E30 (1982 - 1993)
Zf 4 hp22
Hey guys, so i'm picking up the 86 325 next weekend but the tranny has a gigantic leak (main seal i think). the guy I'm buying it from said that he has a getrag 260 off a '91 but i was told that the later 260s dont have a CPS port that is necessary on the 86.
So then my next idea was just to take the transmission out, have a shop replace the seals and throw it back in and use it like that. Now i'm thinking, I can probably find a good running usable transmission to just swap in and trash the leaky old one or trade it for pudding cup or something. A replacement would be much cheaper than having a shop replace seals and I could do it all same-day. (If any of you guys have one that'd be sweet t*tties) I dont have the time or funds at the moment for the manual swap, but when I do the motor swap, i'll do the manual conversion then. Now heres the question. Does any model year ZF4 HP22 transmission fit the car? Or is it the same issue as the manual box on the 86. Will i need an 86 auto tranny? My reasoning is that if the CPS is at the flywheel, both the autos and manuals will need that port, that wouldnt be found in later year transmissions. Thanks!
![]() 1995 525iA 250k mi Shifted Performance E34 2006 325i/6 48k mi 2003 350Z 87k mi Shifted Performance 350Z Garden State Euros Last edited by Monsignor; 05-12-2012 at 08:23 AM. |
So to recap any E30 eta manual should work post 86 and I bet the ones in the 528e e28's are the same too.
![]() Last edited by SWISS; 05-12-2012 at 11:24 AM. |
1) im looking to simply replace the automatic with a non leaky one. does it have to be an 86? or would any one fit. I've heard about CPSs being at the flywheel so would i need to find one with the proper CPS port. 2) i'm not looking to modify or relocate the CPS in any way. I want a stock daily until I can do the motor swap. I want to put the same exact trans in it thats in it now. Its an auto now with a main seal leak. Would any year work? or must it be an 86 auto? I appreciate the help!!
![]() 1995 525iA 250k mi Shifted Performance E34 2006 325i/6 48k mi 2003 350Z 87k mi Shifted Performance 350Z Garden State Euros |
Protip- When pulling trans use a pry bar to seperate the torque converter from the flywheel after you unbolt the 3 bolts if it doesn't just come apart. DO NOT LET THE CONVERTER COME OFF THE TRANNY! IT WILL NEVER WORK RIGHT AGAIN!
Excellent. Much obliged. Should I find a replacement tranny with a torque converter in it?
So yes, if the tranny doesn't have a converter on it, walk away.
the main seals need replacing. It's pouring fluid out. Should i just remove the trans, bring it to a shop and have them fix the seals and reinstall torque converter and i'll just bolt it back up?
if you dont mind getting dirty, just do it yourself, itll be cheaper then taking it to a shop. 14-20 bucks for the seal at Oriellys or around 4.50 on pelican parts sorry no link but yea check it i had the same problem on my e30
Just change the seal(s) and ask a trans shop about the torque converter installation (buy trans fluid from them to sweeten them up). You've done the hard work, grab the glory.
