2005 325i - Clunking Noise
My bimmer has right under 100k miles. I just replaced both control arms, ball joints, and bushings and had my vehicle aligned. Shortly after I am now hearing a clunking noise while driving the vehicle which occurs primarily while braking hard. It also happens while turning. Not a repeated clunk like a CV joint but more of a single "POP!". I know that I still have the factory struts and engine mounts but these items appear to be fine from close inspection. Does anyone have any suggestions on what this may be?
I have already taken the vehicle into the shop that performed the alignment and they said the alignment is fine...when asking them about the noise they suggested it may be the engine mount (but I can't see the engine mount being loose at all). Any input would be greatly appreciated thanks! |
Diff bushing, maybe ?
(R.I.P. Jever) *Please support the Wounded Warrior Project* |
Thanks for the reply! I will check into this next time I get a chance to get under the car. I looked around on youtube and found a couple of examples. It does seem like the noise is coming from closer to the front of the vehicle but anything helps.
Just a thought but make sure your calipers are on tight. Had work done at a shop and a few weeks later the caliper came off while driving. Bolts had backed out.
You could also visually inspect motor mounts while down there and try to pry between mount and sub frame to see if it is a bad MM. |
RSM, Subframe, engine mounts (the rubber dries up and starts to crack), etc
![]() #465420 National Capital Chapter My Progress Thread 2000 323Ci | TiAg | Gray | AFE | UUC | Eisenmann | Koni | ACS Type III | Coby Wheel | 2006 X3 3.0i M-Sport | Silver Grey | Terracotta | Navigation | Premium Pkg | Cold Weather Pkg | AFE | |
Does it ever happen when you go over bumps? Or just braking? More when turning one way or the other?
I have exactly the same problem!!
Guys check your camber bolts. Number 10 in this diagram.
![]() I had forgotten about those. I was tracking my son'e e36 and I would get a single pop when cornering hard. I could feel it through the aluminum race seats and it drove me nuts. We checked everything and tore the rear end apart. In the end it turned out to be the camber bolts had rusted pretty bad and would shift when loaded up. SOunds like that might be what you are experiencing. Easy check and fix. Good luck! |
I had a clunk in the rear when I would shift in lower gears. The part , rear diff bsuhing, wasn't expensive but had to take it to the shop. Ened up being about $500. The bushing was totally shot when they showed me. They also said it was hard to get off so I'm glad I didn't try this one in my carport.
Response to 1972 Ford
The noise happens all the time when braking moderately hard as I keep on letting it go it is beginning to happen more often (like going over bumps etc.). I tried to check it out again and was unsuccessful so I will be taking it in on Monday. Last edited by jblair85; 11-23-2012 at 02:14 PM. |
I need to replace the rear diff bushing as well. It has an occasional pop as well. Shop here in CA quoted the same amount.
Strut mounts maybe? I had similar noises to what you are experiencing, only not in cornering, mainly when hitting bumps.
Just to wrap this one up. I took my vehicle into the shop and they could not find anything broken or worn. They ended up just lifting the vehicle on a floor lift to put weight on the suspension and then they tightened down on the bolts all around where the control arm bushing and ball joints were installed. This was it....no charge either.
