E36 (1991 - 1999)
Old 11-14-2012, 07:37 AM
joepizz1 joepizz1 is offline
Mein Auto: 318is
Exclamation Problems 318is
Hi
i have a e36 318is 1998. 1st is my car mis fires at high rpm and seems to hit a rev limiter, i've replaced all the spark plugs but it makes no difference???? 2nd is my traction control doesn't work, i have replaced the traction control button and again makes no difference??? 3rd is everytime i plug my alarm in it won't stop going off??? anyone else had these problems?? Oh and the passenger door has packed up and will only open from inside any ideas?
Old 11-14-2012, 07:48 AM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
1. Your car has a rev limiter. It is at fairly high RPM. Are you hitting it?
2. What plugs did you use? (Aside from that, if you replaced them and it changed nothing, then they weren't the underlying issue).
3. How is replacing the ATC button supposed to 'fix' the ATC not working?
4. What is the ATC doing to be 'not working'?
5. Brand of alarm? What is the voltage of your battery with the car off? With the car running?
6. You're gonna have a blast replacing that door handle. On coupe's they're a bitch.
Originally Posted by hnaz View Post
I grew up in a time when the internet was just a baby. Grammar back then versus now... holy cow. You could watch the degradation of society as the internet became more mature.
HAS KEN HAD HIS MEDS YET?
Old 11-14-2012, 08:08 AM
Mein Auto: 318is
it usally revs up to 6 and a half. 5,500 at the moment just speaking to another form he said it was the abs sensor
The plugs boash
well maybe the traction control button may have shorted out. its nice without traction but its not good going everywhere side ways. The traction light on the dash wont go off?
factory fitted alarm and i dont know how can i test the voltage?
cheers for the heads up on the door dude
Old 11-14-2012, 06:29 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
trac light is on because it sees a fault in the system, so it is disengaged.
a dvom will be ok to check voltages.
df
