E34 (1989 - 1995)
Old 11-07-2012, 02:35 PM
budshaw budshaw is offline
Mein Auto: 1995 525iT
occasional shudder felt underneath
To all:
I have a '95 525iT E34, M50 with 135K miles on it. 3 or 4 months ago I noticed a slight stutter or shudder coming from under the car near where the drive shaft connects to the engine.(I think) It happens mostly when starting out when the torque is greater but I noticed today that it will also vibrate in neutral when I give it moderate throttle. I thought transmission filter at first but now am thinking u joints. (Not sure of the terminology but I'm referring to the the connector between the motor and drive shaft)
Does this sound familiar to anyone out there and if so what do you recommend?
Thanks in advance to all you afficianados out there. Peace
Bud Shaw
Old 11-07-2012, 03:31 PM
Josh429er Josh429er is offline
Mein Auto: 1989 BMW 535i
Well yes it could be u joints, but there are many other parts between the driveshaft. First off is it manual?
Also be as detail oriented as possible. Does it happen when the cars warm, or cold, or both. Does happen when you turn left or right. Low and high speed. What does it do in reverse.
Every bit will only help us help you.
2003 GMC Sierra SLT 2500HD CC/SB
Old 11-07-2012, 03:38 PM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
Also, if it does it in neutral when stationary and revving the engine (couldn't quite tell from your OP), you can rule out the drivetrain. If that is the case, look at motor and transmission mounts.
If no problem when stationary and in neutral, then look at the drivetrain. You have to inspect the entire drivetrain. Take a close look at the flex disc where the transmission connects to the drive shaft.
Good luck.
Steve
Calypso Red 1992 525i with 170K miles
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 11-07-2012, 03:44 PM
Banned
Mein Auto: car
Please do an undercarriage inspection on the mounts, ideally with a professional, and also check for rust, leaks and suspension bushing damage along the way.
Old 11-07-2012, 05:36 PM
supertech777's Avatar
supertech777 supertech777 is online now
could be a bad " GUIBO "
Old 11-07-2012, 05:43 PM
BMR_LVR's Avatar
Humble E34 lover
Also known as flex disc (cough, cough )
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 11-07-2012, 07:39 PM
yeah your right sorry steve !
Old 11-09-2012, 10:56 AM
More info here
Sorry bout lack of details. Yes it is an automatic (as are all Touring models) and It doesn't seem to matter whether it's warm or cold. It will vibrate at start up and going down the road if I gas it. And it does shudder (although not as badly) when in neutral, not moving, and moderately revving the engine. You're right, it shouldn't be the drivetrain if this is the case. How difficult to change out a motor or tranny mount?
Thx.
Old 11-09-2012, 07:52 PM
BMR_LVR's Avatar
Humble E34 lover
Thx.
It's not too difficult, just time consuming. I recently replaced both engine and transmission mounts. Here is a DIY on the engine mounts:
http://www.bmwe34.net/E34main/Mainte...ine/Mounts.htm
The transmission mounts are a lot easier. You can see how to do them easliy enough.
Hope this helps. Good luck.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
