Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series > 7 Series DIY
7 Series DIY
Do It Yourself forum dedicated for 7 Series BMW Owners
Old 10-02-2012, 11:53 AM
Vecoplan Vecoplan is offline
Jeep on 42s, B7 on 22s.
Mein Auto: 2006 LJ, 2008 B7, 2015 X5
I pulled my lights out (yes- took the bumper off), took them apart and sanded and re-cleared the clear lenses on both the inside and out. While they were apart I replaced ALL the bulbs ( because it is such a pain to get my bear claws in there) and sent the lights to AAC lighting in Louisiana, because I have a friend who had them build a bunch of custom lights for him. They removed the CCFL units completely and built a custom LED replacement from scratch and hard wired it in to my existing system so that it operates completely stock. It really had a 100% factory look, is completely error free, and has a money back warrantee. My light look, and operate as if they were factory brand new.
I also just had a bunch of body work done, most of the car re-painted etc. the first day back having it (I was w/o it for a month) I curbed my 22s for the first time ever. Made it nearly 3 years flawlessly... Then this. So... Naturally I'm a little pissed. :-)
Just because I said it doesn't make it true... it just makes in my opinion. Conversely, just because you said it doesn't make it true, and I'm still going to form my own opinion. meverhart@vecoplanllc
Old 10-12-2012, 03:02 PM
rippjd rippjd is offline
Mein Auto: '05 745i / '10 X5 35d
- pls delete -
Old 10-12-2012, 04:30 PM
TUF-FKR TUF-FKR is offline
Mein Auto: Beemer Soon!
There is a re-adjustment period for sure when you have been without your 7. I just got mine back after being in the shop for 3 MONTHS! (new motor).
Understanding the re-adjustment myself right now.. But DAM did I miss my 7! Im in heaven right now! I have washed her twice in the last 72 hours
P.S. To fix the inner (if its a 3 piece) rim, its about $150 and many shops will do it. If its the outer lip, well for Asanti's there are shops on Ebay now that sell the replacement lip for about $300. I recently experienced my first curb
Old 10-12-2012, 05:43 PM
J-303 J-303 is offline
Mein Auto: 750LI
Great info! Mine are on order & I will take the bumper off because of this great info from all you guys.
Old 11-14-2012, 01:19 PM
gregory bork gregory bork is offline
Mein Auto: 2006 750i
hi, my name is greg. im wordering if you are anyone knows if you can make your angle eyes your running lights on a 2006 750i instead of the inside lights.
Old 11-14-2012, 01:21 PM
samadkins29's Avatar
samadkins29 samadkins29 is offline
Mein Auto: '03 745Li
Yes, the dealer can turn off the DRL's. Mine run just the halo rings when switched to the parking lights setting.
2011 535i
2003 745li (Sold)
HID Guide
LED Guide
ABS/DTC Guide
Old 11-23-2012, 04:36 PM
Chris29817 Chris29817 is offline
Mein Auto: 2006 750i (E65)
Which set of MTEC LED did you use?
Old 11-24-2012, 09:17 AM
I bought mine off ebay. But I think Mtec is up to Version 3 now.
2011 535i
2003 745li (Sold)
HID Guide
LED Guide
ABS/DTC Guide
Old 11-25-2012, 11:29 AM
julio745licandy julio745licandy is offline
o4cAnDyReD745Li
Send a message via Yahoo to julio745licandy
Mein Auto: 04 745 LI CANDY RED
o4 745li
? both of my front parking lights are malfunctioning. the light malfunction signals when i turn my car on. what should i do to check my light bulbs first or does it even use lightbulbs? I heard you have to remoove the whole bumper to do this. is this true? Also if i want to switch my angel eyes from yellow to bright white or blue do i have to replace the whole light or just a bulb? What are some good sites to purchase bmw parts at a cheap price? I recently put 22" wheels and now my steering wheel vibrates, forum says its the struts. Where should i start looking for parts? Thanks . any opinions greatly apreciated.
Old 11-28-2012, 09:17 AM
dontaewsu dontaewsu is offline
Mein Auto: 2007 BMW 750LI
Can someone please clear up the halogen vs led vs angel eyes?
are their 2 types of angel eyes out there? Led and Halogen?
and the car comes stock with halogen?
I have a malfunction light so i am replacing and i want mine to not be that amber color. I want them bright like the ones in the pictures shared. Are you saying these are LED Angel eyes?
http://img35.imageshack.us/img35/1699/closeupeu.jpg
Old 11-28-2012, 09:39 AM
Halogen is stock. LED is aftermarket and comes in a variety of colors. Your model will require you to remove the front bumper to do the install (not as hard as it sounds).
@Julio, you can replace your angel eyes w/o removing the bumper on your model. Yes you have halogen bulbs as stock. Pull them out and see if they are burnt out. Replace if needed.
2011 535i
2003 745li (Sold)
HID Guide
LED Guide
ABS/DTC Guide
Old 12-05-2012, 11:24 AM
E92-Lighting's Avatar
E92-Lighting E92-Lighting is offline
Mein Auto: 335i
the brightest LED angel eyes are MTEC V3's for the E65 and E66's, which is 100% plug and play.
BMW CREE LED ANGEL EYES ALL BMW MODELS MTEC V3 V4 DTEC V7 V8 V9 V10 V11 V12 V13 RGB V14 NO ERROR
BMW ACCESSORIES and PARTS
BMW LED INTERIOR KITS ALL BMW MODELS
please PM/Email us for Bimmerfest member BMW discount/combo pricing
info@e92-lighting.com "e90post5" for 5% off as the promo code at checkout
Old 01-23-2013, 06:53 PM
Bad boy Bad boy is offline
Mein Auto: 745i 2002
This is great now I'm changing every build in my car
Old 01-24-2013, 07:55 AM
Error Code
I put in aftermarket angel eyes LED. They worked for about a month, but now they are not coming on. The bulbs are still good. Though I am not getting any light from the angel eyes, not even with stock halogen. I have checked all the fuses, the parking lights come, but the angel eyes do not. Has anyone have this happen to them?
Old 01-24-2013, 08:24 AM
Mein Auto: 750LI
My oem one was out so I put aftermarket ones in and the same side went out after 5 days. Everything checked out okay as well. Don't know what else to do.
Old 02-01-2013, 11:49 AM
Mein Auto: 335i
this wont happen with MTEC LED angel eyes, we have them for the 7series since 2002 ~ to present, and it comes with a year warranty with every MTEC purchase
Old 02-03-2013, 05:08 AM
grahambell grahambell is offline
Mein Auto: 760i
Originally Posted by ShoNuff745i View Post
Guys, I just received my MTEC V3 and was trying to install them but couldnt figure out
how to remove a black plate that was right behind the bulb connectors. I called the BMW shop
and they want to charge me $250 to put them on for me because they said the BUMPER
has to be removed,...but I thought in all the threads I've read, they said that the bumper
DOESNT have to be removed on the '04 models? Did I Mis-read?
I did mine just by removing the air filter boxes and loosening the headlights very fiddle'y, get someone with smaller hands would be easier but certainly possible without removing the bumper.
Old 02-16-2013, 03:13 PM
Ltmax's Avatar
Ltmax Ltmax is offline
Mein Auto: 2008 750l
Just swapped mine out today on my 07 750i with a set of LED's from BMWLED to get rid of that darn parking light warning on the dash. Bulbs were great quality and cost less than $30.
After getting the front bumper off and the headlights out, it became very clear that since the halo bulb access covers are actually on the bottom of the headlight assembly and not on the the back that it would have been nearly impossible to change them out without pulling the front bumper on the 2006 and up models.
The job only took 45 minutes and using the great instructions posted above made it pretty easy to do.
Thanks!
Old 02-21-2013, 10:42 AM
Mein Auto: 335i
only 2006 and after will need to remove the front bumper, and we have all installation guides via our website already
Old 02-27-2013, 06:54 PM
4Bimmers 4Bimmers is offline
Mein Auto: Z3,X5d,750Li,1200RT&C
Where are the instructions how to drop the bumper?
Will check out mtecv3
Has anyone replaced the fog lights ie the round ones on an 06 750Li
Have a great day enjoying your ultimates
4Bimmers and 2Beemers
Old 03-12-2013, 12:28 AM
Punisher745Li's Avatar
Punisher745Li Punisher745Li is offline
BMW Enthusiast
Mein Auto: 2004 745LI
no need to replace the fog lights, get a slim hid kit they are canbus error free and plug and play no need to cut any wires.....
Old 03-12-2013, 12:30 AM
BMW Enthusiast
Im buying this replacement for my license plate looks really good instead of buying led bulbs, you replace the whole unit...
Old 03-13-2013, 01:45 PM
Piers1989 Piers1989 is offline
Mein Auto: E65 745i
The angel eyes on my car look pretty weired, only the inner circles light up.
SORRY FOR HUGE PICTURES, I EXPECTED THE FORUM TO RESIZE THEM.
Any ideas what's up with this?
Old 03-15-2013, 10:42 PM
Try to re-seat the angel bulbs. It should light both sides up.
2011 535i
2003 745li (Sold)
HID Guide
LED Guide
ABS/DTC Guide
Old 03-16-2013, 08:02 AM
Mein Auto: E65 745i
Had a look pulling a headlamp part way out.
Apparently I don't have angel eyes on my car =/
Where the bulb is supposed to be there is no wire and only solid plastic.
I didn't realize you could order these cars without =[
