E60 (2004 - 2010)
BMW 5-Series (E60 chassis) was first seen in the Unites States in the fall of 2003 with a 2004 Model Year designation. The E60 is now available as a 528i, 528xi, 535i, 535xi, 550i and a 535xi sports wagon! -- View the E60 Wiki |
How to: ZF 6HP26 Mechatronics Solenoid Replacement / Valve body removal
Here is a quick video I did on removing the valve body/mechatronics on my E60 yesterday. I ran out of space on my memory card before I finished so there's not any video of it going back together, but it's pretty much just reverse from coming out.
Instead of replacing the whole valve body / mechatronics assembly, I replaced just the solenoids and it completely fixed all of my issues (slow shifting to reverse, rough shifts everywhere, jerky shifts 5 to 6 and 3 to 2 especially, hiccup in 5th, etc. etc.) Hopefully this will help someone.. It appears most E60 owners do not do as much DIY on this kind of thing as me. Let me know if any questions. Hopefully this saves someone some money! Also, about 3/4 of the way through the video it keeps stopping for me and acting like it's the end. It isn't, so make sure to watch the end. Wish I could have gotten more detail on changing solenoids and re-installation, but I'm not doing it again for the sake of a video ![]() Last edited by schpenxel; 10-28-2012 at 01:45 PM. |
Thats diving right in. Thanks for sharing the Diy.
I've been experiencing the slow shift into reverse as well. I'm going to have my guy take a look at your video and see if he could do just that instead of changing out the entire valve body unit in my transmission of my 2004 545i.
No problem! It wouldn't have been so bad if I had had another car to drive if I messed something up, lol. But this is my only car right now. No pressure
Make sure you get enough fluid and make sure to reset everything in INPA so it can re-calibrate to the new solenoids. The accelerator to the floor for 30 second thing never did squat for me. I had 7 quarts of new fluid on hand and it wasn't enough. I had to use a quart or so of the old stuff (which had been changed a few weeks ago so it wasn't so bad) to finish filling it up. Last edited by schpenxel; 10-28-2012 at 05:27 PM. |
You are the man
. Question, apart from resetting INPA was there any other recoding required from $ealership? My local indy has told me if the solenoids are changed, it would need recoding.Also, in your video I could not see how did you remove the sealinng sleeve. If you remove the valve body, do you have to pull the sealing sleeve from outside the transmission body or just disconnecting the wiring harness is enough and the sealing sleeve just comes out along with the valve body. Sent from my Android Bug
Sorry, after I stripped that pan bolt I forgot about the video for a bit. Yes, you have to remove the sleeve. It was so cramped up in that area, that I actually couldn't get it completely out of the car--I could only get it out of the transmission then just left it up in the car wherever it was and called it a day. There's a transmission mount at the rear of the tranny that if I could have removed, I think I could have gotten the sleeve out. I didn't have female star sockets on hand though so I couldn't get it out, but to answer your question, YES it has to come out. |
Very cool Thanks!!
where did you get the solenoids from? What's part number?
http://www.thectsc.com/index.php?p=p...d=36&parent=52 is where I got them for mine. Email them if you're unsure which to buy.
Basically there's a retainer plate (you can see it in one of the pictures towards the end of the video, that has maybe 8 screws on it and runs the length of the solenoids. That is all that holds the solenoids in. The solenoids have o-rings on them that seal pretty tight to the holes they are in, so it takes a bit of a yank to get them out, but ultimately that's it. They don't screw into the valve body or anything like that I wish I could have gotten a good video of swapping them--that was the part I wanted to record the most but I ran my memory card full on accident unfortunately. I found a video on youtube that shows disassembly of a very similar mechatronics unit (maybe the 5HP or something like that?). I'll post it when I find it. Here it is (below) Note that the wiring harness doesn't really exist on the 6HP. It's a big plastic piece with connectors that line right up to the connectors on the solenoids, so that part is nothing like it. But removing the actual solenoids is the same. And obviously ignore the whole taking the valve body apart part--no need to do that to change solenoids. Last edited by schpenxel; 11-08-2012 at 05:32 PM. |
It's somewhere under activate I believe--it should be pretty clear once you see it. It's something obvious like "clear adaptations" or "adaptations reset" |
- F3 (reset adaptation). IF those are your steps, then thanks anyways.By the way, in INPA, is there a way to run a quick one single test to scan the entire E60 for any errors in any system? |
It will just show the module and error code though, no real details. but at least you can see where errors are from there |
Thank you for the write up. Very few people are aware of this issue with the bmw transmission. I recently replaced my solenoids and it totally transformed the way that my car drives. It was a dirty job, but well worth the effort.
Hey Devil Dog!! I love your car!!
2006 550i Titanium Gray, Sports Package, Premium Package, Heated Seats, Navigation, Logic 7, Sirius, M-Tech Kit, PDC |
^^^Hoorah Marine! Nice whip you have there yourself.
Semper Fidelis Teufel Hunden!
2004 545iA, Titansilber Metallic/Black Dakota, Sport, Premium & Cold Weather Packages, Navigation, Premium Sound, Logic 7, HL Washers, Active Steering/Suspension, PDC, Adaptive Bi-Xenon,Voice Command, Beltronics STiR +, 58% Full Tint, Smoked Side Markers, 19" Hyper Silver Avant Garde M359/Michelin PSS, M5 Trunk Finisher & iDrive Controller, Dinan Performance Mods: High Flow Intake & Throttle Body, S3 Engine Software, S1 Suspension, CF Front Strut Brace and High Flow Exhaust |
It wouldn't be so bad if transmission fluid weren't dripping on your head the whole time, lol. I was lucky it never went in my eyes (that's what she said..) |
I need to have some sort of code before I can get the warranty company to pay for changing out the solenoids. I have a slight delay in reverse and the back and forth shifting from 5th-6th; heck I might just do it on my own. How much is the solenoid kit and what is the process of getting the right amount of fluid back in the tranny?
I would replace fluid and pan/filter while you're at it. Total probably 700-800 if you do it all? For oil level:
RESET ADAPTATIONS BEFORE DRIVING!!! And no, being under the car while it's running is NOT a fun job. I would also recommend a few heavy rags to insulate the back of your hands from the exhaust pipes that go right by that area (or did on mine anyways). Ask the back of my hands how they know.. Last edited by schpenxel; 01-29-2013 at 05:44 PM. |
http://www.one-stop-electronics.com/...&product_id=16 It comes from China and takes about two weeks to get though, so that part sucks. INPA here: http://bmwcoders.com/forum/bmw-gt1-o...-software-328/ Pictures don't work, but you can follow directions without them. Make sure to follow all of them.. especially the last part starting with Quote:
#25
| Tags |
| 545i, 6hp19, 6hp26, e60, mechatronics, solenoids, valve body |
