Old 11-04-2012, 03:30 AM
albertoxikitin albertoxikitin is offline
Mein Auto: bmw e63
Originally Posted by Bigchagg View Post
Hi tinnox did you manage to find someone n the uk to fit your pipes then??
If so let me know, I want myn doing too.
Hi... Im from Spain and here is very difficult to find some parts for our 6. I bought Xpipe from Summit racing in USA for about 380$ shipped and i installing it for myself...Now it sounds a lil bit F1 with x pipe in the front....but only noticiable when push the gas up..
Old 11-06-2012, 08:37 PM
Realism Realism is offline
Mein Auto: BMW 650i
Fellow 6ers,
After reading this thread IM ALL IN! Lol..
Old 11-13-2012, 11:43 AM
oRIDDLERo oRIDDLERo is offline
Mein Auto: 2006 BMW 650i
What Model number Magna Flow?
I just installed the X-Pipe and bypassed the 3 resonators on my 2006 650i based on this thread.. Thank you all! Great info.
Sound improvement is great, but i want more!
I want to buy 2 Magnaflow mufflers to add on (I hope this will add the "more" I'm looking for)
I need to know the manufacture part numbers for the exact part that fits my car... Can anyone help? Single tip and duel tip would be nice.
Also... How much volume / sound quality will i get out of adding mufflers. considering I have already done the above mod... Is it even worth it, or should i stay with my stock mufflers?
Thanks in advance for the help!
-oRIDDLERo
Old 11-13-2012, 10:39 PM
Yorgi's Avatar
Yorgi Yorgi is offline
The exhaust will be much louder than stock if you install Magnaflows. Personally I think the Magnaflows sound good but they are a bit much for a daily driver.
Here are two threads with part numbers and video clips. The Mangaflow site also has video clips. Note that the Magnaflow site only lists an entire system for the 650i, which you don't need because you've done the resonator delete.
The Magnaflow exhaust thread...
Magnaflow Exhaust just put in This clip is with one of the two resonators removed.
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
Old 11-14-2012, 01:43 PM
Here are two threads with part numbers and video clips. [URL="http://www.magnaflow.com/02product/shopexd.asp?zone=all&id=10165"]
Thanks but all i can find in my searches seems to conflicting information.
For my 2006 650i I'm pretty sure it is either:
Magnaflow part #11366 (Center/Offset)
or
Magnaflow part #11235 (Offset/Offset)
Then i just need the part number for the tips. (Does tip length matter)
I'm usually pretty good with forum/net research, but this is driving me crazy. I just want the part numbers so i can place the order and get this over with! I even called Magnaflow and the guy was unsure (wanted measurements).
Thanks again!
Old 11-20-2012, 01:17 PM
Jon650 Jon650 is offline
Mein Auto: 650i
Very nice. Where did you put the x-pipe - and I presume you kept stock rear mufflers?
Jon
Originally Posted by Mattserati View Post
I would like to pop my head up and say hi. I bought my 650i on Monday, and thanks to this thread, I had the desire and confidence to delete the resonators this morning.
After $200 (AUS) and an hour's wait, I am now driving a super smooth coupe that changes into a barking animal when provoked. Awesome modification - thanks everyone for providing all the info you have in this thread.
In order to give something back, here is a short video of my car post-resonators. Hopefully anyone sitting on the fence will benefit.
Old 11-21-2012, 05:49 PM
Mattserati Mattserati is offline
Mein Auto: BMW 650i
You can see it in the picture I posted - it is right up front where the bullet resonators used to be. My x-pipe was fabricated on site, and it sees both bends come together a bit less than others I have seen, but my understanding is that it will still do the job of equalising pressure between cylinder banks. Either way, it works and sounds good.
Old 11-28-2012, 09:19 AM
Mein Auto: BMW 650i
Just got my resonators deleted! It sound good but I need a little more rumble. Should i go with Flowmaster mufflers or Magnaflow?
Sent from my PC36100 using Bimmer App
2006 650i
Old 11-28-2012, 10:56 AM
I just installed my Magnaflow's after my 3x res delete... and it will get you LOTS more rumble... Like double lol... Crazy.
Here is link for the part you need cheap:
http://www.ebay.com/itm/310481239844...84.m1439.l2649
And the stock tips for them:
http://www.ebay.com/itm/120851613894...84.m1439.l2649
Old 02-03-2013, 03:03 PM
mattymetzger's Avatar
mattymetzger mattymetzger is offline
Mein Auto: BMW 645ci
Has anyone tried to install 2 cutouts just in front of the mufflers? any pros or cons on that mod? would there be even enough room to install a electronic valve.
Old 02-25-2013, 08:00 AM
balkanvt balkanvt is offline
SRM
Mein Auto: '04 645Ci
Originally Posted by funktekk View Post
that's something I like to call the the Bavarian Two Step... if a nice BMW rolls in, knock the price up two steps.
hahahaha that, sir, is as good of a definition as it gets
On a side note, has anyone tried an exhaust combination with M6 mufflers on the 6ers?
I have a 645ci, got my hands on some oem M6 mufflers fairly cheap - mainly because I want to install a M6 rear bumper. Sound should be different IMO - the pipes are bigger, and i'm sure the baffles inside the M mufflers are tuned differently as well.
Old 02-25-2013, 08:02 AM
SRM
don't do it...I tried that with a V6 audi before, two cut-outs right after the headers....thing was louder than a drag car, sounded absolutely fugly, and the drone inside the car will make you get addicted to advil after about 30 min of driving. I really don't see a V8 bimmer be any better
Old 02-25-2013, 03:37 PM
bluers bluers is offline
Mein Auto: 2010 650i
I took the plunge and removed my two round resonators over the weekend with straight pipes. The difference in sound is very very subtle compared to stock. I'm hoping to eventually replace the mufflers to achieve the desire sound. For now, I'll have to settle.
Old 02-25-2013, 05:14 PM
MakaveliFaison's Avatar
MakaveliFaison MakaveliFaison is offline
Mein Auto: Bmw E64/5, Maserati GT
M6 mufflers sound good imo on 650s havent heard it on a 45 but it should bevthe same
650i sport hud ac schnitzer eibach resognator delete m6 quads akebonos
Old 02-25-2013, 07:51 PM
Nitrogen's Avatar
Nitrogen Nitrogen is offline
Mein Auto: BMW 650i Convertible
Ok so all this talk of deleting and removing and changing, but how will this effect emissions testing? Our smog test here in Cali are very strict?
Will they still pass the test after the mods if so I'm gonna do mine too.
Eurowned- did you take an after pics.
thanks!
Sent Via iPhone using BimmerApp
Old 02-25-2013, 11:01 PM
reytran's Avatar
reytran reytran is offline
Nothing quite like a 6
Mein Auto: 09' 650i Cabrio
If you don't touch the cat/ catalytic converter, you will pass smog for sure. Even some catless system can pass the smog (might fail the visual test).
My phone is really bad so the sound record not really show the real sound. If you guys come down to the SoCal meet, I will prove to you guys that 650i can sound so good. The M6 Eisenmann Race is a total different beats compare to Remus or Magnaflow. Magnaflow will give you a brum brum typical new generation muscle car sound. Eisenmann race is another stoy. I'm loving my 6 sound.
2009 BMW 650i Cabrio (daily drive)
2011 Audi A4 (groceries, bully, road trip, winter beater, family car)
BMW CCA ID: 473647
Old 02-26-2013, 09:59 AM
gregb's Avatar
gregb gregb is offline
Mein Auto: 2014 BMW ///M6 vert
Did you also delete the center "box"/resonator and replace it with an X-pipe? Most folks on this thread (including me) took out all three and installed an X-pipe in place of center box. The sound is still subtle but a little louder than just taking out the two resonators, especially at WOT.
Regards, Greg
'14 M6 vert, san marino blue on amaro brown full merino leather, drivers' assistance, exec package, B&O sound system, CCB package, akra exhaust, tint, windscreen, etc.
'07 650i vert, beige/jet black, sports & cold weather pkgs, comfort access, etc.
'11 Acura MDX Advance with Entertainment pkg for wife - no mod's '04 Acura TSX (daughter) and '12 VW GTI - Autobahn (son)
Old 02-26-2013, 10:38 AM
I decided to keep the center resonator box intact in case I wanted to replace the mufflers to keep the noise level down. I was thinking about buying the Eisenman Race exhaust, but I coundn't justify spending $2400 for only the mufflers. Plus, I would want to replace my stock rear bumper cover to a M6 bumper cover for proper fitment of the quad exhaust tips.
On the side note, I really miss the exhaust note from my RS4 with Magnaflow exhaust.
Old 02-26-2013, 11:50 AM
gregb's Avatar
Ok - very little change with deleting just the two front cans. Might get the sound you're looking for if you do mufflers, but the x-pipe is easy, cheap and always reversible - might be worth trying first to see if its enough for you. Good luck.
Regards, Greg
Old 03-02-2013, 04:21 PM
modified my exhaust system today
Today I finally did some work to my exhaust system. I installed two 2 1/2 inch cut outs right in front of the mufflers. Now I can have some "sound" when I'm driving and my wife can switch to the original sound when she is driving. Sounds awesome when idling and still not too loud when hitting the gas.
Name:	2013-03-02 15.18.39.jpg
ID:	364552   Click image for larger version
Name:	2013-03-02 18.23.06.jpg
ID:	364553   Click image for larger version
Name:	2013-03-02 18.28.22.jpg
20" wheels 245/35 - 285/30, black grill and blacked out side markers, 10W white LED angel eyes, Eibach lowering springs on Bilstein shocks,
AC Schnitzer pedals, Sprint Booster (what a waste of money), electronic exhaust cut-outs, red brake calipers (painted)
AFE air intake, door laser BMW logo projector lights, CSR front lip with carbon accents, carbon side skirts
Old 03-03-2013, 04:35 AM
Patton63 Patton63 is offline
Mein Auto: '08 BMW 650i 'vert
Can you post a video/sound clip? I've seen others comment on how loud this type of mod is. Would love to hear what it sounds like.
Old 03-03-2013, 03:27 PM
made a video but the quality is not the best, had to use my cell phone. The sound is better when you hear it with your own ears.
once the weather is better I will make another video with a better camera and some drive-bys
Old 03-03-2013, 03:43 PM
ProRail ProRail is offline
"Clunker" *****
Mein Auto: 1999 BMW 528A-220K-traded
Originally Posted by eurowned View Post
Hi everyone, I currently own a 09 650i convertible
i was thinking going to the shop tomorrow to get the resonator removed and keep the stock exhaust...
will this make the sounder louder? or should i not even bother doing so?
What is a sounder? Do all BMWs have it?
Old 03-03-2013, 03:53 PM
"Clunker" *****
Stock exhaust good. Other exhausts bad.
Old 03-03-2013, 05:19 PM
reytran's Avatar
I did the same xpipe I guess. Your xpipe is Magnaflow right? LOok similar to mine. With the M6 E-Race. Here is my sound clip. From a broken iPhone (low quality)
BMW CCA ID: 473647
