Old 11-07-2012, 08:27 PM
APe83 APe83 is offline
Mein Auto: 2006 BMW X3 3.0i
X3 slid into curb in snow... Should I be worried?
Hi all. New to the forums here.
I was driving my x3 in the snow tonight and I was turning a corner at about 15 mph. The car slid and hit the curb. I drove it home for about 40 min and didn't hear or feel anything, nor did it look odd, other than the curb rash. Should I be worried? Is it likely that a problem will later problem develop with the wheels from the impact?
Thank you!!
Old 11-08-2012, 04:19 AM
timarnold timarnold is online now
TA
Mein Auto: 2003 bmw 525i
Unless you bent a wheel, which should result in substantial vibration, it is unlikely you did anything to the suspension. The components are pretty beefy and there are rubber bushings at the suspension mounting points except of course the tie rod ends. So if your X3 steers straight without vibration, drive on.
Old 11-08-2012, 04:46 AM
ioannis214 ioannis214 is offline
Mein Auto: X3, 2.0i, Manual, 10/06
Shouldn't be a problem based on speed. However, due to the cars weight, it might be worth having a wheel alignment check, if something went out of place it will show up and you can have it corrected.
Old 11-08-2012, 04:51 AM
TheFinanceGuy's Avatar
TheFinanceGuy TheFinanceGuy is online now
still learnin'
Mein Auto: 1998 328i Hellrot Red
Could be huge problem, you should just give the car to me.
Patrick ///98 328i hellrot///BMWCCA#465139
Old 11-08-2012, 08:41 AM
halltristan's Avatar
Bimmer Enthusiast
Mein Auto: 325i and X3
Thank you!!
This is serious. You're going to need new suspension all around - new struts, springs, possibly even new axles, control arms, etc. You're looking at $5000 at least in repairs. You'll probably need to replace your transmission and engine out too just to be sure that everything is good. Wouldn't hurt to install some training wheel either SO YOU CAN LEARN HOW TO DRIVE.
Member No. 470379
Old 11-08-2012, 09:00 AM
x3brian x3brian is online now
Mein Auto: X3
I would check my tire pressure before driving. If all are above 32 psi you should be fine. The only thing I would suggest is an alignment.
Old 11-08-2012, 09:49 AM
AzNMpower32's Avatar
Tar Heel Faithful
Mein Auto: X3
You need to get the alignment checked. There may be no apparent pulling but there are other factors like toe, camber, etc...angles that could adversely affect tire wear and handling.
Current Ø consumption (X3): Spritmonitor.de (325i) Spritmonitor.de *Click on icon for details.
Old 11-08-2012, 11:30 AM
Dominic49's Avatar
Dominic49 Dominic49 is offline
Mein Auto: Bmw
was the wheel straight or turned at the time?
Old 11-08-2012, 12:09 PM
Mein Auto: X3
Said like Sheldon on Big Bang....
"This is sarcasm right?"
Old 11-08-2012, 12:16 PM
Mein Auto: X3
Old 11-08-2012, 01:48 PM
Wow... some people are incredibly rude on here...
For those who were helpful and answered nicely. Thank you for the advice. The wheel was straight when I hit it. I guess I will go get a wheel alignment check done.
Thanks again!
Old 11-08-2012, 02:30 PM
nightmareuki nightmareuki is offline
Mein Auto: X3
alignment check!!! also get better/winter tires if you curbed your X3 at 15mph
Old 11-08-2012, 02:39 PM
How much does an alignment check typically cost?
Old 11-08-2012, 02:55 PM
Bimmer Enthusiast
An alignment can cost anywhere from $30 to $200. Call around to local auto places and find out for yourself. Us trying to tell you what something should cost in your area would be like trying to guess how many craters are on the moon. And you calling people rude is rude in and of itself. People hit curbs everyday - I am amazed that anyone has given this thread serious consideration.
Member No. 470379
Old 11-08-2012, 04:42 PM
mlukas161's Avatar
mlukas161 mlukas161 is online now
Mein Auto: 03 330i, 04 X3
I pay 180 at the BMW dealer to have my alignment done. It's probably worth having them check the suspension components while they're at it. Good luck. Accidents can happen to anyone.
Old 11-08-2012, 04:45 PM
Mein Auto: X3
but dont go in saying that you hit a curb, just say that you have not done it in a while, if you say you hit curb its gona be a jackpot for them
Old 11-10-2012, 06:39 AM
kisas kisas is offline
Mein Auto: Infiniti
Didn't the xDrive kick in? where was the DCS ? sliding at 15 miles?
Old 11-10-2012, 07:42 AM
Mein Auto: 2004 X3 2.5i
Stability and traction interventions are more pronounced at higher speed.
At 15 mph there was probably much more of a RWD bias than the more normal 40/60.
But tire condition, road camber and other factors might have been a consideration in this instance.
Old 11-10-2012, 08:37 AM
Mein Auto: Infiniti
Sounds reasonable. I was impressed by the youtube videos showing BMW has steady control when making turns on snow field. This is one of the biggest factors that make me inclined to buying a BMW xDrive.
Old 11-10-2012, 08:43 AM
Mein Auto: X3
doesnt matter what car you have if you have **** tires you gona crash.
Old 11-10-2012, 08:54 AM
Mein Auto: Infiniti
wow, make huge difference. But Changing the four tires every year?
(to people in the north) do you actually do this?
Old 11-10-2012, 09:14 AM
Mein Auto: X3
i have a winter set and a summer set, will be putting on winter set soon.
winters are 17" continental winter contact
summers are 19" staggered continental DWS
even if you hit black ice one a year that's the difference between going of the road and a big scare. definitely worth 1.2k and in the long run you're not paying my extra but are MUCH safer
Old 11-10-2012, 10:54 AM
Tar Heel Faithful
Mein Auto: X3
We usually have a seperate set of wheels/tires that we simply swap seasonally. I'm actually considering doing it again this year after a hiatus last winter (which really wasn't a winter in Raleigh). The summer tires I have are pretty greasy below 7°C, all-seasons won't be quite as pronounced but they are still not very effective below that temperature.
Old 11-10-2012, 01:17 PM
Mein Auto: Infiniti
scary!!!
do you put on your winter tires yourself or have a shop do it? Changing tire for a SUV with xDrive should not be easy, right?
Old 11-10-2012, 02:27 PM
Mein Auto: X3
scary!!!
as easy as any other car/suv, there is no difference between xdrive and non xdrive vehicle when it comes to tires/rims etc. 5 lugs and you're done. but i bring it to firestone where i have lifetime alignment and they charge me like 40$ to swap wheels and recheck alignment x2 a year.
accident, curb rash, e83, rims, x3
