You KNOW you own an E39 when you...
1. Constantly look at the engine temp gauge...LOL.
2. Check your coolant reservoir at least once a week. 3. Have slight clunk when going over bumps at 2-3 mph (of course I have a Bilstein struts). This thread is designed to be fun, so bring it on haha. |
When you read CN90 DIY to know what will fail next
That only happen when I was still with a Land Rover, no way those things are coming back to haunt me.
96 528i AT w/steptronic. => 97 540i w/ steptronic. |
4. When you find yourself on Bimmerfest everyday to try and head off the next problem before it bites you in the a$$.
When you can read words with missing pixels.
When you can go 80 but it's really 76 When you adjust the headlight but fear a snap sound When you throw away the glove box flashlight When you wipe the windshield and the gasket crumbles When you wonder why it's called a window regulator! |
when you constantly surf the net shopping for the best prices of parts that arent even broke yet.
when you constantly replace parts that arent even broke yet when you have a spare tire in the trunk but no spare tire jack when you cant wait to get to work in the morning because you cant stop for coffee on the way due to lack of functioning cupholders when your better than everyone else when you always have the best looking car in the parking lot, no matter where you park and how much newer or more expensive the other cars are when your afraid to roll down the windows when its cold out for fear of the crunch noise when you constantly pass people, not because you need to or they are going too slow but because you can
ESS Tuning m60 version software m60 intake manifold a.f.e. c.a.i. 3" obx catback full powerflex urethane setup 545 ssk cdv delete m5 rear sway bar M5 chassis rods M5 3.15 lsd Bc-r coilovers w/ swift springs Akebono=suck ss braided brake lines coming soon: Jb lwfw
When you went from an ordinary man to an extrordinary mechanic
When you spend thousands on tools to avoid the dealer When you tell everyone you know how amazing BMW's are and how you would drive across the country in your 180k mile car today (if you did you would be on pins and needles the whole time, and triumphantly rejoice when you actually made it to and from your destination without major incident..) When Traveling without major incident means: smelling coolant each time you put gas in the car, topping it up once, checking the oil and power steering fluid and hearing some ticking that is probably nothing...
1999 540i/6 MSport- Halos, Facelift Tails, Debadge, Maint Done 2010 Mini Cooper S- Bone stock TURBO 1991 Mazda Miata CSP Autocross Beast. too much to list.. 1981 CB750 Cafe Racer |
screw the gauge, i have test 7 up all the time
1999 BMW 540i/6 - Eibach ProKit - E60 SSK - ZHP knob - DJ Autos/FX-Rs/Orion V2s - HID Fogs - M5 front bumper - muffler delete - 19" LM reps ![]() |
Me too. I dont like to beat on it untill its warmed up and the gauge lies and says that it is full temp when its only about 70c. Full temp isnt until 106c
... when you punch it in 3rd gear, and it pins you in the seat, and all the while you're wearing a big grin.
Ed in San Jose '97 540i 6 speed aspensilber over aubergine leather. Build date 3/97. Golden Gate Chapter BMW CCA Nr 62319. |
cn90's first one is spot on, do that ALL the time
Dinan Free Flow Exhaust, M5 illuminated shifter and boot, black kidney grills, tinting on back windows, CCFL Angel Eyes, CDV delete, 15mm spaced (M5 rear sway bar soon) |
when people don't know how to open your doors from the inside
lol "Hey man I think your door is broken"
my wagons faster than yours
When you're happy that you forgot items at the grocery store because it gives you an excuse to go for another drive.
When you some times think about buying insurance from Lloyds of London because you know you'd never get out of it what you've put into, it if it gets hit, from your auto insurance. |
When you go rim shopping, find a set you love, then realize you have the only 74mm hub BMW ever made
![]() RIP Ben "Jever" Doebele, we wont forget you Hi, I'm Chad. Talk to me or GFY ![]() 1997 328iS... HR coilovers, Brembo F40 calipers, camber plates, so many more cool things! 1993 Chevy K3500 CUMMINS 6BT 5 speed with 19.5" commercial grade wheels. Pulling 15k pounds going 75mph up a 7% grade... cake
When you like to "blow the carbon out" every time you drive it.
When the DSC is off more than its on. When you open the hood everytime you pull into the garage to let the heat out so the plastic won't disintegrate. When you park at the far end of the lot to avoid door dings. You open the window a crack when you go thru a tunnel so you can hear that aftermarket muffler. When you turn around to look at your pride and joy as you are walking away from it. When you spend 12 hours working on your friends E39 because yours isn't broken, and you need an excuse to use all of your tools and drink beer with him. EDIT When you carry the following parts in the spare tire well. (haven't had to use them, but you never know when you'll stumble across a broken down E39) A code reader and tools Every hose in the cooling system MAF Cam sensor Crank sensor T-stat Both belts Ignition switch Dual temp sensor Expansion tank and cap And when you go on a long trip you take a few more parts, just in case Water cooled alternator Power steering pump Idler pulleys Water pump
2000 540/6 Slightly tweeked...everywhere Last edited by JimLev; 11-11-2012 at 05:56 PM. Reason: Added more |
ahhhh... YESSS
2003 ///M5. ~ Jet Black/ Le Mans Blue Supersprint Headers, AFE intake, Evolve Alpha N Tune, ST coilovers, Eibach Rear Sway bar, Beast Power Brackets, Drilled slotted Rotors, Akebono Euro pads, Brake Duct's Grill, Magnaflow 14816 Mufflers ![]() _____________________________ |
I just watch "Hitler Rants about the E39 BMW" on YouTube and LMAO.
1. When you plan to do a job but know to buy extra parts for all the other misc. BS plastic that might break; 2. Watch your coolant temp. (test 7) religiously; 3. Spend hours on the forums gathering information before you start a job; 4. When you plan a job with the "while I'm in there mentality"; 5. Start shopping for parts that will go bad before their needed. |
wow, Ive had my car two months, and i do all of these.
at work i park all the at the end of the isle so that i can only have a car parked on one side of me, not both, therefore narrowing the odds of a ding 50% especially the last one. sometimes i feel like if anyone is watching me i either look like im stalking someone as i walk away or im super paranoid because i keep looking over my shoulder.
....HAVE a title and keys to one
l Stock 2000 528i l
I work at the mall and my car is always as far out and alone as possible. And by the time i get to the door i have taken a look back at it atleast 10 times. God I F*ckin Love this car, when im having a bad day and i get in it i forget everything.
You get a sinking feeling every time you see fluid underneath the car, no matter what it is.
When ya see another E39 on the road and think "i wonder if he knows who i am from the forums"
![]() When ya Get into it with other BMWs on the road who think they got the best bimmer ![]() No i got it,! When ya power steering leaks, Windows clunk going up, Headlights point at the groud, cooling hose blows off while , steering wheel shakes while braking, you look at the temp gauge every other 2 days while driving, Everytime you see a M5 ya feel like lil Brother, When ya passenger points out another BMW you tell em to shut up, when ya tell people pull twice when there about to get out the car, when you hear a DING and your heart drops as you look at the cluster display, uhhh yeaaa
#25
When it gives you the impression you've just been working out at the Gym...
Cheers Stuart NZ |
