car misfires after i changed the plugs
i have a 97 bmw 528i i my starter went out so i put a new one on it and a new crank sensor and then i went and put new plugs in and went to start it up and it wont idle and when u rev it up it pops threw the intake anyone know what could be the probley...could it be the spark plug boots
Where did you buy the crank sensor? Unless it was a dealer-supplied part, it could be the problem.
Ed in San Jose '97 540i 6 speed aspensilber over aubergine leather. Build date 3/97. Golden Gate Chapter BMW CCA Nr 62319. |
i got it from advance auto
![]() '12 X5d Sapphire/Black/Bamboo, Sport (ZAP), Premium (ZPP) & Premium Sound(ZPS) packages: 20" 214's, OEM Hitch![]() GONE - '06 750Li Sapphire Black/Creme&Black (Loadeddddd)
cant do that on my ride
went and odered a new crank sensor see if the one i had in there was bad ill find out in the morning if it works hope so
Chk that the gnd wire (brown) is connected and d plug boots are in fine condition......
Sent from my GT-I9070 using Bimmer App |
Why not just install the old one?
Crank or cam? Why change crank sensor?
i changed the cranjk sensor cause i broke the one that was in it when i changed the stater i put a new crank sensor this morning , the plug boots look ok , and the brown ground wire is good so u think it could be the cam sensor they wanted $100 for one .... i hooked it up to a machi. and it shot 5 codes p1189- fuel control bank 2 sensor 1 .....p0101- mass or volumn air flow circuit ...p0505-idle air contol system....p0335- crankshaft position sensor "A" circuit....p0420-catalyst system effenciency below threshold... p1750-senconary pressure solenoid circuit range/peformance or system voltage input low ....p0173-fuel trim....... anyone know about these and what ones i need to change to get my car to run
