E30 (1982 - 1993)
Old 11-14-2012, 04:44 PM
WickedFast.Inc WickedFast.Inc is offline
Go Fast or Go Home
Mein Auto: 1989 325I
Re-assurance
First off is it normal that when i put my car in drive it pushes the back end down and in reverse lifts it up i know there is a bit of torque to these cars so i figure checking wouldnt be a bad idea
Second i have an dc to ac converter and hooked to it a small amp i have set up (its properly wired trust me on this) yet when plugged in my cars rpms will sometimes although rare drop to zero and kill my car now its only when plugged in it did it about 5 min ago and i unplugged it my car rolled about 5 feet and the rmps returned to normal. Any thoughts besides the alternator being weak i cant think of why it would cause this but even with a weak alternator i figure it shouldnt shut my car down
Wicked Fast Entertainment
Old 11-14-2012, 06:01 PM
markseven markseven is offline
an audience of One
Mein Auto: Go Kart with AC
  1. Normal
  2. I would imagine an inverter is too much of a draw on a brand new alternator. The car audio guys can prolly shed light on what sort of alternator is needed.
Old 11-14-2012, 06:27 PM
downhiller's Avatar
livin large
what mark said. these only have a 90 amp alternator or at least that was one option when i changed mine out
Old 11-14-2012, 06:28 PM
Go Fast or Go Home
If in fact it was the inverter would hooking my setup straight to the battery with a remote switch to accomidate on off so not to kill my battery it should stop. So if it does not im looking at a weak alternator ?
Old 11-14-2012, 06:29 PM
Go Fast or Go Home
How big of an alternator do they make for this car
Old 11-14-2012, 06:33 PM
downhiller's Avatar
livin large
question 1 from me, what the hell kinda amp do you have that needs to have a converter? all the ones ive dealt with you run one wire to the negative terminal, and run the positive through a power cap then to the amp.
Old 11-14-2012, 06:41 PM
an audience of One
Marshall?
Old 11-14-2012, 08:29 PM
Go Fast or Go Home
There is a short story for that when i traded for the car he gave me a headunit for it which i tested (i have pretty good knowledge of electronics)
It was bad so i dont have one
I made a mini stereo you hook up your phone or ipod to the amp the amp powers two speakers an 8 inch sub and 6 inch bose
Powered by a 12v. Dc laptop charger plugs into a wall for music anywhere
:/ its all i have for music in my car
But it plugs into ac converts 12 v dc and since i have yet to rig it to my battery and hook up a switch i plug it into the inverter running from the cig lighter
Old 11-14-2012, 09:05 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x2,E30x1, F150
All that up-and-down converting to simply play music in the car is sort of like going 'round your arse to scratch your elbow, isn't it?
Ditch the converter and wall plug and power it with 12 VDC. If you have time to do all that fiddly nonsense with the converter/wall wart, you can surely find time to simplify it.
And, yes, if the system is loading that much with the converter/power supply/amp that it dims the lights or even kills the engine, the alternator is on it's last legs. Get it tested BEFORE it strands you. Battery, too. Get it load tested, not simply voltage tested. There is a difference.
Quotes to live by:
Ken Kanne, Silverhill, AL, E36 & New Member Intro Forum Mod/Bimmerfest Misplaced-Posting Tow Truck
BMW-CCA #441426 Which is worse, ignorance or apathy? I don't know, and I don't care!
1995 318is "Bebe"; 1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette"
Old 11-15-2012, 12:22 AM
BMWFatherFigure's Avatar
Old School
+1 on all above.
Current:
E38 Parts Car
Previous:
Old 11-17-2012, 09:34 AM
Go Fast or Go Home
Ill look into that but the reason it has a wall wart is because its for parties and such for music i didnt origionally plan on putting it in my car i just thought of it one day the inverter is just so i dont have to unwire the power supply and rewire it later
Old 11-19-2012, 01:29 AM
Nick323's Avatar
Nick323 Nick323 is offline
Nick's Toys
Mein Auto: 323i E30 2-door
Thumbs down Transformers in cars
I put a 13.6v power supply in my Land Cruiser, so I can charge the battery as well as run the fridge should I stop at a camping site on my travels.
Then I put in a 150 W inverter, so I can charge the camera batteries, cellphone etc. in the bush.
Both are swiching and not Transformer converters and I still have "noise" in the system
This noise does interfere with crank trigger signals etc.
If you have a old type Oscilloscope float the probe near your wires and
If you want the Disco set-up at parties, I would make sure that all automotive electroncs WILL be switched off !
Simply put, you have so manny coils working of induction in your vehicle (Ignition,Injectors, triggers etc.) you do not want to wreck their output or input signals
Don't take life too seriously; no one gets out alive !
1984 323 currently being resurrected from the ashes
Old 01-16-2013, 07:13 PM
BigBoy740il's Avatar
BigBoy740il BigBoy740il is offline
Mein Auto: 1989 E30; 2000 E38; GS350
Listen... Ditch the house amp and get an amplifier designed for 12V applications. The DC/AC convertion is impractical as well as inefficient use of power.
Big Boyz with Bad Toyz.
