Hello everyone, I am new to the blog and have enjoyed what I have read, thanks. I have a 2003 Z4, the car is absolutely fabulous to drive and I love it. On rough asphalt roads my car tends to wander just a bit and I can hear the rear tires address the pavement. My question is, when is it necessary to have the front and rear alignment done?
I have noticed that rough bumpy asphalt roads can cause steering inputs that require attention. But I think this is the nature of the car's direct steering, and not related to alignment. So you have two questions: wandering and alignment. Bump-steering is probably normal. An alignment should be considered if the steering pulls to one side, the front end shimmies or the steering wheel shakes or if the front tires have unusual cupping-type wear. However, I understand the Z's suspension normally causes odd-looking tire wear to the inside. |
Z4's exhibit a phenomenon called "Tramlining". This is the wandering you are seeing. An alignment can alleviate this to some degree, and getting rid of the runflat tires will also reduce the tramlining effects. It will never completely go away. The tramlining is not from the electric steering but due to the wider track the car has.
Getting rid of the Runflats has the biggest positive effect....!!! If you have doubts on the alignment, you should get it redone. A good shop should only charge you about $100.00. Also, if your shop says that they cannot align your BMW, don't just think they are stupid. When you align the car, the 'Steering Angle Sensor' must be reset and that takes some specialized equipment. Not all shops have this.
. How does something immoral, when done privately, become moral when it is done collectively? Furthermore, does legality establish morality? Slavery was legal; apartheid was legal; Stalinist, Nazi, and Maoist purges were legal. Clearly, the fact of legality does not justify these crimes. Legality, alone, cannot be the talisman of more people. Walter E. Williams Drives a 2008 Z4M Coupe' (His) & 2003 Z4 Roadster (Her's) |
