E90/E91/E92/E93 (2006 - 2013)
Old 11-12-2012, 09:34 AM
ghoover ghoover is offline
Mein Auto: 335i M-Sport JB4 DCI OCC
09 BMW 335i Metallic Ticking Noise?
Hi guys,
first real post, been reading alot about this ticking noise not really sure
The car has 80,000 km on it i have had it since 50,000 km
the car had some bad valve / lifter ticking, they all have been replaced about 3000 km ago
now its getting cold out
the car only does this when its cold
here is a video of the tick
https://dl.dropbox.com/u/31068396/BM...G_11052012.MOV
any thoughts or ideas?
Old 11-12-2012, 01:26 PM
crazyeyeskilla's Avatar
crazyeyeskilla crazyeyeskilla is offline
Mein Auto: '09 E90 335i xDrive 6MT
This is pretty common when N54/55 engines are cold. Mine ticks for a few minutes when cold, then it goes away. Always has. There's a long history of discussions on the subject at Bimmerfest. Here might be a good one to start with: http://www.bimmerfest.com/forums/sho...d.php?t=260555
Old 11-12-2012, 05:25 PM
CALWATERBOY's Avatar
CALWATERBOY CALWATERBOY is online now
Mein Auto: 2009 E93 N54
Not a problem here. Not in Canada or Colorado either.
40°F is Winter in SF. Below that a week in December. Much colder where ya'll are?
Old 11-12-2012, 05:30 PM
snow here tomorrow! so yes gets cold 0C to - 25C for Nov to end of Feb, thats why we usually stick to awd / xDrive vehicles with snow tires.
no one else gets this ticking noise?
the dealership mechanic today said they are just noisey ticky engines.
Old 11-12-2012, 05:45 PM
kmorgan_260 kmorgan_260 is offline
Mein Auto: 2007 335i
Mine does this too and the dealer has listened to it on two occasions. They say it is perfectly normal. Doesn't sound normal to me but it runs fine and has for the last 40K miles that I have owned it.
94 318i, 97 528i, 07 335i
Old 11-12-2012, 09:42 PM
sptt144 sptt144 is offline
Mein Auto: 2009 335i
How long does it take before it stops ticking from the time you start it? If it is very cold out (which living in Canada, I'm sure it is) it will take some time to get the oil up to the top and thinnned out enough to quiet the lifters. Although, I once had an engine (2002 Mercedes Benz) that did that and after I finally took the valve cover off to research, found (by accident) that there was a little loose screw that held down the oil rail. The oil would quiet this down once it got going and all the time I thought I had sticking or noisy lifters. On another car (2005 Nissan Altima SER), it ended up being my timing chain which was rattling due to the chain guide having slipped down (difficult repair) but it sounded like it was coming frm the valves. I finally nailed that one down using an auto stethascope ($13.00).
Old 11-13-2012, 05:44 AM
it only does it when its cold and it goes away once its warmed up, i am trying to keep the oil at max level to see if this mitigates the noise
i will try the stethescope idea too
Old 11-13-2012, 11:20 AM
Robin128 Robin128 is offline
Send a message via ICQ to Robin128
Mein Auto: 335i auto, Volvo T5 man
Mine does it ... I'm thinking cold oil slowly filling the cam followers...normal.
Changed them on my old ford but was doing the same after 15,000m.
HTH
One should treat others as one would like others to treat oneself.
Old 11-13-2012, 12:49 PM
Only when the engine is cold, say for the first minute it's idling. I don't think it matters whether the ambient air temp is 50F or 0F, but when the engine oil is below operating temperature, it occurs. A couple of years ago I read it had something to do with the lifters.
Old 11-13-2012, 01:10 PM
Same thing...lifters : followers.
Old 11-13-2012, 05:37 PM
Sounds like you are OK. If it ever gets down into the 30s here I'll see if mine does it as well. Lowest it's been is 42 degrees for one night but we are supposed to have a cold wave. I have not had any noise on my 2009 with 32K yet but weather is perfect out here.
