Old 11-13-2012, 02:09 PM
crosby68 crosby68 is offline
Mein Auto: 2006 BMW Z4 M ROADSTER
G force proformance chip
I purchased a G Force Proformance Chip, but have not installed it yet. I can return it. It is for my 2006 Z4 E85 Roadster.
What do you think about these chips, do they work?
The instructions require it be hooked up to the IAT/MAF sensor. I not sure where it is, I know it located after my air cleaner and before the thrittle body. It wants you to peel back the factory and splice in the two wires. not sure if i should mess with it.
Thanks for your help!!!
Old 11-13-2012, 04:42 PM
Blacklane Blacklane is offline
Mein Auto: 1998 Z3 Roadster
Near the top of the page on the right is a button labeled "Search this Forum." It can be your friend. Most recent posting on G Force was this one:
http://www.bimmerfest.com/forums/sho...d.php?t=619690
Old 11-14-2012, 04:29 AM
Mikey48 Mikey48 is offline
Mein Auto: BMW Z4 3.0
Be very careful messing with your that IAF/MAF sensor that is a $500.00 sensor you are messing with ! If you drop it or hit it hard it will die ! Good luck.
Old 11-14-2012, 08:18 AM
Thanks for all your input. I am going to send the chip back for a refund.
Old 11-14-2012, 12:19 PM
wifesauto wifesauto is offline
Mein Auto: sloporsche
what made you buy it in the first place ?
Old 11-14-2012, 02:17 PM
I guess the better gas milage and who does'nt want more horse power.
Old 11-14-2012, 02:40 PM
you DO NOT get better mpg AND more power
Old 11-14-2012, 03:21 PM
Wertles Wertles is offline
Yoda with a library card
Mein Auto: 1999 M Coupe
Only happens in the turbo diesel world. I gained 75 hp, 150 ft lbs of torque, and 3 mpg all while running cooler. All we had to do was change the timing and duration of the injectors. I wish it were that easy and effective with the Z's.
1999 Boston Green M Coupe
2002 Z3 2.5 Automatic Roadster
2013 Ram 3500 Crew Cab Dually, 850 ft/lbs torque, stock and staying that way
1995 318i spray paint red, 170,000 miles and climbing
