X5 E53 (1999 - 2006)
The X5 SAV Forum |
Spark Plugs
How often should you change the spark plugs?
BMW X5 2002 E53 4.4i M62
E61 525i 2004 M54 Auto E46 320i 2002 M54 Auto E46 330i 2003 M54 Sedan Manual |
Every 50k miles and/or every 2 years.
GGC BMW CCA #443004 Join the BMW CCA! 2005 X5 4.8is Le Mans/Black/6spd Steptragic ![]() 1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual ------------------------------------------------------------------- 1997 328iC Schwarz II/K/K 5 Speed Manual SOLD 5/2012 2004 645Ci Mineral Silver Metallic/Black 6 Speed Manual RIP 04/2011 |
This is the same interval I used on my old M62 powered bimmers and what we suggest to customers.
![]() Have questions? Need answers? Live Chat us! 8:30am to 12:00am Midnight EST sales@ecstuning.com | customerservice@ecstuning.com Customer Service Hours: 8:00am - 8:00pm EST Sales Team Hours: 8:00am - 11:00pm EST 800.924.5172 OEM BMW Part Number Search |
spark plugs
thanks guys. you can tell I'm not a mechanic!
I am looking at the OEM Bosch spark plugs with the 4 earthing points. Do you have to set the gap up these or are they pre-set from the supplier?
I have used the same OEM Bosch plugs. Gap is pre-set.
spark plugs
What are the benefits of changing your spark plugs?
I think mine have not been changed for quite a while but the car runs very well. Will you get improved mpg?
It's possible, but if the car is running very well there's no need to change anything.
BMW Tuneup & Maintenance Tips:
Tuneup & Auto Maintenance Tips To Lengthen Your BMW's Life Tuneup - an old-fashioned maintenance term that's nearly non-existent today. With electronic ignition and fuel injection came computers that took over control of engine settings. Early versions allowed for some tinkering, but today's engines require advanced equipment and training. You can, however, replace normal maintenance parts and still see improved engine performance from your BMW. Here are common maintenance parts you can replace to significantly increase performance and reduce major problems: Basic Ignition Parts Spark Plugs: Spark plugs are good indicators of engine condition. Removing and inspecting spark plugs tell you a lot about how well the engine is running and what may be causing problems. All spark plugs should be removed and checked every 30,000 miles - even if your BMW is "low maintenance" - you're told to change spark plugs at 100,000 miles. This prevents the plugs from seizing in the block, causing expensive repairs down the road. Always note which plug came from which cylinder. This tells you if a particular cylinder has a problem. BEWARE: New spark plugs can make a difference in your BMW's performance but only if replaced with the appropriate OE replacement plug. http://www.bimmerfest.com/forums/sho...d.php?t=471358 Last edited by Mudnyrey; 11-15-2012 at 09:17 AM. |
plugs
I dont have a torque wrench.
Do the plugs have to be torqued down or can I just tighten them by hand.
Torque down to hand tight, then another 1/4 turn. Too much or too little and bad things will happen.
