E36 (1991 - 1999)
Old 03-21-2012, 04:15 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Originally Posted by Mr Gusta View Post
does this mean the RHD leans to the left
No, it does not, because the car leaning thing is a MYTH. Totally unfounded.
1998 BMW 328is
1966 Pontiac GTO
Old 03-21-2012, 04:17 PM
bmw-mania bmw-mania is offline
Mein Auto: BMW
+1
sag from WEAR.
Originally Posted by cj.surr View Post
I don't have to read the username on these posts to know who wrote it.
Bmw-Mania, Ladies and Gentlemen.
Old 03-21-2012, 04:21 PM
armando325i armando325i is offline
Mein Auto: 325i
grow up, man. there is no need for all your bull****!
i said, that if the car leans to the left or to the right, its nothing to do with the drivers position or batteries position, its because suspention on that side is weaker than in other side, and MOSTLY it will show up more than normally, when weight is added on the car!
Old 03-21-2012, 05:21 PM
Joe__Sterling's Avatar
Joe__Sterling Joe__Sterling is offline
Fast Cars Suck!
Send a message via AIM to Joe__Sterling
Mein Auto: '13 FIAT 500 '68 BMW 1602
Solution.
*The I Drove to Both East and West Coast Bimmerfest Club* Member #1
@Joe__Sterling on twitter & instagram (two underscores)
Old 03-21-2012, 05:33 PM
Mein Auto: 325i
Originally Posted by Poorboysracing View Post
Solution.
+E36
but still it will be there, only solution is to get the coilovers and adjusted
Old 03-21-2012, 06:19 PM
Jordo Jordo is offline
Mein Auto: 1995 328
It's a myth. How does BMW know if you weigh 110lbs or 300lbs. That would need, different-different springs depending on your weight... If that makes sense.
Your car is what 13-19 years old.... Your springs are clapped out. Plain and simple.
1995 325i with 120k on clock. All stock, for now.
2002 BMW X5.... Not stock.... At all.
Old 03-22-2012, 12:26 AM
Si e30 Si e30 is offline
Mein Auto: E36 M50TU
Huumm...just check with Bentley manual, the ride High measured from center rear arch ( rear fender lips) to the bottom side of rim and found 2cm deviation between left and right .
my old lady has Right driver side anyway...seems I need to check the Coil Spring as mentioned in Bentley....any one know what is the length of unloaded spring, will try to measure it
Old 03-22-2012, 09:19 AM
Mein Auto: BMW
more eyereeesh
Yes. It does.
Driver position IS the CAUSE.
OP drives on right side.
Right side SAGS 2cm.
You follow?
RIGHT side & RIGHT SAG
Is that a comma at the end of your SENTENCE?
Suspension
Your sentence composition is getting better..
But, you need to work on your GRAMMAR, twit.
weight added on the car? Really?
+E36
Oh, "THE COIL-OVERS and ADJUSTED". (?)
Is that all?
You're giving the rest of the hard working, hard drinking paddy's I know a bad name.
Éirinn go brách
Read a BOOK.
If 2cm really irritates you that badly.
Take the springs from the RIGHT, and put them on the LEFT.
Take the springs from the LEFT, and put them on the RIGHT.
Drive like normal.
In about 2 weeks your 2cm difference will disappear.
Cheers!
Old 03-22-2012, 09:21 AM
Mein Auto: BMW
Hmm..
..Solution?
I concur..
SOLUTION.
Old 03-22-2012, 01:23 PM
David325is David325is is offline
Mein Auto: 325is
Its normal read the sticky's
Old 03-22-2012, 01:40 PM
Mein Auto: BMW
Yes.
Its normal for the car to lean.
Its cause is from DRIVER WEIGHT.
Jeezus..
Does anyone have a picture of the posterior of THEIR RHD E36 from a wrong lane country??
Not pics scoured from the 'net..
WE CAN LOOK AT THEM SIDE BY SIDE in comparison to end this nonsense.
Old 03-23-2012, 08:02 PM
john kaminski john kaminski is offline
Mein Auto: 1994 325i
So Ze German, where is the battery located ? I also have a slight lean to the left - maybe previous owner had a fat wife !
Cheap Trick
Old 03-23-2012, 08:18 PM
Mein Auto: 325i
exactly.
this is suspension not the driver what leans the car to one side.
especialy for our, hero, bmw-mania, here u go, a pict of my own car, rhd leaning to the left, almoust full tank+ 2 kids on the back, taken aprox 1 y ago. at that point all 4 springs was about 1y old, all front suspention was sorted out from the dealer.
are u still thinking, that driver is the problem?
ps, the text is all urs, run the spelling check
f..k the fuel economy
Old 03-23-2012, 08:38 PM
ZeGerman's Avatar
Warm Leatherette
My car has never leaned to either side, because it was not designed to do so.
1998 BMW 328is
1966 Pontiac GTO
Old 03-23-2012, 08:52 PM
Mein Auto: 325i
this is the point, car leans to one or other side, becouse of worn suspension/ on that side, it dosnt meant that whole side is bad but some is a bit more worn than in other side. end of story. thats what im saying all day long, its just a bit worn suspension what couses this. and early sign is, when car is loaded and thats it
p.s. like that ur car has straight lines
Old 04-17-2012, 09:34 PM
kaos_325i kaos_325i is offline
Mein Auto: 1994 325i sedan
exactly.
you're camera is leaning homie
Old 07-30-2012, 02:57 PM
naturedude32 naturedude32 is offline
Mein Auto: E36 323iS
Originally Posted by bmw-mania View Post
Hmm..
..Solution?
I concur..
SOLUTION.
DO IT!!! i dropped mine 3 inches, love it
Old 07-31-2012, 09:00 AM
Mein Auto: BMW
Holyfck.. you really gave that fcker CPR.
just re-read that drivel.. But, now that we're talking about lean..
Old 07-31-2012, 07:20 PM
And what side is the battery on ?
Cheap Trick
Old 08-01-2012, 12:01 PM
Mein Auto: BMW
Open Hood.
Open Trunk.
Take a guess.
Old 11-12-2012, 03:03 PM
kmorgan_260 kmorgan_260 is offline
Mein Auto: 1997 528i
Sorry to revive this old thread but I have owned 3 e36s and every one had at least one broken rear spring when I bought them. One with only 89K miles had both broken. That one was actually not noticable since it sat level. The others sat lower on the side with the broken spring. Not sure if this is a very common problem or if I am just unlucky.
The Bentley manual goes into detail on ride height and the specs it puts forth are the same for both sides. The e36 wasn't designed to lean although I was told that the battery being on the right rear is supposed to partially offset the weight of the driver.
94 318I (Daughter's car), 96 740IL(current project), 97 528I(DD), 07 335I(Son's car)
