E90/E91/E92/E93 (2006 - 2013)
Old 11-13-2012, 01:36 PM
Doktor Bert Doktor Bert is offline
Der Sturm Uberdoktor
Mein Auto: Mercedes-Benz
E93 Cranks But Won't Start - Tech Tip:
Had a 2008 328i (28,000 miles) come in with a crank but no start condition. The dealer had checked everything and came up empty handed. I discovered the problem was a loose ground behind the upper half of the rear passenger's seat. I applied dielectric grease and tightened the 6mm nut (10mm hex) and the car fired right up.
Hope this helps...
P.S. My bad, E90
Did you just pass me at 200kmh in a 300SD???"
Old 11-13-2012, 02:09 PM
DSXMachina's Avatar
Automaticallyparsinglinks
Hope this helps...
P.S. My bad, E90
What was the ground for? Was it a muti-point ground? How did you find it? Let's face it, the back of the car is not where we usually start looking.
Old 11-13-2012, 02:11 PM
Yes, blade-type multi-point ground. Just started looking at the wiring diagram and found the grounds for the DME were located there.
Old 11-13-2012, 03:48 PM
DSXMachina's Avatar
Good catch!
Would you mind taking a look at Autoque's thread in regard to vanos and valvetronic? It's not really about those things. Your input would be helpful.
Old 11-13-2012, 04:28 PM
Sure, I'm not really a BMW expert, I'm actually a Mercedes-Benz guy, but I am happy to help. Can you send me a link????
Old 11-13-2012, 06:31 PM
CALWATERBOY's Avatar
CALWATERBOY CALWATERBOY is online now
Mein Auto: 2009 E93 N54
Hope this helps...
P.S. My bad, E90
THAT'S good info - thanks!
Name:	Thumb up 04.jpg
