E46 (1999 - 2006)
Old 11-09-2012, 02:45 PM
brainblonde brainblonde is offline
Mein Auto: 328i
Oil Leak
I have a 2000 BMW 328i with an oil leak. About how much would that cost to fix?
Old 11-09-2012, 04:51 PM
HarryR325i HarryR325i is offline
Mein Auto: 2002 BMW 325I
Depends where the leak is coming from and how much labor is involved. I had a small oil leak from my valve cover gasket ('02 325i w 110,000 miles) that set me back around $200.
Old 11-10-2012, 06:15 AM
bmw330ci04's Avatar
bmw330ci04 bmw330ci04 is offline
Mein Auto: 04 330Ci 6 Spd, 07 335Cic
Valve cover gaskets do seem to be a popular thing, BMW at one of their free inspection clinics quoted me like 450 for it. Also check the oil filter housing ( I think that's what it's called?) and those to fix are pricey
Old 12-07-2012, 02:20 PM
orightythen orightythen is offline
Mein Auto: BMW 323 - 00
Hey guys! my Bmw 323i - 00 Engine Head Gasket probably broke today, because i got oil in the water or at least Im hoping its just the gasket. My question is can i buy a 1 mm gasket instead of the 0.7mm gasket even if Im not planing on grinding the head? will the 0.3 mm difference change the compression? And has anybody changed the gasket on this engine? Is It hard? and do i need any special tools for it?
Old 12-07-2012, 03:05 PM
Fast Bob's Avatar
Keeping it surreal
Stop hijacking other people`s threads, you have your own....
The road goes ever onward....
(R.I.P. Jever)
Old 12-07-2012, 03:46 PM
MalibuMafiaV's Avatar
TheMalibuMafia
Mein Auto: E60 M5 & JB4+ 335i
Brainblonde can you take a picture of where you think the leak is coming from for us?. We can help you further with a good pic or... if you know where it is leaking from already. usually it's valve cover gasket or oil filter housing gasket.
"Be yourself for who you are, or be no one at all" - MalibuMafiaV
TheMalibuMafia.com
BMW 2006 M5 - REALLY LOUD
BMW 2007 335i. Single Turbo 6266.
Audi S4 2000 Stage 3 - Dat turbo spool - SOLD
BMW 2000 3-series - Supercharged Because race car SOLD
Maserati 2004 M128 GT - HREs/tint/straight piped SOLD
BMW 2006 M3 - stock - SOLD
Old 12-08-2012, 05:05 AM
sdbyrd sdbyrd is offline
Mein Auto: 2001 325i
I took my 2001 325i in (150K miles) after suffering some oil leaks for a while. I previously had the valve gasket replaced, but they showed me the under carriage and described in detail what they would need to do. Basically there's a lot of seals that need replacing and unfortunately requires disassembling a lot of the car. This is a local mechanic that does great work at a cheap price. I believe they quoted $150 in parts & about $500 in labor. If it's all wheel drive or the M3, the price for labor doubled. Not too bad considering my car is still in great shape.
Old 12-08-2012, 08:44 AM
bimcwe bimcwe is offline
XIL
Mein Auto: 2002 325xi
$150 for a new valve cover gasket set and $500 to replace it, $1000 in labor for an xi? The $500 I can see, it's not $150 for a new valve cover gasket set though.. if that's all that's leaking it's about $30 from Max minus shipping. (oembimmerparts.com). $500 in labor... I can see that. $1000 for an xi? That makes no sense since to my knowledge there is no difference Lol. None at all. I have an xi and replaced my VCGs. Was a damn hastle but I would certainly do it for anyone nice enough to give me a solid 1k.
If it was an indy you should have tried to get him (or her) to do more than that though, definitely plugs while he was in there. Shouldn't have costed you anymore imo.
Dreaming of the ///M.
Old 12-08-2012, 11:09 AM
No. Let me clarify...
I previously had the valve gasket cover replaced for around $250 including parts. The next step to stopping my oil leaks are to replace all of the seals in the under carriage and that requires a lot of disassembling. That's where the $500 labor for 2-wheel or $1000 for 4-wheel drive comes in. This place does excellent work and their rate is only $60/hour...half of what the local BMW dealer charges. Plus, they're always fine if I bring my own parts. Usually I don't need to because they don't have a lot of mark up.
Old 12-08-2012, 04:24 PM
XIL
Ah, then more power to you.
Old 12-08-2012, 04:28 PM
BMdude816 BMdude816 is offline
Mein Auto: 2004 BMW 118
Hi mate. It depends where the leak is. Might as well provide us a picture? Is it valve cover gasket? or oil filter housing gasket?
Old 03-25-2013, 12:39 AM
Droopy9 Droopy9 is offline
Send a message via MSN to Droopy9
Mein Auto: 1993 BMW 318i
Hi There,
Can you let me know if they fix the oil leaks in your car and what they find out.
I would like to know because I just bought a 2001 325i.
I can see that the car is been leaking oil from the valve cover (low side). the replacement of the valve cover gasket is knowm but!!!
Also, I can see oil on the side of the engine above and around the engine mounting bracket. So, I am trying to figure out or find a thread about this issue.
thanks,
Old 03-25-2013, 09:32 PM
Mein Auto: '04 330Ci 6-speed
Search more and don't expect much from this dead thread.
What is an engine mounting bracket?
There are only four main kinds of oil leaks. It's not rocket science.
Old 03-26-2013, 05:27 AM
jonathan2263's Avatar
jonathan2263 jonathan2263 is offline
Cogito Ergo Zoom
Mein Auto: 325iT
Valve Cover Gasket and Oil Filter Housing Gasket are the two that come to mind. What are the other two ? I have a small leak that I have to chase down. I know it's not VCG. It seems to be in the area of the OFHG. I also know my Oil Level Sensor is bad. Could that be leaking? I do think its coming from higher than that.
http://www.facebook.com/home.php?sk=...?id=1338939628
"I May Be Going To Hell In A Bucket But At Least I'm Enjoying The Ride"
Old 03-26-2013, 06:20 AM
ahull's Avatar
ahull ahull is offline
Vanos gasket, vanos oil lines, vanos solenoid seals, cam position sensor seal, maybe crank position sensor too. oil pan gasket, oil level sensor, rear main seal (probably front main seal too). CCV hose.
2003 330i TiAg Sport Pkg ~95k miles
DIY MODS: AA Stage I supercharger, Meyle HD FCAs w Powerflex CABs, Bilstein shocks, Meyle HD Rtabs, Angel Eyes, Clear Corners/Markers w/ LEDs, LED tails, ZHP rims, Akebono pads, AUX input
DIY E46 Merit Badges: Sunroof resurrection, CCV, OFHG, VCG w/ VANOS seals, DISA, Cooling Refresh I, steering giubo, window regs, Magnetic Infandibulator (see wiki)
DIY On deck: Rear Diff bushing. UUC SSK, clutch job eventually, Wavetrac LSD
