Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Tire Rack's Tires, Wheels, Brakes & Suspension
Discuss everything about wheels, tires, suspension and brakes for your BMW.
Sponsored by The Tirerack. Moderated by Gary@Tirerack.com
Old 11-08-2012, 09:38 PM
z168 z168 is offline
Mein Auto: 01 540i/6
going with 225 from a 235
On a '01 E39 540, with stock tires of 235/45/17 on a 17x8, switched to 18s with 18x8 fronts
will it be a problem to switch to narrower 225/40/18? its less than 4% difference so ABS shouldnt be affected.
Old 11-09-2012, 07:47 AM
Gary@Tirerack's Avatar
Gary@Tirerack Gary@Tirerack is offline
Moderator
Mein Auto: 1995 BMW M3
Be careful with the load rating. Many tires in 225/40R18 do not carry the approx 1350lbs per tire that is the recommended minimum from BMW.
Refer to 'Gary/Bimmerfest' as your previous contact when you order online. Credit Bimmerfest.com by ordering through the sig link.
Gary@Tirerack.com
Old 11-09-2012, 06:32 PM
Perfect person to respond! I was looking at getting it from TireRack.
I was looking at Continental ContiProContact - 225/40/18.
Serv. Desc: 92H
Load Range: XL
UTQG: 500 AA A
My rears are the same but with 265/35/18 thats why i wanted to get ^ Would this be ok?
Old 11-10-2012, 06:11 AM
Moderator
Overall diameters are too far off and could cause issues with ABS and traction control. Stick with 235/40R18 or 245/40R18 when using with 265/35R18.
Tires http://www.tirerack.com/a.jsp?a=AB2&...ires/index.jsp
Gary@Tirerack.com
