Old 11-11-2012, 01:23 PM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is offline
Mein Auto: 2011 535i M-Sport
I don't worry about it. As long as I have been coding, 9 months now, I always code my car, and I have coded probably 50 others, all with the car on and the engine fully running (EXCEPT if I am coding the DME module).
I have never had any issue with coding and excess noise, and I do not have to worry about proper voltage being maintained on the car, plus I get the added benefit of active HVAC.
IMHO there is nothing worse than inadequate voltage during coding, and it is a much greater threat than noise introduced by the engine.
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11)
- BMWCCA #446923
- flick
Old 11-11-2012, 01:27 PM
April1 April1 is offline
Mein Auto: X3 2011
If engine is running, it should not be parked in the garage
Old 11-11-2012, 01:30 PM
Err....good point...or in gear.
- BMWCCA #446923
- flick
Old 11-11-2012, 03:37 PM
Keyser Soze's Avatar
Keyser Soze Keyser Soze is offline
just like that, he's gone
Mein Auto: 330i and 535i
I was able to install all the software, connect to the car, make a backup of the existing CAF files, find and modify the module I wanted to, saved, ran the coding and got the confirmation messages. I then disconnected waited a few minutes and locked/unlocked the car but I am not noticing the changes.....are these some of the coding changes that takes 30+ min to resolve? I also verified my new backup files had a module with a later time so it looks like my changes got saved.
EDIT: went for a test drive and they both worked! Auto Stop/Start was off at the first stop sign I reached and the driver door unlocked when I turned the car off. It appears you need to go drive it to notice the changes as it appears the door needs to kick into LOCK by itself at 20mph or whatever for it to auto UNLOCK to kick in. Sweet. Look forward to making more changes.
I suggest any new coders who are having concerns to try these two changes first as they are in the same module and easy to find/modify and also to PRINT out the instructions and take your time, there is a lot of stuff to digest.
CAS
3000 TC
TC_MSA_MEMORY
aktiv / Werte=01
Sets car's Auto Start/Stop function to start in the last used setting (e.g. Off) when the engine is started
CAS
3002 CLM
ER_KEYOUT_AUTOVR
aktiv / Werte=01
Unlocks doors when engine is stopped (start/stop button is pushed). Allows single pull to open doors.
EDIT2: went back in to code the IDrive "disclaimer" off and was able to do so with no problems. Sweet!
HU_CIC (2013 will have HU_NBT instead!)
3001 EXBOX
LEGAL_DISCLAIMER_TIME
kein_ld
2013 F10 535i M-Sport (Picked up 9/14 from Santa Barbara!) (Sophisto Grau, 6-speed MT, M5 Grille/Trunk Lip, more to come)
2002 E46 330i Sport (Jet Black, 5-speed MT, H&R/Koni Sports, Meyle HD Control Arms, Powerflex FCAB's, Hotchkis sways...and more)
2001 E46 330Ci (Sold) : (
Old 11-12-2012, 06:29 AM
bmwlolli bmwlolli is offline
Mein Auto: F11, 530d
psdzdata v47.4/v47.5
Hi, thats my first reply in this forum. I'm looking vor psdzdata-files, version 47.4 or 47.5 (if exists) because my F11 from 4/2011 just got an update at BMW. Can anybody help me with a link to download the file(s)?
Thank you!
Old 11-12-2012, 08:42 AM
Thank you!
I'm sorry, but I can't. RapidShare deleted my account and all my files.
- BMWCCA #446923
- flick
Old 11-12-2012, 10:11 AM
Do you or anybody else have a local copy of the files? Than I could offer you a link to load the files up?
Old 11-12-2012, 10:42 AM
tomeller tomeller is offline
Mein Auto: F30 320d
I would feel safer coding with the engine running as the DRL's come on with the ignition, but I'm not sure what is part of the DME module. Would the auto start/stop be in there?
Old 11-12-2012, 01:18 PM
The 47.5 PSdZData set is 15 GB. PM me with the details of what you are proposing.
- BMWCCA #446923
- flick
Old 11-12-2012, 01:23 PM
There is nothing of interest in the DME (Digital Motor Electronics) ECU for most users. Occasionally, and unsuccessfully, I mess with VMAX etc., looking to remove the Speed Limiter.
- BMWCCA #446923
- flick
Old 11-12-2012, 11:34 PM
webb webb is online now
Mein Auto: korea
Hi there, can somebody please share those files in a torrent or give me a link for the new psdzdata files?
siruu79@gmail.com
cafd_000000f9_007_003_022
Thanks in advance
Old 11-13-2012, 02:27 AM
Mein Auto: F30 320d
Thanks for that, I was considering removing a fuse to turn off the DRL's, now I will try coding with the engine running.
Old 11-14-2012, 05:10 AM
jacky.wf jacky.wf is offline
Mein Auto: F10 5series
Thanks for your share
Old 11-14-2012, 05:20 AM
RegalNC RegalNC is offline
Mein Auto: 2006 X3
Question Remote Vehicle Programming
Can a vehicle be programmed "remotely" ?? Vehicle in one state, programmer in another state.
Old 11-14-2012, 06:52 AM
Telefax Telefax is offline
Mein Auto: 535
What coding option stands for remembering steering wheel heater?
Is it possible to turn on DRL only light switch in Auto position, not in 0?
Old 11-14-2012, 04:07 PM
It can be done remotely via an RDC Client like TeamViewer so long as the person receiving the coding has a working E-Sys Setup and ENET Cable and can connect to the car while still holding an Internet Connection.
- BMWCCA #446923
- flick
Old 11-15-2012, 04:20 AM
Mein Auto: 2006 X3
Thanks for your reply!
Old 11-15-2012, 08:16 PM
csnyder335i csnyder335i is offline
Mein Auto: 335i
Can someone tell me where to download 47.5 PSdZData. Thanks!
Old 11-16-2012, 01:43 AM
Since my RapidShare cancellation and deletion of all my files, someone else will need to step up...
- BMWCCA #446923
- flick
Old 11-16-2012, 01:47 AM
Mein Auto: 535
If someone could give me ftp with normal speed, I can upload 47.7.
There 30 files, each 700mb.
Old 11-16-2012, 10:44 AM
ImpetuousRacer ImpetuousRacer is offline
Mein Auto: 2013 BMW M5
PM sent with FTP Details.
Once received and downloaded I will make a torrent.
Old 11-16-2012, 10:55 AM
wassy's Avatar
wassy wassy is offline
BMW Enthusiast!
Mein Auto: '08 750i
Please pm me with link. Thanks guys!
'13 640i Gran Coupe Alpine White/Cinnamon Brown, M-Sport, Driver Assistance, Lux Seating, Premium Sound, Full LED's
'10 Porsche Panamera S
'09 Maserati Quattroporte S
'08 550i Carbon Black/Natural Brown/Anthracite, Sport Pkg, Active Steering, Comfort access, Sport transmission, rear shades, NAV, Sirius, L7, Ipod/USB, PDC, Heated Front Seats.
'08 750i Sapphire Black/Natural Brown
'06 750i Sapphire Black/Natural Brown
'07 550i Sapphire Black/Black
'05 545i Silver Grey/Black
Old 11-16-2012, 11:12 AM
skymast skymast is offline
Mein Auto: 2012 BMW 535
me too please.
2012 BMW 535 ... Silver / Black, M Sport, Premium, Premium Sound, Technology, Heated Seats, Sport Automatic
Other Cars ... Mercedes S550, Chevrolet Tahoe LTZ, Porsche 996 Turbo
Old 11-16-2012, 03:47 PM
Mein Auto: korea
Hi, Telefax
Can you please PM me the links for 47.7
Thanks,
Mein Auto: korea
Hi, Telefax
Thanks,
siruu79@gmail.com
