Old 11-10-2012, 07:41 AM
champaign777's Avatar
Mein Auto: 2010 550i M Sport
Originally Posted by EconoBox View Post
Today:
Replaced MAF sensor ($150)
Replaced Hood Emblem ($30)
Replaced Wipers ($35)
Replaced Power Steering Reservoir O-ring ($1.50)
Put on snow tires! ($400 used OEM wheels, $200 used snow tires, $42 mounting)
where did you get Bosch MAF sensor in $150
E39 4 ever
M54 GARAGE SALE
2003 530i 107k miles for SALE
Old 11-10-2012, 10:03 AM
Nline6's Avatar
Nline6 Nline6 is online now
Always best in the NW
Mein Auto: E39 528it & E36 M3 sedan
I just removed my valve cover. I am doing VANOS seals today! Any advice?
Touring the nation, one state at a time
Old 11-10-2012, 01:59 PM
Quest_908 Quest_908 is offline
Quest_908
Mein Auto: 01 530i and 04 aviator
Painted grill white to match the body
Old 11-10-2012, 02:03 PM
PavelK313 PavelK313 is offline
Mein Auto: E39
Vanos piston bolts are left threaded.
Old 11-10-2012, 04:33 PM
Tuskfish Tuskfish is offline
Mein Auto: 2001 530i
Finally replaced the leaky OFH gasket. Not too difficult just a little bit of time. Nice 70° day in November so it was comfy in the garage.
The wife curbed the front bumper pretty good yesterday so I think that Mtech upgrade is soon to come.
Old 11-10-2012, 06:08 PM
sawtooth4x4 sawtooth4x4 is offline
Mein Auto: E39 525 Sport Package
Just stuck the BMw in the garage last night. There is now a 3 foot snow drift in front of the door.
Hopped in the Range Rover and drove around to get stuff I needed in this nasty snow storm.
Sent from my SAMSUNG-SGH-I717 using Bimmer App
Old 11-11-2012, 08:57 AM
FiveDriver FiveDriver is online now
Mein Auto: 1999 528i
I'm still in "Shakedown Cruise" Mode, but after putting on 5K miles since I bought it......I can find nothing that needs urgent attention.
I have to get thru New Jersey Inspection in December which is mainly Emissions Check. The Near Term goal is to clear that hurdle without doing anything Major to fight the Battle of the HydroCarbons.
Beyond that, next Spring I'd like to replace the Rear Shocks and add the Sway Bar. Also thinking about a Window Tint.
Old 11-11-2012, 10:07 AM
POof540i's Avatar
POof540i POof540i is offline
^^^Worst Username Ever!
Mein Auto: '01 540iA
Changed two ruptured hoses and expansion tank over the last 2 months. I've been putting too many miles on my baby lately. I need to buy a beater. I'm thinking a 2012 Civic.
"The more you know, the more you don't know," Dave Chappelle
"Man is an emotional animal, occasionally rational; and through his feelings he can be deceived to his heart's content"-Durant
WTT: Black Comfort Seats for Black Sport Seats. PM for info.
Old 11-11-2012, 11:27 AM
scott740il scott740il is online now
Send a message via AIM to scott740il
Mein Auto: 1999 540iT Wagon
ordered new rear speakers from BSW, and new air and cabin filters. Going to be tackling the oil leak in the next couple of weeks. Its driving me batty.
Old 11-11-2012, 05:26 PM
6spdonly 6spdonly is offline
Mein Auto: 01 540i6
Bought my 540i last month. Going through all the maintenance items since I don't have a complete history on it.
Just got done replacing the following:
- Air filter
- Diff fluid with Mobil 1 75w90
- Trans fluid with RP Synchromax
- Clutch/Brake fluid flush (DOT 4).
- Oil and filter (Mobil 1 0w40, Mann HU938/4X)
Flush of power steering deferred until I verify whether or not one of the hoses has a slow leak.
Coolant not replaced. The cooling system was replaced not more than a year ago based on the date code on the Behr radiator and the condition of the other parts - WP and thermostat housing.
Also, in the process of cleaning/conditioning the leather seats with Zaino Z-9/Z-10.
Old 11-11-2012, 05:32 PM
Steve530 Steve530 is offline
Changed the fuel filter yesterday. Also changed the oil.
Today I replaced the hood roundel and the drivers side seat covering.
Steve
OSRAM CBI
BMWCCA Member #337964
Old 11-24-2012, 09:35 PM
Sumotide17 Sumotide17 is offline
Mein Auto: 2001 540I/6 Sport
Today I replaced the Lower Oil Pan Gasket, the oil level sending unit gasket, and changed the oil with Mobil 1 0w-40 as well as the oil filter. I also replaced my drain plug with a magnetic drain plug.
Old 12-03-2012, 11:14 AM
1BADBM 1BADBM is offline
Mein Auto: 530i
I'll contribute since I've done a considerable amount of work over the last 4 months. In late summer I replaced Bilstien sports that had been on the car for at least 6 years with Koni Yellows and OEM sport springs. I will be re lowering in in the spring with H&Rs.
Last month the car started overheating and found out the Head Gasket was blown. Here's a list of what was done/replaced:
Head gasket
Head set
Exhaust manifold
I needed a set of head bolts
Thermostat
New upper intake boot (old one was torn)
Disa valve
Timing Chain guide (old one was broken)
VANOS line
VANOS seals
Set of water pipes under the intake (cracked and brittle)
Strut mounts
All belts
Valve cover gasket
Oil filter housing gasket
Temperature sensor O-ring
BG brake flush **Noticeable difference in brake feel! Definelty reccommend!!**
Not Including the suspension the work came up to $2200 from my BMW indy.
Car has 170,000 miles and has never run this good since I've owned it. I notice the engine sounds different on start up, anyone else experience this after changing the VANOS seals? I was without the car for a month but the she has LIFE again!
Old 12-03-2012, 11:35 AM
jdt10768 jdt10768 is offline
what did you recover the seat with? interested, thanks
Old 01-07-2013, 01:16 AM
This weekend I rebuild my front calipers as well as replaced my rotors and changed brake pads.
Old 01-07-2013, 07:22 AM
Nline6's Avatar
I installed some new front door speakers. And got new tires,
