E60 (2004 - 2010)
Old 11-13-2012, 08:57 AM
KenWilk KenWilk is offline
Mein Auto: 2006 525i
SOS Call System Malfunction
My problem finally solved. I took my 525i to an independent repair shop and in 1 hour they determined thru a diagnostic check that the Telematics Control Unit (TCU) was bad. After it was replaced everything works fine, including blue tooth. The TCU is an amplifier looking box located in the left rear of the trunk. It was easy to remove & replace.
Old 11-13-2012, 09:56 AM
wyb's Avatar
wyb wyb is offline
Mein Auto: A car
Out of interest for future posters - would you mind sharing what the replacement part cost - parts + labor?
thx
535i XDrive | Alpine White w/Black+Natural Leather Interior
It's ALL perspective - get some. No - I am NOT addressing YOU!
Old 11-13-2012, 01:59 PM
txag_530i's Avatar
txag_530i txag_530i is online now
Mein Auto: 2006 530i
I had the same error and deleted the SOS option from my car via programming.
BMW SOS Error Fix
Old 11-13-2012, 06:04 PM
Mein Auto: E60 - 545i
BMW SOS Error Fix
Same here
Old 11-14-2012, 05:06 PM
phlfly's Avatar
phlfly phlfly is offline
Mein Auto: 07' 550i
Is anyone has a good procedure for this as what it has done at BMW coding website?
Also may be someone has NCS Expert and INPA to do and has experience with it
BMW CCA Member, Capital Chapter
Old 11-15-2012, 06:35 AM
phlfly's Avatar
Mein Auto: 07' 550i
I found a guy on BMW coding that will do remotely coding. If you need contact info let me know.
Old 11-21-2012, 08:59 AM
Smile SOS Call System
I found a local BMW mechanic in Dallas, not a dealer. The TCU was $276.50, reprogramming was $150, plus $75 for diag.
