G force proformance chip
I purchased a G Force Proformance Chip, but have not installed it yet. I can return it. It is for my 2006 Z4 E85 Roadster.
What do you think about these chips, do they work? The instructions require it be hooked up to the IAT/MAF sensor. I not sure where it is, I know it located after my air cleaner and before the thrittle body. It wants you to peel back the factory and splice in the two wires. not sure if i should mess with it. Thanks for your help!!! |
Near the top of the page on the right is a button labeled "Search this Forum." It can be your friend. Most recent posting on G Force was this one:
http://www.bimmerfest.com/forums/sho...d.php?t=619690 |
Be very careful messing with your that IAF/MAF sensor that is a $500.00 sensor you are messing with ! If you drop it or hit it hard it will die ! Good luck.
Thanks for all your input. I am going to send the chip back for a refund.
what made you buy it in the first place ?
I guess the better gas milage and who does'nt want more horse power.
you DO NOT get better mpg AND more power
Only happens in the turbo diesel world. I gained 75 hp, 150 ft lbs of torque, and 3 mpg all while running cooler. All we had to do was change the timing and duration of the injectors. I wish it were that easy and effective with the Z's.
1999 Boston Green M Coupe 2002 Z3 2.5 Automatic Roadster 2006 Inferno Red Ram 3500 MegaCab 3500 2010 Rescue Green 2 door Wrangler Mountain Edition |
