E34 (1989 - 1995)
Old 11-03-2012, 11:49 PM
M540FELLA's Avatar
M540FELLA M540FELLA is offline
Josh
Mein Auto: 95 540i m sport
New Coilovers Installed
Well the rears anyway. The fronts are at the machinist waiting to get welded up.
Kido coilovers that are ride height adjustable, and shock dampening adjustable as well.
I adjusted the dampening to the softest setting a took it for a ride. It's about a inch lower than it was with the eibach lowering springs. Drove around a little but smelled burning rubber, turns out I have them set a little to low.
The tires are rubbing on the trailing arm. So I gonna have to get some wheel spacers, but until then will have to bring the height back up.
Before:
After:
Old 11-04-2012, 10:19 PM
_Ethrty-Andy_'s Avatar
_Ethrty-Andy_ _Ethrty-Andy_ is online now
E34 Converted E30 Fanatic
what offset and size are your wheels? mine dont rub at all, my schnitzers are 17x8.5 et13 front and rear, though the front is VERY close to the strut
Old 11-04-2012, 11:19 PM
M540FELLA's Avatar
Josh
It's kinda weird only the left side rubs, on the trailing arm. I'm running style 37 m-pars from a 740i sport,18x9.5 et 25 in rear.
Old 11-04-2012, 11:52 PM
okay that will be your rubbing, wider taller rim and higher offset. my rims are miles away from the struts out back, like a good inch and a half id say. re rubbing on one side only, i bet they are set at different spring rates. the side that rubs you should increase the spring rate maybe 5 turns
Old 11-05-2012, 05:18 AM
e34_spangler's Avatar
e34_spangler e34_spangler is online now
e34 User
Mein Auto: bmw e34
Looks nice!
Sent from my SCH-I535 using Bimmer App
1992 525i
beyren mesh wheels
Dinan Performance chip
Ka motors carbon intake
st suspension's springs
Old 11-05-2012, 10:13 AM
1995i540 1995i540 is offline
Satin Black E34
Mein Auto: 1995 540I/6
Looks nice, plug and play?
How was the swap? Did you just remove the old shock + spring and replace it with this unit and adjusted it before lowering the car?
///////////////////////////////////////////// E34 Addicts
Old 11-05-2012, 11:30 AM
M540FELLA's Avatar
Josh
There rears are totally plug and play. Just take out the old and throw in the new! I did have to drill out the bolt holes, they were a little off but not by much.
Old 11-05-2012, 12:37 PM
Satin Black E34
You made existing holes bigger or made new ones? Would old shocks still fit and secure on the bolt holes (if you made them wider?)).
I assume you did not need a spring compressor etc? This sounds pretty cool, hope it holds up so make sure to do an update
Old 11-05-2012, 01:15 PM
M540FELLA's Avatar
Josh
I had to take a little out off the holes on the back deck,not that much though. The old ones will still fit no problem. No compressor needed at all. Really can't wait to put the fronts on.
Old 11-05-2012, 01:47 PM
Satin Black E34
Man I'm jealous :\ I recall you got them for a good price? Point me to the store I just want to see what I'm looking for $$$$ wise
Old 11-05-2012, 02:27 PM
M540FELLA's Avatar
Josh
It was a group buy on bf.c, but the guy that was running it (AquilaBMW) is moving to the U.K. So I don't know if he's gonna do another one.
Ebay doesn't have them as of now, but they have a lot of similar sets. A couple of guys on bf.c are running the b/c racing, and the ksports. JOM is making a kit you can straight install no cutting or welding. It's kinda a build your own coilover kit really. However you don't get the dampening adjustability. http://forums.bimmerforums.com/forum...=JOM+coilovers
Old 11-05-2012, 03:17 PM
Costa's Avatar
Costa Costa is offline
Mein Auto: Supercharged E34 540i6
What are you gonna do with the old set up? *hint hint*
Old 11-05-2012, 03:26 PM
Satin Black E34
Nice thanks, honestly I want it because I don't want to deal with stupid spring compressors when I need to replace the components.
#lazy
Old 11-05-2012, 03:50 PM
M540FELLA's Avatar
Josh
Costa, I'm keeping the old set up just in case have to get a shock replaced, or some other problem arises. Also hate messing with spring compressors, Aleksey.
Old 11-07-2012, 06:22 AM
rdc rdc is offline
Russell
Mein Auto: 1995 525iA
In general I see that different brands of tires have different overall width and tread width. That may cause part of your rubbing issue where someone else with the same wheels, springs and coilovers do not have an issue. Just thinking outloud.
1995 525i auto, 1/95 build, EAT chip, abt 228K miles, EC mirror, HID, Lumbar, Oxford Green/Parchment, rebuilt trany @ 208K
Old 11-07-2012, 06:28 AM
Monsignor's Avatar
BMW CCA Memeber #445389
Mein Auto: M50 Big Body
I dont know if they tires can have actaully different specs. a 225 with tire will be 255mm. it must be. i think the differences are in the flexibilty of the sidewall for bulge or stretch to compensate for difference between wheel and tire width. For instance, Falkens dont stretch as well as general UHPs, but they damn well with both be 255mm wide if they 255 tires..
1995 525iA 250k mi Shifted Performance E34
2006 325i/6 48k mi
2003 350Z 87k mi Shifted Performance 350Z
Garden State Euros
Old 11-07-2012, 07:35 AM
rdc rdc is offline
Russell
When I was comparing stock size bmw tires I specifically noted that the tread width being different between manufacturers such as Michelin and Bridgestone. This may be more to do with tread and shoulder design. Some tires have squarer tread while others have a more rounded tread. That said a 255 tread width should be 255 wide for all manufacturers. But I suspect there are some differences.
Old 11-07-2012, 07:39 AM
Monsignor's Avatar
This is true. I understand. The squared/rounded differences and shoulder tread design is a good point. Taking that into consideration even manufaturer's model tires could vary in that regard. Maybe some Michelins have the same differences as you've mentioned thus far.
2006 325i/6 48k mi
Garden State Euros
Old 11-07-2012, 08:25 AM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is online now
Humble E34 lover
Mein Auto: 1992 525i
I agree about the differing shape of the tires of the same size. My E34 came with nearly worn out Bridgestone Potenzas. Even though the tread width was the same on the replacement tires, the foot print of the Potenza was significantly wider.
It's hard to tell in the attached pictures, but the one in front of my house has the old Potenzas on it and the one in the cul-de-sac has the new tires. Rear tires for point of focus.
ID:	348664   Click image for larger version
Steve
Calypso Red 1992 525i with 170K miles
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 11-07-2012, 09:05 AM
Monsignor's Avatar
Off topic, but i really need to reiterate: <3 <3 <3 Calypso <3 <3 <3
2006 325i/6 48k mi
Garden State Euros
Old 11-07-2012, 09:47 AM
BMR_LVR's Avatar
Humble E34 lover
Me too
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 11-12-2012, 10:19 PM
MySatinDoll MySatinDoll is offline
Mein Auto: e34 535i/5
When you talk about suspension performance. Coilovers change the game.
I marked my front damper adjustments on my strut brace/tower.
So I can gauge the soft and firm by feel in case I lose the little dial.
Which already happened to one of them when it was "Father son working on the car day."
Looks good man glad you got them installed.
I think michael will continue to offer them.
But I'm sure it will not happen till after he gets settled in.
Old 11-12-2012, 11:02 PM
M540FELLA's Avatar
Josh
Yeah still waiting on the fronts, getting kinda pissed. That's a good idea with marking settings.
Old 12-12-2012, 02:01 PM
M540FELLA's Avatar
Josh
And now the fronts are in! They are incredible! The ride is night and day. I haven't even changed the dampening on the fronts yet. Pretty much a bolt in after the welding is completed. Although I had to change out my bearings. My first attempt on how low to set it was a little ambitious lol. I couldn't even turn my wheel. Easy to adjust though, just brought it up an inch and done.
Before:
Too much wheel well
After:
Ahh that's better!
Old 12-12-2012, 04:50 PM
Monsignor's Avatar
now you just gotta make dat booty drop
2006 325i/6 48k mi
Garden State Euros
