Old 10-30-2012, 08:37 AM
Mulchman's Avatar
Mulchman Mulchman is offline
Mein Auto: '07 650i
Odd sound after startup.
Shortly after starting my car, while still in the garage I will hear what sounds like a kitten crying under my hood. Its a high pitched squeek that sounds like a kittens meow. Any ideas? Does not happen all the time.
'07 650i Coupe - Black Sapphire Metallic
M6 bumpers, skirts & wheels
BMW M Cross Spoke Composite 101 Rims 20"
HUD, Comfort Access
Old 10-30-2012, 08:49 AM
greco2000's Avatar
greco2000 greco2000 is offline
Mein Auto: 2008 650i LCI
Do you hear this sound when the A/C is turned on? When you hear it again, turn off your air completely and see if the sound goes away.
2012 BMW M6 CONVERTIBLE
Old 10-30-2012, 12:41 PM
Mulchman's Avatar
Mein Auto: '07 650i
Will do and report.
HUD, Comfort Access
Old 10-30-2012, 05:43 PM
Yorgi's Avatar
Yorgi Yorgi is offline
Might be belts, tensioner bearing, vacuum leak, vanos. Can you get someone to start the car for you while you stick your head under the hood?
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
Old 11-01-2012, 12:23 PM
HerbP HerbP is offline
You will here a air sucking sound from the air intake, until the engine goes into a closed loop program. The intake is just manually sucking unmetered air. This is usually on a cold morning start.
Old 11-01-2012, 12:58 PM
Mulchman's Avatar
Mein Auto: '07 650i
I still need to stick my head under the hood when starting. It is not a belt or at least doesn't sound like one. Nor does it sound mechnical like VANOS. Vacuum is possible or the closed loop deal. I'll try to remember to check when I get home.
HUD, Comfort Access
Old 11-01-2012, 06:20 PM
pablo645's Avatar
pablo645 pablo645 is offline
Mein Auto: 650i Convertible
I believe I know that sound. I hear sometimes when I start my car and asked the dealer about it once. I was told it has something to do with the fuel pump priming up or something to that effect. SA said it's not anything to worry about but we'll see. I though it was from under the hood but it was from the backend but the sound seems to echo under the car.
2012 650-xDrive Convertible. Titanium Silver Metallic - M Package - Driver assist package- Cold weather package - luxury seating package - Bang & Oulfsen system.
Previous Cars:
2008 650 Convertible 6 speed manual
2004 645 Convertible 6 speed manual
1994 540 6 speed manual
Old 11-02-2012, 04:47 AM
Mulchman's Avatar
Mein Auto: '07 650i
Of course now I can't replicate the noise. Will report back when I can.
HUD, Comfort Access
Old 11-13-2012, 03:56 AM
garethparsonage garethparsonage is offline
650i vert
Mein Auto: 650i
I get the same noise, after start up brief high squeak type sound from behind dash left side? I think its something to do with the fan motor, it has only started since the weather has gone cooler, not bothering me too much as its only for a few seconds
Old 11-13-2012, 05:05 AM
Mulchman's Avatar
Mein Auto: '07 650i
It hasn't happened since I first posted...of course
Next time it does I will stick my head under the hood as I sould have the last time...
The fact that it has gotten cooler outside and I hear it less (or not at all) makes me wonder if greco2000 wasn't on to somthing with the A/C?
HUD, Comfort Access
