Another Dynamic Handling Question - Bimmerfest - BMW Forums
Old 11-09-2012, 01:34 AM
wayner44 wayner44 is offline
Mein Auto: boat
Hey all, questions for someone who has DHP
With the xDrive models does the suspension get stiffer in sport mode or just in sport +
I know one of the main differences is sport+ has limited stability control, but not sure if sport mode actually adjust the dampers like sport+
Old 11-09-2012, 02:58 AM
sean10mm sean10mm is offline
Mein Auto: '13 335i xDrive 6MT ZDH
Suspension gets stiffer in both, both modes are the same except for the difference in traction control.
Old 11-09-2012, 12:37 PM
Mein Auto: boat
Also one more question.
Do Sport lines without the DHP still have the sport+ option?
If I test drove 2 335 xi sport lines back to back one with DHP and one without. Are there any interior options that specify the car is equip with the DHP package?
Old 11-09-2012, 09:13 PM
Mein Auto: boat
anyone? sry I know its an od question, it is just something I am wondering.
Old 11-10-2012, 01:47 AM
windsor027's Avatar
windsor027 windsor027 is offline
Mein Auto: 2015 335i and 2014 X3 35i
I don't know about the 335xi models I do know the sportline 335i models do have the sport+
2015 335i Sportline | Driver assist| HK | NAV | Premium | Heated Front seats |8-Speed Auto.
2014 X3 35i Dynamic Handling Package| Cold Weather Package | NAV | Premium hi-fi system | Driver Assistance Package.
2013 335i Sportline | M-adaptive | HK | NAV | PDC | Heated Front seats |6-speed MT. GONE Great car, zero issues
2011 X5 35d Great SUV gone
Old 11-10-2012, 01:58 AM
Mein Auto: boat
It is my knowledge that if the car has the Dynamic Handling Package then you can adjust the stiffness from the iDrive?
Old 11-10-2012, 05:04 AM
boltjaM3s boltjaM3s is offline
Banned
Mein Auto: BMW M428i
Yes.
The reason is the Adaptive M Suspension which is bundled in the DH Package (and also available separately):
On Sport line, hit a button and get the softer Comfort suspension.
On Luxury line, hit a button and get the firmer Sport suspension.
All the time, the adaptive dampers are sensing road conditions and making micro-adjustments to road feel.
BJ
Old 11-10-2012, 12:28 PM
bmw_or_audi bmw_or_audi is offline
Mein Auto: Passat 1.8T MT
Originally Posted by boltjaM3s View Post
Yes.
BJ
When you "hit the button", does it only affect the suspension, or other things such as steering and throttle response change as well? It would be nice if you could control the suspension independently.
Btwy, are you sure you can have the Adaptive M suspension outside of the DHP? I can't see that as a standalone option on bmwusa, but of course that doesn't mean anything.
I also have yet to read some feedback here about the "Variable sport steering" component of the DHP. Any opinions by owners?
Old 11-10-2012, 02:46 PM
Mein Auto: boat
Yes I also did not know you can order it as a separate option on the F30
Old 11-10-2012, 04:16 PM
jlukja jlukja is offline
Mein Auto: '13 328i
When you are in ECO or Comfort the suspension is in "soft" mode. ECO also provides much softer throttle response, all settings are to optimize fuel economy. SPORT and SPORT+ modes give you suspension in "firm" mode. Throttle response is much sharper, steering is heavier and feels more direct.
I don't believe you can. On my MY2013 I had to order the DHP to get the adaptive M suspension. Didn't really want the variable sport steering but felt the adaptive M suspension was worth the price of the entire DHP.
I really don' t notice it. It doesn't come into play on highway cruising or at higher speeds, only after you turn the wheel by more than 100 degrees (more than quarter turn) does the ratio quicken. Its actually quite handy making tight turns into my garage, in parking lots, or on tight switchbacks.
MY2013 328i, N26 / 300 / 4CG / KCDF / 2DW / 205 / ZDH / 302 / 3DZ / 403 / 494
Old 11-10-2012, 04:44 PM
Mein Auto: boat
A sure way to tell if the car has DHP is to pop the hood and see if there are wires coming from the top of the struts?
Old 11-11-2012, 02:40 PM
Mein Auto: boat
bump
Old 11-11-2012, 06:20 PM
Mein Auto: '13 328i
You can also tell through the iDrive system. When configuring sport setup it will ask you if you want the suspension to adjust when sport is selected. This suspension adjustment option is only there if you have the adjustible M suspension.
Old 11-11-2012, 10:11 PM
Mein Auto: boat
ohh cool thanks
Old 11-12-2012, 03:00 AM
windsor027's Avatar
Very true. Plus if you have it you will feel the car's suspension tighten up considerably from comfort to sport. Its like you jumped in a different car. Now I can't validate this statement, I have test driven just one 335i in the BMW USA event that didn't have DHP and it wasn't a Sport Line model. It was a luxury model. From what I remember I would say the comfort level setting is a tat softer that the regular suspension on that car but in sport mode its almost certainly a bit stiffer than the regular sport suspension in the sport line (I test drove a sport line 335i extensively back in June). But because it still adjust to the type of road you are on it is still very comfortable
Old 11-12-2012, 06:10 AM
tim330i's Avatar
tim330i tim330i is offline
Bimmerfest.com Founder
Mein Auto: Ti Silver 03 M3
The strut actuators are on the side of the strut body and the wiring runs out of the wheel well with the ABS and other sensor wires. I do not believe you could tell from looking at the tops of the strut. If you turn the wheel to full lock you should be able to see the actuator on the rear side of the strut body. It sticks out at 90 degrees and is fairly obvious -
BMW M Adaptive F30 suspension
Tim
Old 11-12-2012, 08:18 AM
tturedraider's Avatar
Freedom isn't free!!
The answer to this question is yes. The other answer is that Sport + does nothing other than decrease the safety of the car for street driving. Sport + disables Traction Control. Nothing more.
www.bmwcca.org
Old 11-12-2012, 08:35 AM
tim330i's Avatar
Because I already wrote this up, this clarifies what options give your F30 sport+ driver experience mode -
http://www.bimmerfest.com/forums/sho...d.php?t=639476
As tturedraider pointed out, sport+ does very little so if your F30 3 series doesn't have it you're not missing much.
Old 11-12-2012, 07:30 PM
Mein Auto: boat
okay guys thanks
