Old 10-29-2012, 05:21 PM
coolguy1 coolguy1 is offline
Mein Auto: 2006 525i
so Parts are about $100/axle/Pad in Ebay
What are the installation cost per axle through an independent Tech?
if rotor replacement also needed, then part is about $100/rotor/axle -- How much for additional install cost per axle?
Old 10-29-2012, 07:38 PM
wiredread wiredread is offline
Mein Auto: 2006 bmw 530xi
Thats way too much money for the rotors. I did front brakes with the rotors changed and it cost me about 270 with sensor and other parts.
Old 10-29-2012, 08:18 PM
Man... It's soo tough to find a normal pricing anywhere w/ Independent Techs.. You have to make zillion calls and each ones pricing is sooo different. Once you move to a new place, the hunt begins all over. I have few things to take care: Break Pads, oil change, filters, brake fluid etc.. Each place offers very different prices lol.
Old 10-29-2012, 09:34 PM
supratreo supratreo is offline
Mein Auto: 08 535i
im sure the quality of work/experience also varies with price so also take that into account. however, if you can, do the brakes and oil change your self, its very easy.
Old 11-13-2012, 01:55 PM
CarGuyHere CarGuyHere is offline
Mein Auto: 535Xi before a 330Xi
Originally Posted by pcy View Post
Buy rotors and pads on-line (RMeuropean dot com, AutohausAZ dot com are good) and replace them yourself or find an independent mechanic.
Take a calipers and measure the thickness of rotors. If the current thickness of the rotors is below the MINIMUM required, then replace the rotors. Otherwise, it's not necessary.
What is the minimum thickness for a 2008 535Xi?? Or where would I find that info?
Old 11-13-2012, 01:58 PM
Cool
Wow. You even beat this guy who only got about 120K miles on his rotors!
Is that the new fad in brake rotors?? No more drilled!
(I can't believe anyone could do that) I wonder how wierd that would feel braking.
The things people do to reduce weight!
Old 11-13-2012, 02:15 PM
Question
How does BMW know that I need to replace my brake in 3000 miles??
Does it actually measure the thickness, or the computer assumes how much has worn off?
And, if measured, how accurate is it?
How far can I do past the "due date?"
Old 11-13-2012, 02:24 PM
Gustavoerod's Avatar
Gustavoerod Gustavoerod is offline
Mein Auto: 2006 530i
The break sensor is designed to wear off at specific rate, that's how the computer determines how long you have before new pads are needed.
Old 11-13-2012, 02:26 PM
Crazy part is, when I changed my pads I noticed there's so much pad left on them that any other car without a sensor can go about 15k miles more with those pads.
Old 11-13-2012, 02:33 PM
That's sounds like BMW!
Did you replace pads, or pads and rotors?
I NEVER replace rotors until they give me a problem such as warped. So usually its two sets of pads for each set of rotors.
Old 11-13-2012, 02:49 PM
Same philosophy here, don't need new rotors until warped.
Old 05-30-2016, 12:40 PM
sportigliatti sportigliatti is offline
Mein Auto: 535i
535i Brakes
Originally Posted by danaroy View Post
I own a '08 535i with sports package plus stage2 intake. Pushing around 330HP 345torque. When I had to do my front brake for the first time they wanted $900.00 at the dealer. I went to http://brakeperformance.com ordered me front and rear sensors, high performance semi-metallic (last better than non metallic when you drive like I do) pads and dimpled and slotted rotors (not drilled, they can crack and warp, dimpled have a life time warranty). Had my local BMW shop install them and I spent about $1100.00 total. That's for front and rear high performance (a very sexy) brake rotors, pads and sensors installed for $200.00 more than OEM for just the front. Just make sure the shop you chose has the computer to reset your maintenance info.
GREAT ADVICE! I have the same, minus the stage 2 intake. Thank you, DanaRoy!
Old 06-05-2016, 09:41 PM
quinby1 quinby1 is offline
Mein Auto: 2007 530i
Picked up a complete front/rear brake service kit from BavAuto(rotors, pads, sensors) for <$400+shipping. Paid my mechanic $170 for labor to do both axles. Done for total of less than $650.
Doesn't look like a hard job like other members mentioned but I don't have the tools nor the experience so I'm not going to attempt that task.
