Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > F10 / F11 (2011 - Current)
The new chapter in the highly successful story of the BMW 5 Series Sedan (F10) and wagon (F11)
Old 11-13-2012, 08:43 AM
Alan L. Alan L. is online now
Mein Auto: Msport 335i
HID Fog lights from DDMTuning.com works on the F10
Just a FYI for those on the fence about doing this upgrade...
I bought the 35watt 5000K H11 kit from ddmtuning and they work flawlessly on my 2013 Msport without any errors popping up or flickering. Just make sure you also order the "Error Code Eliminator" along with your kit. For $50 total you can't go wrong.
Alan
Current - 2013 N55 535xi Msport SAT
Retired - 2009 N54 335i Msport 6MT
Retired - 2000 M52TU 323i ASA Supercharged 5MT
More photos of my car here
Old 11-13-2012, 10:09 AM
alextremo alextremo is offline
Mein Auto: F10 550i
Nice - any pix?
Old 11-13-2012, 10:21 AM
none yet but its def. much brighter than the regular bulbs i had in there before. The 5000K gives off a slightly more blueish color than the factory hid's but its a pretty good match. Far from those ghetto 6000K and up blue/purple hids i see idiots running around with in their mini vans.
Old 11-13-2012, 10:32 AM
Mr. Grumpy's Avatar
Mr. Grumpy Mr. Grumpy is online now
BMW Freak
Mein Auto: 2011 535i, 10 Ninja ZX-14
Isn't the H.I.D. fog lights to bright for the incoming traffic? I'm on the fence with this mod since I've been wanting to match the fog lights color with the head lights but not to the account of blinding others.
I'm not trying to put you on the spot, I just want to hear your personal experience with the H.I.D. light output and the incoming traffic. Has some one flashed their high beams at you yet?
2011 535i (07/2011 build) Imperial Blue, Oyster/Black Interior, Anthracite Wood Trim, ZPP, ZP2, ZCV, ZSP, 2TB, 6NF, 6NR.
2009 Kawasaki Ninja ZX-14
Retired: 2009 328i,Titanium Silver, Black Interior, Dark Wood Trim, ZPP, ZLP, 609, 494, AAW Tune.
Old 11-13-2012, 10:52 AM
miamiboyca's Avatar
miamiboyca miamiboyca is offline
Mein Auto: F10 6MT
I like my minivan... and just wait until I put the 22"s on it.
Some night time pics would be great! Also how do you make sure they are aimed correctly?
2013 535i Space Grey, Biege, M-SPort, Premium, Tech, Cold Weather, Luxury Seating, PDC, 6MT ED-10/11/2012 - PCD Redelivery-12/14/12
Old 11-13-2012, 11:38 AM
I have not been high beamed yet after I installed this. I don't expect this to blind incoming drivers since they are so low to the ground. Honestly the lights barely hit the bumpers of cars in front of me so unless i'm on a wicked hill i don't think this will be a major issue. Quite honestly even if it did I wouldn't care that much if it helps me prevent all those idiots that likes to pull out of a side street directly in front of my car. I think the F10 is too quiet or something because I never had this issue with my previous cars because they all had louder exhaust systems.
Alan
Old 11-13-2012, 12:05 PM
miamiboyca's Avatar
Mein Auto: F10 6MT
Alan
Unfortunately for me I have had that my whole driving life... lol
Old 11-13-2012, 12:18 PM
lll F10 lll lll F10 lll is offline
Euro ****
Mein Auto: 2012 535i M-Sport
THANK YOU, finally someone with a STRAIGHTFORWARD simple answer. Ordering mine today
Old 11-13-2012, 12:20 PM
Silververtu Silververtu is offline
Mein Auto: 2013 550i M Sport
Great find Alan. I was about to get 3000k 55w halogen foglights. How hard is the install, do you have DIY instruction? Did you get the HID harness and mounting bracket? Also, where did you put the ballast?
2013 BMW 550i M Sport SAT
Gone But Not Forgotten:
2006 AUDI 2.0T A4 Avant, 2007 BMW Z4 3.0si Roadster, 2006 BMW M Roadster
Old 11-13-2012, 12:34 PM
Euro ****
Leaning towards the 55W kit as well.
The install should be very straight forward, plug & play. I think the toughest part would be to find a place to securely mount the ballasts, but that should be it. No cutting or soldering required.
Old 11-13-2012, 12:42 PM
Just order the 35watt kit plus the error eliminator cables. You don't need anything else. Should be $50 plus whatever shipping is.
The install is simple as can be for the Msport bumper. Not sure if this will work on the non Msport bumpers.
1) Remove the mesh grill around the fog lights simply by pulling it straight out. Try to get your finger around the lens and mesh grill then just pull.
2) Stack the ddm tuning kit ballast, ignitor and error canceller on top of each other. They are small boxes and you can use double sided tape to do this. You are doing this to make the install cleaner and take up less space by stacking them up together. Also prevents them from banging around each other during bumps.
3) add double sided tape on the bottom of the ballast. This will mount to the bottom shield behind the fog lights
4) connect the wires and swap in the hid bulb
5) peel off the backing of the double sided tape and place the electronics directly behind the fog light housing. There is just enough room and a flat surface for this to mount back there. Seems sturdy and its completely out of sight. Use the 3M grade (red backing) and it also helps if you wipe down the flat area behind the fog light before sticking it there.
6) reinstall the mesh just by pushing it back in.
Honestly this whole process took me less than 30mins both sides on my Msport bumper.
Alan
Old 11-13-2012, 12:45 PM
Someone on the other forum said the 55watt kit didn't work on his F10 and the 35watt worked fine. His car had errors so he stuck with the 35watt kit. He was trying this in his headlights though so not sure if the fogs would react the same.
Alan
Old 11-13-2012, 01:04 PM
Great instruction. Thanks Alan!!!!
Time to get my hands dirty again
Old 11-13-2012, 01:48 PM
Mr. Grumpy's Avatar
BMW Freak
Alan
Alan, thx for the response. I was thinking the same thing, the fog lights are so low that it shouldn't bother the incoming traffic but I wanted to hear it from someone that had the upgrade.
I upgraded the D1S bulb to 5,000K so I'll be ordering the same for the fog lights.
Again, thx for the response.
Old 11-13-2012, 02:04 PM
Euro ****
I upgraded the DS1 bulb to 5,000K so I'll be ordering the same for the fog lights.
Were your 5000K D1S from DDM Tuning as well?
Old 11-13-2012, 02:17 PM
Mr. Grumpy's Avatar
BMW Freak
No, I bought mine on e-bay but they're made by Sylvania. Is the Osram Sylvania D1S 5000k.
Old 11-13-2012, 03:12 PM
Euro ****
All you ballers. I might be the first one to experiment with the DDM Tuning 5000K D1S replacement bulbs then!
Old 11-13-2012, 04:19 PM
I would advise against getting the ddm tuning bulbs for your headlights. My stuff shipped straight from china and were pretty much what you would expect for $35. Personally I would get higher quality headlight bulbs or leave them stock but that's just me.
Alan
Old 12-10-2012, 07:30 AM
Medimisr Medimisr is offline
Mein Auto: 2013 535i M-sport AW m/t
I just put 5000's on my fogs... i love how they accent the msport bumper, but i can't stand the contrast between them and the angel eyes and headlights!!!
I've been researching a solution for this, but i'm finding people had issues with the led replacements for the led's. I'll probably change the stock headlight bulbs to 5000's, but the angel eye rings will still be a dull white compared to the blueish tint that the 5000's have.
Old 01-03-2013, 05:39 PM
Chuck W.'s Avatar
Chuck W. Chuck W. is online now
Mein Auto: 12 BMW 535I MS Alpine Wht
Many thanks to Alan L. for starting this post. I bought the same lights from DDM Tuning. Great results.
Driver's Side Mod.. Passenger's Side OEM
Both Done
2012 BMW 535I 14K Miles
ED Pick Up on 12/03/2011; US Pick Up on 01/27/1012
Alpine White, M Sport, Blk Nappa, Cold Weather, Luxury Seating, Premium, Premium Sound, Tech, Sports Trans, Active Cruise, Heads-Up
Mods - Quad Exhaust Tips, HID Fog Lights, Clear Front Reflectors, M5 Spoiler, Calipers Painted Black, 12.5 mm Rear Wheel Spacers, 5% Tint Rear - 35% Tint Front - 50% Tint Windshield
Coding by itschase (Chase)
Next; ED of 2014 M4
Old 01-03-2013, 06:14 PM
Travel4Surf's Avatar
Travel4Surf Travel4Surf is offline
Mein Auto: Everglades 243
Can you please post a photo with just the fog lights and angle eyes (park lights) on?
Minha patroa é um BMW
Old 01-03-2013, 08:20 PM
Looks great!
If you want bulbs that match the halos I would suggest the morimoto 5000k bulbs. They are more white while the ddm bulbs looks alittle more blue.
Alan
Old 01-04-2013, 04:38 PM
Chuck W.'s Avatar
Sure. Oddly enough, in person there is not such a blue tint as shown in the photo.
Next; ED of 2014 M4
Old 01-05-2013, 10:47 AM
BigDeep1's Avatar
BigDeep1 BigDeep1 is offline
Festaholic
Mein Auto: 2011 535i Sport
Hmm...
Is it possible to change the bulbs in the angel eyes to get the 5k temp color? I will say that I love how the new OEM BMW angel eyes are much brighter than the aftermarket upgrade bulbs of the e60 and similar.
2011 535i Sport (Prem 1, 2)
Old 01-19-2013, 07:43 PM
DallasBimmer's Avatar
DallasBimmer DallasBimmer is offline
Big D Alpine W Bimmer
Mein Auto: 2013 535i MSPORT/09 G37S
Alan
OK, I tried getting the mesh grill out by pulling on it and its pretty snug in there. My car is only days old so I don't want to break the grille piece.
Is there a trick to doing this without breaking any (tabs)?
