Old 11-04-2012, 10:25 AM
miotoo miotoo is offline
Mein Auto: F10 520d
Also..according to this document, we might need a specific firmware on the device..'By default supported only chinese clone ICOM with corresponding firmware version'
File Type: pdf 3505033-BMW_ISID_for_real_ICOM_configuration_manual.pdf (3.04 MB, 333 views)
F10 520d born 11.04.2011 Deep Sea Blue
205, 230, 322, 403, 415, 423, 428, 430, 431, 459, 464, 465, 494, 502, 508, 522, 524, 534, 548, 609, 614, 615, 620, 644, 654, 676, 698, 851, 879, 962, 1CA, 1CB, 1CD, 2K1, 2PA, 3AG, 4AT, 4UR, 5AC, 6AA, 6AB, 6FL, 6NF, 6NR, 6VC, 8KA, 8TF, 8TL, 8TN, 8V1
Old 11-04-2012, 12:09 PM
MINI+BMWtek MINI+BMWtek is offline
BMW master tech
Mein Auto: e30 318
I can't access my window xp screen(T61 native ISTA) I turn the the computer only ISTA comes on, will your 2.30 ista/d vmware work on native install ISTA?
Old 11-05-2012, 06:09 AM
shawnsheridan's Avatar
Mein Auto: 2011 535i M-Sport
The ICOM firmware version should match the ISPI version of your ISID or ISSS. (i.e. if your ISID/ISSS is version 2.9.x, you should flash the 2.90.x firmware for ICOM). Flashing something like the 3.x ICOM firmware may render the ICOM incompatible with your ISID/ISSS until you either downgrade the ICOM using the restore procedure or upgrade your ISID/ISSS.
ICOM Firmware Restore
ICOM-Firmware-Restore.zip - Contains ICOM_Restore and ICOM A Emergency Software Update
https://www.rapidshare.com/files/258...re-Restore.zip
ICOM Firmware 2.8.x
ICOM-Firmware-2.80.70.zip - Contains ICOM-BootImage-01-09-00 and ICOM-ApplicationImage-01-11-01
https://www.rapidshare.com/files/201...re-2.80.70.zip
ICOM Firmware 2.9.x
ICOM-Firmware-2.90.59.zip - Contains ICOM-BootImage-01-11-01 and ICOM-ApplicationImage-01-15-01
https://www.rapidshare.com/files/212...re-2.90.59.zip
ICOM Firmware 3.0.x
ICOM-Firmware-3.00.43.zip - Contains ICOM-BootImage-01-13-00 and ICOM-ApplicationImage-01-18-00
https://www.rapidshare.com/files/333...re-3.00.43.zip
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11)
- BMWCCA #446923
- flick
Old 11-05-2012, 06:11 AM
The VMWare is it's own ISTA. If you have a native ISTA, you wouldn't use the VMWare version.
- BMWCCA #446923
- flick
Old 11-05-2012, 02:07 PM
clausx3 clausx3 is online now
Mein Auto: X3 20d f25
Hello shawn, first of all thanks for your availability
just one question, do you think it's worth buying a icom A and go to ista or believe enough e-sys to play with my car?
What benefits would I get?
Thanks!!!
Old 11-05-2012, 09:46 PM
Thanks!!!
ISTA/P via ICOM is designed to easily allow you to program the entire car via a Measures Plan, from one Integration Level to another Integration Level, and to Import and Activate FSC Codes.
E-Sys, which can also use ICOM, can do the same, although it is not as straight forward. E-Sys is actually better in that like WinKFP for Exx Chassis, you can target a single ECU to be programmed, where with ISTA/P and its Measures Plan, the whole car must be done.
At the end of the day, I don't think ICOM-A is a must have, however, it is a faster more reliable interface for programming than ENET, and if it is priced reasonably, I'd pick one up if you want to be able to flash ECU's. If you only plan to FDL Code, or occasionaly flash a single ECU with E-Sys, you don't really need it.
- BMWCCA #446923
- flick
Old 11-06-2012, 12:44 PM
Hello shawn,
thanks for your reply, then I'll wait until the price drops again
Old 11-06-2012, 01:31 PM
Hello shawn,
Same here. I think $150 is the sweet spot for me.
- BMWCCA #446923
- flick
Old 11-06-2012, 01:45 PM
I fully agree with you...just a question, in my vmware ista/d 2.30 is missing the f25 wds, is it normal? am I missing somethings?
Thanks!!!
Old 11-06-2012, 02:23 PM
Thanks!!!
Are you selecting X' Series, not 3 Series?
Name:	ISID Model Selection - X Series - F25.png
- BMWCCA #446923
- flick
Old 11-06-2012, 03:16 PM
cn555ic cn555ic is offline
The Coder guy in N.Y
Mein Auto: bmw
Hey Shawn. Can u run Ista-D with the car running or would it have to be just ignition on position?
Old 11-06-2012, 03:31 PM
I have not connected to my car with it, as I have just been using it for documentation. That said, I don't see why the car couldn't be running, same as with E-Sys.
- BMWCCA #446923
- flick
Old 11-07-2012, 08:07 AM
jean019 jean019 is offline
Mein Auto: e90 05/2006
links are dead...
Do you have a recent ISTA/D + ISTA/P VM (english or french) for download ?
Thanks !
Old 11-07-2012, 08:46 AM
April1 April1 is offline
Mein Auto: X3 2011
Running car is a great source of electrical noise. Unless your entire system is well grounded and shielded, it's preferred to be just with ignition switched on.
Old 11-07-2012, 10:48 AM
Mein Auto: F10 520d
We can expect difficulties with future versions..
http://forums.bimmerforums.com/forum...17&postcount=5
Old 11-08-2012, 02:32 PM
Is it possible to consult technical bulletins TSB (bmw SI xx xx xx) in the ISTA/D VM ?
thanks
Old 11-08-2012, 04:14 PM
thanks
Not that I have ever found.
- BMWCCA #446923
- flick
Old 11-09-2012, 05:59 AM
sh.... do you know where we can find them ?
before some TSB where available here but it seems bmw changed the access
thanks
Old 11-09-2012, 11:57 AM
thanks
Sorry, but I have no source for TSB's.
- BMWCCA #446923
- flick
Old 11-12-2012, 05:29 AM
maybe you have some links to icom emulator which is ok with the ista ? I read the threads that week end and it seems to be the graal to find, near impossible !!!
Old 11-12-2012, 05:36 AM
Yes, it is very hard to find. Unfortunately, a few day's ago my RapidShare account was locked and all my content deleted.
- BMWCCA #446923
- flick
Old 11-12-2012, 05:52 AM
Maybe you have a copy of the files ?
if so I'm sure we can find somewhere to upload it ...
Old 11-12-2012, 06:40 AM
mateforrest mateforrest is offline
Mein Auto: BMW F10 530D SILVER
Shawn please,
Where can I found the EBA,s?
Inside Ista D?
Regards
Old 11-12-2012, 07:18 AM
Originally Posted by mateforrest View Post
Shawn please,
Inside Ista D?
Regards
What is EBA?
- BMWCCA #446923
- flick
Old 11-12-2012, 07:31 AM
No ?
