BMW Coding and Programming
Discuss coding options and features on your BMW here. |
#26
Also..according to this document, we might need a specific firmware on the device..'By default supported only chinese clone ICOM with corresponding firmware version'
F10 520d born 11.04.2011 Deep Sea Blue 205, 230, 322, 403, 415, 423, 428, 430, 431, 459, 464, 465, 494, 502, 508, 522, 524, 534, 548, 609, 614, 615, 620, 644, 654, 676, 698, 851, 879, 962, 1CA, 1CB, 1CD, 2K1, 2PA, 3AG, 4AT, 4UR, 5AC, 6AA, 6AB, 6FL, 6NF, 6NR, 6VC, 8KA, 8TF, 8TL, 8TN, 8V1 |
#27
I can't access my window xp screen(T61 native ISTA) I turn the the computer only ISTA comes on, will your 2.30 ista/d vmware work on native install ISTA?
ICOM Firmware Restore ICOM-Firmware-Restore.zip - Contains ICOM_Restore and ICOM A Emergency Software Update https://www.rapidshare.com/files/258...re-Restore.zip ICOM Firmware 2.8.x ICOM-Firmware-2.80.70.zip - Contains ICOM-BootImage-01-09-00 and ICOM-ApplicationImage-01-11-01 https://www.rapidshare.com/files/201...re-2.80.70.zip ICOM Firmware 2.9.x ICOM-Firmware-2.90.59.zip - Contains ICOM-BootImage-01-11-01 and ICOM-ApplicationImage-01-15-01 https://www.rapidshare.com/files/212...re-2.90.59.zip ICOM Firmware 3.0.x ICOM-Firmware-3.00.43.zip - Contains ICOM-BootImage-01-13-00 and ICOM-ApplicationImage-01-18-00 https://www.rapidshare.com/files/333...re-3.00.43.zip
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickr® |
#29
The VMWare is it's own ISTA. If you have a native ISTA, you wouldn't use the VMWare version.
#30
Hello shawn, first of all thanks for your availability
just one question, do you think it's worth buying a icom A and go to ista or believe enough e-sys to play with my car? What benefits would I get? Thanks!!! |
#31
E-Sys, which can also use ICOM, can do the same, although it is not as straight forward. E-Sys is actually better in that like WinKFP for Exx Chassis, you can target a single ECU to be programmed, where with ISTA/P and its Measures Plan, the whole car must be done. At the end of the day, I don't think ICOM-A is a must have, however, it is a faster more reliable interface for programming than ENET, and if it is priced reasonably, I'd pick one up if you want to be able to flash ECU's. If you only plan to FDL Code, or occasionaly flash a single ECU with E-Sys, you don't really need it.
#32
Hello shawn,
thanks for your reply, then I'll wait until the price drops again
#33
Same here. I think $150 is the sweet spot for me.
#34
I fully agree with you...just a question, in my vmware ista/d 2.30 is missing the f25 wds, is it normal? am I missing somethings?
Thanks!!! |
#35
Are you selecting X' Series, not 3 Series?
#36
Hey Shawn. Can u run Ista-D with the car running or would it have to be just ignition on position?
#37
I have not connected to my car with it, as I have just been using it for documentation. That said, I don't see why the car couldn't be running, same as with E-Sys.
#38
links are dead...
Do you have a recent ISTA/D + ISTA/P VM (english or french) for download ? Thanks ! Last edited by jean019; 11-07-2012 at 08:22 AM. |
#39
Running car is a great source of electrical noise. Unless your entire system is well grounded and shielded, it's preferred to be just with ignition switched on.
#40
We can expect difficulties with future versions..
http://forums.bimmerforums.com/forum...17&postcount=5
#41
Is it possible to consult technical bulletins TSB (bmw SI xx xx xx) in the ISTA/D VM ?
thanks |
#42
Not that I have ever found.
#43
sh.... do you know where we can find them ?
before some TSB where available here but it seems bmw changed the access ![]() thanks |
#44
#45
maybe you have some links to icom emulator which is ok with the ista ? Thanks |
#46
Yes, it is very hard to find. Unfortunately, a few day's ago my RapidShare account was locked and all my content deleted.
#47
Maybe you have a copy of the files ?
![]() if so I'm sure we can find somewhere to upload it ... Last edited by jean019; 11-12-2012 at 05:56 AM. |
#48
Shawn please,
Where can I found the EBA,s? Inside Ista D? Regards |
#49
What is EBA?
#50
No ?
