E90/E91/E92/E93 (2006 - 2013)
E93 Cranks But Won't Start - Tech Tip:
Had a 2008 328i (28,000 miles) come in with a crank but no start condition. The dealer had checked everything and came up empty handed. I discovered the problem was a loose ground behind the upper half of the rear passenger's seat. I applied dielectric grease and tightened the 6mm nut (10mm hex) and the car fired right up.
Hope this helps... P.S. My bad, E90
Yes, blade-type multi-point ground. Just started looking at the wiring diagram and found the grounds for the DME were located there.
Would you mind taking a look at Autoque's thread in regard to vanos and valvetronic? It's not really about those things. Your input would be helpful. |
Sure, I'm not really a BMW expert, I'm actually a Mercedes-Benz guy, but I am happy to help. Can you send me a link????
THAT'S good info - thanks! |
