Old 11-12-2012, 10:38 AM
twowheelin twowheelin is offline
Mein Auto: BMW 328i Conv, Volvo S60
Replacement exhaust tips?
Greetings! New member here and very happy to find such a knowledgable community here on the web. We recently purchased an 09 328i convertible and really enjoy the feel of the this car!! While doing some detail work this weekend, I noticed one of the twin exhaust tips was damaged. It looks like the lower lip of the D.S. tip is pushed forward about 1/2". Fortunately the actual pipe is fine and not even scratched. Is anyone familiar with how the tips are mounted and if replacements are available? I'll get a pic of the tip posted asap. Here is our new addition!
Any ideas or pointers appreciated!
Old 11-12-2012, 12:34 PM
SD ///M4's Avatar
SD ///M4 SD ///M4 is offline
(prev. SD335is & SDZ4MR)
Mein Auto: 2016 M4 Coupe | 2006 Z4MR
BMW exhaust tips are usually snap riveted. The rivets need to be drilled out and removed then the exhaust tip can be pulled off. The muffler will need to be dropped or removed to get to all of the rivets. The replacement tips can be sourced from number of places, both OEM and aftermarket. The replacement tip is then secured with new snap rivets.
A muffler shop may be able to do this for you.
- Tom
His: 2016 M4 Coupe | Sakhir Orange Metallic | Black Full Merino Leather | CF Trim | M DCT | Adaptive M Suspension | 19" Black Alloy Wheels | ZEC | ZLP | ZDB | MPE | ED 5/13/16
Hers: 2011 335is Couipe | Le Mans Blue Metallic | Black Dakota Leather | Dark Glacier Aluminum | 6MT | ED 5/12/11
Also His: 2006 Z4 Roadster (E85) | Interlagos Blue Metallic | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12
Old 11-12-2012, 01:29 PM
Thanks for the quick rely. I've been digging around and it looks like removing the muffler or at least dropping it down is a must. I'll look a little closer at the muffler tonight to see what the attachments look like and what I'll need to do to get a drill onto the rivets.
Old 11-12-2012, 01:59 PM
ModBargains.com's Avatar
ModBargains.com ModBargains.com is offline
Mein Auto: E92 335i, F82 M4
This may be a good time to upgrade the exhaust as an alternative solution. I'd recommend that you check out the Rogue Engineering IKON Exhaust for the BMW E90/92 325i/328i/330i. It's one of the more affordable setups out there and it'll improve the sound and performance on the car!
Alan Wei | Alan@ModBargains.com | (714) 582-3330 ext. 8006
We Specialize In: BMW M3 Wheels | BMW Brakes | BMW Suspension | BMW M3 Parts | VMR Wheels |
Remus Exhaust | HRE FlowForm
Hours: Mon - Fri 8:00am-6:00pm | Sat 8:00am-5:00pm
Check out the Blog for daily updates!
Old 11-12-2012, 02:02 PM
tturedraider's Avatar
Freedom isn't free!!
There's a very good chance the tip is held in place by nothing more than friction, a tight fit. You may be able to reposition the tip with just a little force and elbow grease. Good luck. Congrats on your car and welcome to the 'fest.
www.bmwcca.org
Old 11-12-2012, 04:11 PM
roadkillrob roadkillrob is offline
Mein Auto: 325CIC, 335CIC
They used to be just friction on the single sided exhaust cars - you could just pull really hard and they would come off and replacements are about $35, not sure if they started attaching them more permanently in the last few years or not.
2008 335i Vert Montego/Saddle/Grey Poplar
2013 Mercedes C63 AMG Obsidian Black/Black
2016 X5 M-Sport Mineral White/Mocha Design Package/Fineline Oak
Old 11-14-2012, 05:21 PM
R608 R608 is offline
Mein Auto: '11 328i M-Sport (6MT)
My '06 didn't come with exhaust tips. I ordered a pair and they probably would have stayed on purely from friction (I had to actually heat them up to get them on at all), but they included a screw on the bottom to help ensure they stay put once installed. Not sure if BMW is actually riveting them on now for some reason, but check the underside of each tip, up near the front, for a simple philips screw before you get too far.
Old 11-14-2012, 06:26 PM
texdrake's Avatar
texdrake texdrake is offline
Mein Auto: 328xi
I have a 2011 and its heldon by a friction clip, as are all 328 LCI's. just pull real hard
Texdrake
2011 328xi Sedan - DSB / Chestnut / Aluminum / Auto / Value / Premium / Xenon / Sat / Split Rear Seats
M3 Lip Spoiler / LUX V3 / Aluminum Pedals & E-Brake / Interior LED / Xenesis H8 & H3 / LED side markers
Clear Side Reflectors / DSB painted calipers / Cyba black scoops / Tint / Powder black grille & exhaust tips
Future Mods: VMR V710 18x8.5" Gunmetal rims
Old 11-14-2012, 06:37 PM
schnecharl schnecharl is offline
pending
Send a message via ICQ to schnecharl
Mein Auto: bmw
The rivets need to be drilled out and removed then the exhaust tip can be pulled off. [img]*****************ca3[/img]
Old 11-14-2012, 10:42 PM
Wihelm G Wihelm G is offline
California Über Alles
Mein Auto: 328CiC and 328iT
Yes
No
Rust and spring clips hold them on. To remove OE exhaust tips, a few light taps on a piece of wood positioned at the rear of each tip will loosen them up enough to pull out by hand.
