Old 11-09-2012, 09:39 AM
invariant's Avatar
invariant invariant is offline
Mein Auto: 2008 335i
Ramps front and rear: silly?
Does anybody use ramps both front and rear instead of jack stands? Is that a silly idea to do so?
My dilemma is to buy a set of 4 jack stands (do I need some kind of adapters to avoid damaging plastic jack points? Or where do you place the stands under an X3?) or buy another set of ramps...
I do realize that jack stands make more sense since I can have wheels off the ground.
2008 E90 335i 6MT + SSK + CDV-delete / ZSP / aluminum / black leather / Conti DW + compact spare / integrated portable nav plus
2005 E83 X3 Auto
Old 11-09-2012, 09:44 AM
jdauria jdauria is offline
Mein Auto: 323Ci & X3 3.0i M-Sport
Jack stands on sale! http://www.harborfreight.com/automot...set-38847.html
Jack pads? http://www.ecstuning.com/ES251251/
#465420 National Capital Chapter
My Progress Thread
2000 323Ci | TiAg | Gray | AFE | UUC | Eisenmann | Koni | ACS Type III | Coby Wheel |
2006 X3 3.0i M-Sport | Silver Grey | Terracotta | Navigation | Premium Pkg | Cold Weather Pkg | AFE |
Old 11-09-2012, 10:28 AM
invariant's Avatar
Thanks! What I meant is where do you place jack stands? Just next to the plastic jack points? I looked, and it's just a flat surface there. I think that it will end up dented...
2005 E83 X3 Auto
Old 11-09-2012, 10:32 AM
http://www.pelicanparts.com/bmw/tech...Jacking_Up.htm
My Progress Thread
Old 11-09-2012, 12:40 PM
Dominic49's Avatar
Dominic49 Dominic49 is offline
Mein Auto: Bmw
I do from time to time depending upon what I am actually working on.
Old 11-09-2012, 12:56 PM
x3brian x3brian is online now
Mein Auto: X3
Personally I use jack stands. I use the front center mounted jack point with my floor jack and then put the jack stands directly under the pads. My jack stands are exactly the the same outside width as the jack pad and when I remove the jack the fit right into the jack stand groves. I do the same for the rear but I use a level on the lower panel to make sure I am level if doing fluid changes.
One of the easier cars I have owned to get up in the air.
Old 11-09-2012, 01:22 PM
mlukas161's Avatar
mlukas161 mlukas161 is online now
Mein Auto: 03 330i, 04 X3
+1 on X3Brians method
Old 11-10-2012, 12:06 PM
raaizin raaizin is offline
Mein Auto: X3, A6, Maxima, Jetta
Originally Posted by jdauria View Post
I just cut a piece of wood to fit in the jack pad. Then used regular jackstands. Worked for me!!!
Old 11-10-2012, 01:10 PM
Supercourse Supercourse is online now
Mein Auto: 2004 X3 2.5i
+1
I followed the lead of BMW and over-engineered it in solid oak with glue and screws.
Works well for using a floor/trolley jack on those lifting points too.
(The underside that is not shown in the pic. is a hollow box shape.)
Old 11-11-2012, 08:54 AM
Wow, that looks great. Mine isn't nearly as sophisticated, but gets the job done!!!
Old 11-11-2012, 10:54 AM
PSUEng PSUEng is offline
Mein Auto: 2007 X3
Here's my setup and my opinion on how to get this car (and others, in general) off the ground safely.
For BMWs, to properly hold them on the jack pads--in other words, completely load the ENTIRE jack pad on the car, these are the stands I have and highly recommend:
http://www.ultimategarage.com/shop/p...4254gltk8o9kf2
I also have the two piece Race Ramps 56" ramps--they never slide, they are easy to store, and you can use them on low vehicles as well (like my M3) and Made in USA:
http://www.raceramps.com/2-piece-56-...ice-ramps.aspx
Lastly, I have the AC hydraulic DK13HLQ jack that I use on the X3, M3 and my Honda--I reach ALL the factory center lift points with ZERO issues.
http://www.pelicanparts.com/bmw/cata...ACHyd1_pg1.htm
Please--if you use any standard jack stands--and I have, as I have two sets of Craftsman 4T stands (very good stands), you are not fully using the load bearing capability of the body side lift supports. Also, you run the risk of having the car slip off the stands.
I use Ramps on front and stands in the rear, but in some cases like tire rotation, I use 4 stands, or if the car needs to be perfectly level for a fluid change, etc.
Old 11-11-2012, 12:07 PM
invariant's Avatar
I ended up buying this kind: http://www.amazon.com/Torin-T43004-A.../dp/B0007XTGCI
2005 E83 X3 Auto
Old 11-11-2012, 01:31 PM
Mein Auto: 2007 X3
Those should work, just be sure the jack pads are straight on in the cradle.
Old 11-11-2012, 02:10 PM
Nice $1000 setup. Too bad I don't have nearly enough money to have that setup
My Progress Thread
Old 11-11-2012, 03:16 PM
Mein Auto: 2007 X3
Yeah it's a bit excessive--but I've had crappy jacks fail and I got tired of buying stuff that may or may not work. I don't need a jack failing, or a car falling off jacks.
Old 11-12-2012, 08:14 AM
mrsanchez3 mrsanchez3 is offline
Mein Auto: '05 X3 3.0i
Has anyone actually used 2 sets of ramps for things like fluid changes? I'd like to do it, but I only have 1 set and don't want to buy a second if it's really difficult to get the car up on 2 sets.
Old 11-12-2012, 02:20 PM
halltristan's Avatar
halltristan halltristan is offline
Bimmer Enthusiast
Mein Auto: 325i and X3
I've been thinking about doing the same thing. The only issue I see is having a couple people help you, one person on each side as you ramp the vehicle.
Member No. 470379
