tank - Bimmerfest - BMW Forums
Old 11-09-2012, 10:25 AM
Laura Diaz Laura Diaz is offline
Mein Auto: 740I
Recently there was a tracking device placed on my car on the gas tank. Is this dangerous to the car?
I have been told there is a plastic covering on the tank and placing something on it is not in any way dangerous, is that true?
Old 11-09-2012, 10:27 AM
Mein Auto: 740I
Tampering Brake Lines
I am falsely being accused of tampering with the break lines of a 740I BMW, is that even possible without lifting the car?
I took 2 years in high school auto shop in 1993, and that is the basis in which I am possibly "capable". I though BMW mechanics when through years of training.
Don't the brakes freeze if tampered with or lights go off?
Old 11-09-2012, 10:40 AM
rrtec's Avatar
rrtec rrtec is offline
Bored Worker
Mein Auto: 540i/6 4/99
Grabs popcorn....
2001 740il Sport- Needs maintenance.. Parts ordered..
2006 Volvo XC90- Kid Hauler
FC3S LS1/6Speed
1992 BMW K75s Cafe build
Old 11-09-2012, 10:59 AM
JasonSC540ia JasonSC540ia is offline
Mein Auto: 1999 740i
Your going to have to elaborate more on your story. Im very curious toknow where this story is going. "Tracking device"? Falsely accused?
To answer your question: No you will not get a DSC light if you just pull the brake lines off or on. You will get the light if a wheel speed sensor is bad or abs control mod is bad, or brake fluid low. Now if you pulled the brake lines and didnt bleed them when you put them back on, it is possiable that some air made it up to the abs control mod and caused an error. If you had that much air in the system your brake pedal would feel spongy as hell and your car would not brake worth a $hit.
Old 11-09-2012, 11:00 AM
Originally Posted by rrtec View Post
Grabs popcorn....
Me too
Old 11-09-2012, 11:21 AM
Mein Auto: 740I
popcorn continuation
Ok so he's the deal since you guys grabbed popcorn
I placed (or a PI did) a tracking device on a car my ex drives but it was not illegal because the car is under my name too
but he wants to make it "illegal" so he now takes the position that the brakes were tampered with!
he also said that the placement of the device on the gas tank made it dangerous and i put his life in danger
And since I took auto shop in 1987 in high school he says I could have done it.
but i think the car is too low to do anything to brakes unless lifted
he said the brake lines were cracked
OK so put down your popcorn now...
thoughts?
Old 11-09-2012, 12:40 PM
And then......?
Im sure theres a lot more to this story then your letting on.
COME ON! juicy details!
Old 11-09-2012, 12:53 PM
Mein Auto: 740I
details
check your inbox
Old 11-09-2012, 04:29 PM
uter's Avatar
uter uter is offline
E30, 840i, i3 BEV, X5 40e
Mein Auto: M3, 840Ci, 325ic, X5 40e
How can it be illegal to track your own car?
Old 11-09-2012, 04:33 PM
Mein Auto: 740I
its not
Its not - that is why he made up the story that I placed him in danger by having the tracking device on it _ specifically on the gas tank
Old 11-09-2012, 05:44 PM
chrisn7 chrisn7 is offline
Mein Auto: 750iL
There would have to be a fuel source, such as a leaking tank, and an ignition source. E38 tanks can and do leak, but I can't see there being sparks from a tracking device
Old 11-10-2012, 04:32 AM
BMWFatherFigure's Avatar
Old School
This is a hoot. The ex is a no-knowledge knob. Any qualified mechanic will get him laughed out of court. You could have shared the juicy stuff with all of us though..
Current:
E38 Parts Car
Previous:
Old 11-12-2012, 09:40 AM
joyism5's Avatar
joyism5 joyism5 is offline
Mein Auto: '99 740IL, K75RT
There is no pastic covering the tank, it is steel only. How was the tracking device being added to the fuel tank? Depending on how was added, it can pe dangerous or not. If it was added using a magnet device, it's not harmfull at all.
JOY = BMW
