E90/E91/E92/E93 (2006 - 2013)
Old 11-09-2012, 03:27 PM
terri_atl terri_atl is offline
Mein Auto: 2011 328i Convertible
Stone chips repair on Black Sapphire Metallic
Hi all, sent my car for a wash today and when it was done, I discovered under the very bright sun a couple of stone chips. Needless to say, I am upset.
So here I am, hoping someone here will give me good suggestions on how I should fix it. I heard stone chips need to be repair to prevent that area from rusting.
All constructive ideas are welcomed and much appreciated. Thank you!
2011 328i Convertible | Black Sapphire Metallic | Black Dakota Leather | Bamboo Anthracite Wood Trim| Sports | Premium | Comfort Access | Heated Seats | Navigation | Harmon Kardon | iPod/USB
Old 11-09-2012, 03:41 PM
Leekay07 Leekay07 is online now
Mein Auto: 08 335Xi, 2013 X1
only stone chips that go beyond the white base coat do you need to fix. Stone chips are going to happen we live on roads made by stones
If you like customer service. Don't look beyond a BMW.
Old 11-09-2012, 04:29 PM
Hi there, I saw 2 white holes. If I don't fix them, won't the damage worsen?
I don't even know how it happens, I may sound scary, other than these 2 stone chips, my car has zero scratches/dents/holes and I have my car for over one and a half year
Old 11-09-2012, 04:41 PM
laser's Avatar
laser laser is offline
Mein Auto: 2007 S2000
Having multiple black cars in the garage I've done a bit of "triage" to the inevitable scrape and stone chip.
If you are wanting to do something yourself that's actually pretty easy.
First realize only you can see the stone chip ..... it's not visible to anyone else from more than 10 feet away.
Second, "do no harm" ..... don't do anything crazy like rattle canning with spray paint!
Google up some Black Sapphire Metallic touch up paint (Amazon or a BMW supplier) and throw away the brush that comes with. Use a toothpick or an artist brush to fill the hole and it will disappear.
Our cars are not going to rust in Atlanta unless you spill a "con sal" margarita on the chip spot!
Laser
___________________________
2011 535i Black Sapphire Metallic, Sport, Euro Del (ret)
2009 328i Black Sapphire Metallic
2007 Honda S2000 Berlina Black
Old 11-09-2012, 05:09 PM
Hello there!! Thank you so much for your input!
I really like the idea of using toothpick or artist brush. I will try to search some Black Sapphire Metallic touch up paint. I suppose not all sapphire metallic are the same? Do you think Global Imports will carry the paint?
People tend to say Atlanta is humid and how about rain? Won't rain if I do not dry the car caused rust? Sorry if I sound very ignorant.
Thank you again for your kind advice
Old 11-09-2012, 05:46 PM
laser's Avatar
I bet Global does carry the touch up paint as BSM is a very popular color.
But really the tiny spot that is chipped won't be large enough display the color flecks embedded in BSM.
Most any black auto paint will do as all you are doing is hiding the white undercoat layer that is showing through.
Your car is not going to rust ...... this is just a little cosmetic touch up!
Laser
Old 11-09-2012, 08:55 PM
pointandgo's Avatar
pointandgo pointandgo is offline
bimmerfest Supporting Member
Mein Auto: '11 E90 328i
I have the same color (last two cars). I swear by Dr. ColorChip...I've used it either professionally applied, or DIY for the last 12 years. All my cars have been black (jet black, or other variations). I'm quite satisfied with the results. As I "tracked" two of my BMWs, rock chips were an unfortunate result on the "nose" and lower "earo" part. The Dr. ColorChip treatment worked for me and it blended it quite well!
Black Sapphire Met., Black Dakota Lthr., PP, Moonroof, convenient electronic "dip stick," Steptronic.
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
MBz W124 300E (slammed)
(unmentionables in between)
'71 AMC Javelin (4-Spd Stick on the floor)
'67 Pontiac Firebird 'cabrio' (1st car - "the leaker")
Member: BMW CCA
Old 11-10-2012, 12:52 PM
Thank you laser for your advice!! I really appreciate it
Have a wonderful weekday!! Hope you are out enjoying the gorgeous weather
Old 11-10-2012, 12:55 PM
Hi there!! Thank you so much! Your recommendation helps alot!
I will go search this brand online. Appreciate your posting here have a terrific weekend!
Old 11-10-2012, 03:39 PM
Tom K. Tom K. is offline
Mein Auto: '07 328iT.'13 Boxster
Although I won't own another black vehicle, I've had good results with Dr. Colorchip on my Platinum Bronze E91.
http://www.drcolorchip.com/
Tom
Old 11-10-2012, 03:54 PM
andrew b's Avatar
andrew b andrew b is offline
flâneur en cabriolet
Mein Auto: 2007 E93 N54
Dr. Colorchip is good, but won't give you a smooth, flat finish (unless you go for multiple coats). langka is another system where you use regular touch up paint, and a special solvent to "level" the paint befire it has cured. Both work well.
You might want to take a look at THIS THREAD on chip repair with touch up paint you can get from the dealer, followed by wet sanding, compounding, and buffing. You can scroll down, I included photos so you can see if the chip is similar to yours, and the kind of results you can expect.
No matter how you go about it, I suggest getting touch up paint matched to your BMW, either with one of the kits or from your dealer. You can find the paint code under your hood, or check online where the kits are sold, many include the code and the name.
Old 11-10-2012, 04:13 PM
Mein Auto: 2007-335 HTC
If you really want to do it right, and since I painted my Triumph TR6 by my self I think I got the plan.... if i were going to repair stone chips and not pay the body shop this is what I would do, clean the area to be touched up, put a tiny amount off filler in the chip, sand with 3000 grit paper, of course waiting the amount of time need per instructions to dry, get my air brush from harbor freight, spot prime, scuff, and spray the area lightly, and multiple coats of touch up paint, let dry and buff it out, you wouldnt know the chip was there, although I know this is probably beyond some. But if you get the materials, practice on cardboard most can do it. otherwise get a bottle of touch up paint and dab it on, wipe it smooth with your finger, let dry and buff it out
Hondo
Old 11-12-2012, 01:22 PM
Tom
Hi Tom! Thank you for posting here. I really love black, I heard there is a type of coating that will protect the paint. But no one offers me that when I first got the car. If let me do it again, I will still get black but get it "sealed" to better protect it.
Will definitely research on Dr. Colorchip. Not sure I am handy enough to do this though
Old 11-12-2012, 01:28 PM
Thank you so much! I will have go check out the thread you have provided. I hope that this is an easy fix, but reading a few of the postings that many have kindly left, I am not sure I have that type of talent.
Will read up about Lanka too. U mean before I use a touch up paint, I should use Lanka to "fill" up the hole?
Briefly looked through the thread, lots of information. Need to find time to digest them. Will try to take a pic of the two chips when there is sun. It's raining outside and looks like this is going to be a cloudy week. Thank you again!
Old 11-12-2012, 01:35 PM
Hondo
Hi there! Thank you for your tips! I am so grateful many have given me great advice here. Currently I am so busy but I need to find time to do some readings and research on the things people suggested here. Guess my main concern is if I am capable of fixing those holes. I am never good in artwork
Old 03-19-2013, 06:21 AM
Hi all, thanks for all your input. Since the last time I posted, my car was "bruised" lightly on the right front with a 2.5" diameter when I drove into a very dark parking lot. I have sent the car to repair and the collision center at the dealership has offered to repair the stone chips at no charge.
Regardless, thank you for posting here
