Old 11-13-2012, 12:55 PM
mike.k mike.k is offline
Mein Auto: x5
2011 X5: Windshield repair or replacement in NYC
Hi everyone,
Was wondering if you guys can please recommend the best method for repair or replacement(if needed) for an X5 2011. Automatic rain detection is included. Uncertain if it's UV glass.
Have filed a claim with insurance. They will cover the bill but not if the dealer does the repair. It was suggested I try to find out if the repair will be outsourced and then call that shop. If someone knows of a shop that they used and were happy with their service... can install OE(is OEM good enough?) glass and install new seals, that would be very appreciated.
Thanks a bunch!
p.s.
I'm tempted to buff out the scratches myself but would rather not. Long story. A call to safelite and they suggested replacement.
Old 11-13-2012, 01:08 PM
Brian425 Brian425 is offline
Mein Auto: BMW X5 50i
I have dealt with Safelite on a few different cars and trucks. I have never had a problem. I use the one on 18th Ave between 86th and Bath Ave.
Old 11-13-2012, 02:17 PM
ard ard is offline
Resident Curmudgeon
Safelite is the lowest cost, lowest quality product when it comes to glass. Everyone uses them. They have driven the cost down to nothing, which is WHY all the isnurers love them.
You will have someone hack out the old glass then glue in a new glass and stick the trim around it...all held in place with their proprietray goop.
They will NOT follow manufacturers recommended methods and CANNOT tell you the installed window will still result in a CAR that meets mfg specs. Yes, their GLUE is approved...but their methods are not. I had an insurer that was insisting I used them, and when safelite refused to state the installed window would retain the mfg's ratings, the insurnace allowed me to choose the shop
Also, recognize that OEM is not OE glass. And it is not, necessarily, 'just the logo'.
YMMV
A
PS If the scratch is NOT very noticeable, I'd just wait until winter is over- OR you get nailed with a rock
Old 11-13-2012, 06:09 PM
AutoUnion's Avatar
AutoUnion AutoUnion is online now
Mein Auto: '11 X5d
Do you have rain sensor/HUD, etc? If so, then maybe push for your dealer for the replacement.
2011 BMW X5 xDrive 35d Vermillion Red Metallic/Black Nevada Leather
Options: ZCW, ZPP, ZRC, ZTP, 300, 386, 496, 4AB, 6FL, Combox, LED Coronas. 04/11 Production
Old 11-14-2012, 07:15 AM
Mein Auto: x5
Thank you.
Yes to the rain sensor no to the HUD. The little parallel scratches are in the field of view. Just a reminder of the mess of the past few weeks. Maybe I'll learn to love them
I'll push for OE glass if replacement is required. I'll have the dealer look at it? and see if they can buff it out and then direct me to a shop.
Old 11-14-2012, 07:25 AM
gresch's Avatar
gresch gresch is offline
Don't be a hammer
You should be able to pick the shop of your choice, that being said, many BMW dealers in NY outsource their glass replacement to a non-bmw shop, make sure you ask. if you get stuck with Safelite, you can demand OEM glass instead of the safelite equivalent, it will just cost more.
Old 11-14-2012, 09:00 AM
smyles smyles is offline
Mein Auto: X5
Original BMW glass may be the priciest, but it doesn't translate into the best quality.
Old 11-14-2012, 11:09 AM
ard ard is offline
Resident Curmudgeon
Interesting.
Are you saying OE is the same as ALL OEMs (st. gobain, etc)??
or are you saying it is actually worse?
And if you are saying 'the same' is it 'always the same', hence as a policy you can just buy OEM and always get the perfect fit?
I have heard that OE tolerances are tighter ... this may simply be rumor and anecdotes, as there really is no good data on this... but let us know what you know.
A
Old 11-14-2012, 12:00 PM
Mein Auto: X5
Look at your original glass. Most likely you'll see distortion along the bottom edge, as well as vertical distortion if you look from a side. It's because original glass is no better, and often actually worse than aftermarket options. No idea why, but I'd imagine cost is involved, just like with the wheels, for example...
Old 11-14-2012, 12:53 PM
ard ard is offline
Resident Curmudgeon
Wait, are you one that has decided that OE wheels are always expensive because they have the "Stealer Tax" built in, and the cheap aftermarket clones are the same quality but simply cheaper?
My OE glasses- 3 BMWs, a Porsche and an Acura seem pretty optically OK....
http://www.windshield-repair-forum.c...php?f=9&t=4172
Another interesting one...albeit with their own agenda. Interesting discussion of stress and QC with a polariscope:
http://www.ultrabond.com/whywindshields.pdf
^Quite interesting to read about the cost control/politics and Lynx Services place in the whole thing...
Old 11-14-2012, 01:52 PM
CALLAWAY845 CALLAWAY845 is offline
Mein Auto: 2007 x5 3.0...2009 328i
Thank you, ARD. That last article is quite eye-opening on quite a few issues. The author definately has an axe to grind, but it is still worth reading.
Old 11-14-2012, 01:59 PM
Originally Posted by mike.k View Post
Hi everyone,
Thanks a bunch!
p.s.
The key with dealing with the insurance company/glass adjuster is don't let them tie you up in semantics. The terms OE and OEM are very confusing, and mean different things to different people. When I had my windshield replaced, I was ready to order the windshield myself from Tischer, and get reimbursed. They ended up approving factory glass (the same glass new x5's are married with in SC), so I did not need to pursue this option any further.
Old 11-14-2012, 05:10 PM
Mein Auto: X5
If you can't see imperfections in your windshields, it doesn't necessarily prove they're not there. BMW has more than glass supplier, incl. from China, so your thesis about OE/OEM suppliers with super-duper quality standards may be a nice theory, but in reality it's more of a pipe dream.
And if you believe original wheels are the best and no better AND cheaper alternatives can be found, then all I can say is LOL.
