Old 11-13-2012, 02:17 PM
745iguy's Avatar
745iguy 745iguy is online now
Besessen Deutsch Autos
Mein Auto: 2006 X5 3.0
i figured thats what it is. if i develop this problem i will probably go to AGA it looks like its alot more reliable and sturdy, URO uses alot of o rings as u mentioned and IMO looks kinda thin an flimsy, OEM well idk if theyre doing this already i would rather try an aftermarket solution rather than create the same problem again, i never looked into bimmer pipe but im sure theyre all better than stock design.
06 X5 3.0 Toledo Blue Metallic/Light Beige 2:
Adaptive Xenon Headlamps, Panoramic Sunroof, Rear Sunshades,
+Factory Aux Input in Ashtray, Bluetooth, Rear PDC Sensors, Rear Electronic Adjustable Seat Backs,
+White Angel Eye LEDs, +4300K Foglight HIDs, +Blacked Out Chrome Grill Surround, +Puddle Light Logo Projector
.. more updates to come
PREVIOUS 2002 745i
Old 11-13-2012, 07:12 PM
Khabar Khabar is offline
Mein Auto: 745i 2005
Pipe is pipe. it is metal. The problem is a robber ring on the end of pipe.
Old 11-13-2012, 11:03 PM
cmpcpro cmpcpro is offline
Mein Auto: Nothing
Originally Posted by D4T_POM View Post
Cmpcpro,
If you see a link which khabar posted you can see what the process is.
He posted it above
Sent from my GT-N7100 using Bimmer App
Thanks! I read thru the whole thing.. funny you got your leak at 129k.. I just bought my car at 129k and just hit 130k.. how did you tell you had the weep hole leak? I will read up on it soon.. I know the dealer did the water pump, and they had the car for over a week.. is there a clear way to tell if my coolant pipe has been replaced? I did notice on the pass side head there is a splotch of white paint, I wonder if that means something was done to it.. wish I could tell what was done to what..
Old 11-14-2012, 10:34 AM
D4T_POM's Avatar
D4T_POM D4T_POM is offline
Mein Auto: 2002 E66 745Li
Lol you can see it dripping from next to the water pump....plus have to fill up coolant everyday and lately became worse.
Old 11-14-2012, 11:37 AM
Mein Auto: Nothing
Ah thanks, I just checked around there lastnight and all was dry.. it actually looks very clean all around there.. and the water pump is clearly new.. so hopefully I have some time..
Old 11-14-2012, 01:24 PM
D4T_POM's Avatar
Hopefully it dont happen to you as its not a nice feeling to know you have a coolant leak
Old 11-14-2012, 07:11 PM
bigSystems bigSystems is offline
Mein Auto: 2005 745Li
Hi Guys,
Just wanted to ask, I recently got the weep hole leak on my car (02' 745Li -129,000) and was wondering can i fix the weep hole without changing the water pump gasket?
I will buy everything needed i.e the Collapsible Pipe, Gaskets, O - Rings and other parts. But just wanted to get away with opening the fan, water pump, pulley and etc.
Sent from my GT-I9300 using Bimmer App
Are those Kahn rims on your car?
Fully Loaded 7
Microsoft SQL Business Intelligence Expert
Old 11-15-2012, 03:32 AM
D4T_POM's Avatar
Yep
Old 11-16-2012, 04:32 PM
D4T_POM's Avatar
Will be doing the weep hole fix tomorrow.
Wish me luck lol
Old 11-17-2012, 01:16 AM
D4T_POM's Avatar
Khabar quick question, do I have to use 12 new bolts for the valley pan or can I use the old ones?
Reason I ask is because my stupid Local BMW forgot to put the bolts when they sent the package out to me
Old 11-17-2012, 03:58 AM
D4T_POM's Avatar
On the process
Old 11-17-2012, 03:59 AM
D4T_POM's Avatar
Old 11-17-2012, 02:53 PM
D4T_POM's Avatar
Finished atlast, run the car for 5 minutes no coolant leaking
Going to have a shower then take her for a run then park her outside and see how it goes.
Old 11-19-2012, 01:49 AM
allaboutdaz allaboutdaz is offline
Send a message via AIM to allaboutdaz Send a message via Yahoo to allaboutdaz
Mein Auto: 745
Good stuff man!
BMW 7
Honda S2000
Nissan 300zx TT
SuperDuty F350
Suzuki GSXR 1000
Old 11-19-2012, 07:10 AM
D4T_POM's Avatar
Originally Posted by allaboutdaz View Post
Good stuff man!
Thanks buddy
Old 11-19-2012, 09:26 AM
Mein Auto: Nothing
Thanks for pics but is everyones motor this dirty/weathered? When I look at my block it looks brand new.. heads everything.. you can read any of the numbers on anything.. and I know someone hasn't cleaned it because there is crud built up on the shock towers and a couple small spots..
Old 11-19-2012, 02:17 PM
D4T_POM's Avatar
Lol I know but will clean it next weekend as after I put the pipe in my body was aching lol
Old 11-19-2012, 03:44 PM
stuartjohn24 stuartjohn24 is offline
Mein Auto: BMW E65 745i
Nice work! How long did it take you in total?
I got in the car on Sunday morning, got the 'Low Coolant Level' warning on the dash, checked the reservoir and it was dry!
Ive never had to top off the coolant in the 20 months ive owned it, (although I did replace the thermostat and refill the coolant 8 months ago). I checked the coolant literally 5 days ago because I could smell coolant when walking past the front of the car after driving and parking up. Level looked fine just between the MIN and MAX level.
I managed to have a look at the weep hole and it looks dry, with no sign of previous leakage (water marks etc...).
I cant see any leakage anywhere else, the under tray is dry.
Either I have a slow leak somewhere so its evaporating before it drips or perhaps the head gasket is leaking?
It took around a pint and a half to bring it back up to the MIN mark.
How much water were you losing? could it be evaporating in the void behind the weep hole and i wont see it overflowing until it gets worse?
Im stripping the engine to the block after xmas and have already bought the OEM pipe just in case! I will have the timing chain covers off anyway so will change it as a matter of course.
Stuart
Old 11-19-2012, 05:11 PM
D4T_POM's Avatar
Stuart
Stuart,
I started at 10am and finished around about 8-9pm including the runs to screwfix and halfords to pick up the reciprocating saw and T connector and lunch, tea and *** breaks lol, so in total about 9 hours.
I had very obvious leaking through the weep hole as when it would poyr down the bottom you could see it coming from the weep hole on the water pump.
Now its bone dry, but did get a shock of my life when I woke up today and turned the car on and it said coolant low first thing that popped into my mind was head gasket lol.... then I remembered I didnt properly top her up after I put i changed the coolant pipe and didnt really run her in properly for the coolant to ciculate the system for me to top her up with the final drops.
Even then I checked for bubbles in my expansion tank, milky substance on the oil, white smoke from exhaust and lastly my car never over heated on me once. (Touch wood it dont start happening now)
So far so good, also changed my emmissions pipe which was broken off the drivers side valve, now I dont get the rough idle during the morning which I used to get as well as the emmssions fault code.
Also with your car I would check the hoses, my hose from the water pump to the radiator to the alternator was completely dissintigrated on the T connection which in turn was leaking, once I was fixing that I realised I had coolant leaking from next to the water pump but it was ok until it literally started pouring heavily from the hole.
The n62 is a beautiful V8 but its a shame with beauty comes the beast of all headaches to maintain the V8.
Old 11-19-2012, 05:15 PM
D4T_POM's Avatar
Also you might be rite about the void behind the hole as mine didnt use to pour at first until it became abvious when changing the pipe/hose.
Old 11-19-2012, 11:35 PM
Mein Auto: Nothing
So your secondary air pipe was broken on drivers side? And that was causing a rough idle at cold? How long was the rough idle when cold? Thanks for all the help!!
Old 11-19-2012, 11:53 PM
Thanks D4T_POM,
Thats pretty good going! Yeah my weep hole looks dry....for now ha ha! I dont have any water in the oil, or any noticeable white smoke. (thats if you can really tell with all the oil its burning!).
I will keep an eye on it this week.
Thats good, I have secondary air fault too on bank 2, I expect its either the pipe cracked, valve or cylinder head blocked.
Yeah I agree! the V8 is great but maintenance and running cost is high, luckily like yourself I do all the work myself, im still looking at £1200 parts and the 7 in the garage for a month though!
Old 11-20-2012, 04:05 AM
D4T_POM's Avatar
Thanks D4T_POM,
Stuart,
Most likely its your 'Y' pipe that connects to the 2 mushroom like valves below and behind the intake manifold that has broken off the stupid connectors BMW use, they where a pain to take off, especially the ones on the front of the intake manifold considering I did not want to break them for resuse purposes.
Also good luck with the work Stuart, after I put everything back on, my whole body was in pain due to putting myself through different positions to get everything off lol but it was well worth it.
If I was closer to you I would have given you a helping hand when you do the work
Im thinking of buying an engine hoist so I can use it to change my friends engine on a Peugeot 307 as he was so wise while changing his glow plugs he snapped them causing him to need a recon engine also the hoist will come in handy in the future.
A month in the garage? Hope you have another run around as when I didnt drive my 7er for 2 weeks while getting the AGA pipe and other parts ready I felt embaressed to use public transport
Let me know how it goes
Old 11-20-2012, 04:17 AM
D4T_POM's Avatar
Cmpcpro,
Yeh my secondary air pipe was broken which was causing the rough idling every morning when I would start my car for atleast 3-5 minutes, I cant remember the code exactly, I think it was p0491, p0492 and p0431 or something like that lol
Now I dont get a rough idle in the morning
Below is a picture which shows where it actually broke off from (not my picture, someone elses picture who had the same problem and fault codes). you can see on the second picture where it actually breaks off from, funny how BMW use such cheap parts on their flagship car
Not only that, the T connectors on their hoses actually DISSINTIGRATE which makes you wonder 'WHAT THE F***K'
Name:	Secondary Air Pipe.jpg
ID:	350200   Click image for larger version
Name:	Secondary Air Pipe 2.jpg
Old 11-20-2012, 04:32 AM
D4T_POM's Avatar
Also another thing to remember is when a car dealership say 'our cars would last you a lifetime' what they actually meant is 'lifetime in our term is 100,000 miles'
