BMW Coding and Programming
Discuss coding options and features on your BMW here. |
#26
Good deal. Thanks.
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickrŪ |
#27
Here it is:
1- Code KOMBI / HUD_PIA_BLINKER = aktiv 2- Code KOMBI / BLINKER_HUD_ENABLE = aktiv 3- Code HU_NBT / HUD_TURNSIGNAL = aktiv The iDrive check box will not show up, but it works. (I couldn't figure out the check box issue)
2013 535i xDrive M-Sport Graphite 2011 X3 35i White 2004 325i Silver Grey 1978 518 |
#28
#29
#30
Paging @marcosg:
Can you check and tell me if your HUD Turnsignals work with just: KOMBI / BLINKER_HUD_ENABLE = aktiv HU_CIC / HUD_TURNSIGNAL = aktiv Or, if you also have to enable: KOMBI / HUD_PIA_BLINKER = aktiv Also, tell me if you have the "Turn indicator" Checkbox in Settings=>Heads-Up Display.
#31
KOMBI / BLINKER_HUD_ENABLE = aktiv HU_CIC / HUD_TURNSIGNAL = aktiv I did not code KOMBI / HUD_PIA_BLINKER. It is currently set to inaktiv Yes, I do have "Turn indicator" Checkbox in Settings=>Heads-Up Display.
2011 BMW F10 528i M Sport Last edited by marcosg; 09-18-2012 at 06:20 AM. |
#32
Ok. Interesting. So, a car with HU_CIC updated with 47.x acts the same as it always has, yet cars with HU_NBT apparently need KOMBI / HUD_PIA_BLINKER also enabled to get HUD turn signals, and for some reason, the "Turn indicator" Checkbox does not show up with HU_CIC / HUD_TURNSIGNAL = aktiv.
#33
I couldn't get my 2013 F10 to work either, but will try it with these new settings and will report back.
#34
Adam |
#35
#36
I set: HU_CIC / 3000 / HUD_TURNSIGNAL to aktiv (Wete=01) KOMBI / 3003 / HUD_BLINKER_ENABLE to aktiv (Werte=01) F30 function is named this, there is no BLINKER_HUD_ENABLE in KOMBI) KOMBI / 3008 / HUD_PIA_BLINKER to aktiv (Werte=01) I get the iDrive turn signal option in the HUD section and I can select it and it's checked, but no HUD signals show up. I also wanted to code the one-touch from 3 blinks to 5, so I also changed: FEM / 3064 / PIA_DEFAULT_TIPPBLINKEN to Mehrfachblinken (Werte=01) FEM / 3060 / BLINKZYKLEN_ANZAHL_TIPP to Werte=04 (value name changes to UNKNOWN) I now get 5 blinks for one-touch, but still no HUD signals. Any ideas? It may be one of those settings that takes a while to "take", so I'll see if it works tomorrow... I-Step is F020-12-07-532 CAFD versions: HU_CIC is 0F9_007_003_007 KOMBI is 9C8_005_000_030 FEM is 794_004_122_077 |
#37
If anyone figures out HUD turn signals for F30 2012, please post. Thanks.
#38
don't you have the same menu structure as the F10/11?
535xd with 20'' Wheel style 434 M in Sophistogrey II Brillant Metallic |
#39
It's almost the same.
HU_CIC / 3000 / HUD_TURNSIGNAL to aktiv (Wete=01) KOMBI / 3003 / HUD_BLINKER_ENABLE to aktiv (Werte=01) F30 function is named this, there is no BLINKER_HUD_ENABLE in KOMBI) KOMBI / 3008 / HUD_PIA_BLINKER to aktiv (Werte=01) I've set all three and get the option in the iDrive HUD list and I can and do select it, but no turn signals show up in the HUD. |
#40
I'm not sure, but a couple posts above, he said he was unable to do it.
#41
![]() 2013 ///M5 Alpine White · Sakhir Orange Full Merino Executive · Driver Assistance · B&O · 20" HRE P40SC · Akrapovic Evolution · H&R Springs · Many Euro Mods |
#42
Did you only change the KOMBI / HUD_PIA_BLINKER = aktiv and nothing else to get yours to work? I have not tried that yet. I've also always set HUD_BLINKER_ENABLE to aktiv too. When I just reset HU_CIC / 3000 / HUD_TURNSIGNAL back to inaktiv (leaving the other 2 changes intact), the check box goes away and no signals in the HUD. I think the HU_CIC change just enables the checkbox on the screen and the KOMBI change(s) actually enable the function. |
#43
#44
This works perfectly well in a 2011 Australian M-spec 520d.... Nice to use as the turn signal sound is quite soft and can be muffled by music.
#45
Has anyone tried this on the f01?
2011 750i |
#46
Coded the signals on my f01;
2011 750i |
#47
shows the hud only both sides together or right/right and left/left ?
in my tested F30 i cant get it work got the Checkbox too but take no effect in hud |
#48
Any luck on this. Have an 2013 F30 checkbox shows up but no blinkers in HUD. Have all 3 settings enabled.
#49
Signals are shown to together.
2011 750i |
#50
I also have all 3 settings activated on my 2012 328i and the check box is operational, just no blinkers in the HUD. |
