E46 (1999 - 2006)
Old 11-04-2012, 05:56 PM
uvbnhd uvbnhd is offline
Mein Auto: 2009 128i Convertable
angel eyes and corner lights
HI
Hoping someone can help. I have 2004 325ci convertible and both the angel eyes and the cornering lights don't work. I replaced both bulbs in the cornering lights and they still don't work. I checked some of the fuses and they are good. Any idea`s
Old 11-04-2012, 06:44 PM
Jimmys 530i Jimmys 530i is offline
Mein Auto: 2003 530i
Post pics of the headlights. The OEM setup does not come with angel eyes.
2004 BMW 330ci Silvergray Sport Package, Cold Package, Xenon Headlamps, Premium Package, 6 Speed Manual, Build Date 9/03
Sold - 2003 325i Sedan Japanrot 5 Speed 8k Xenon Headlamps Build Date 11/02
Old 11-05-2012, 07:51 AM
E46_Ci E46_Ci is offline
Mein Auto: 2005 325Ci + ZPP/ZSP/ZCW
And what "cornering lights" are you referring to? Our cars don't have "cornering lights" like the newer cars do. Are you getting any bulb out warnings on the dash (car symbol with light symbols to the front)?
If you are referring to the front corner lights next to the low beam (parking lights that also act as turn signals)... if you are not getting any bulb out warnings, those lights can be programmed by the dealer to be "off" when the headlights are on... the previous owner may have done this. Do your turn signals work?
Alpinweiß 2005 325Ci
Spacegrau 2007 X5 3.0Si
Old 11-14-2012, 08:58 PM
Hi Guys
THanks for responding and i apologize for taking so long to respond. There are two head lights. Outer does both low and high beam but iner light never comes on. I read online some people were saying they were cornering lights. They have fully functional lights in them so i replaced them. I didnt think BMW would waste money on working bulbs unless they were suppose to work. Am i wrong on this. Tried everything i found online,backing up, turning wheel, blinkers on nothing works. I am not getting anybulb warnings just thought they should be working and blinkers work fine. Also dont know if it has angel eyes but the inner light has a thick ring around it that i thought could be angel eyes. Here are some pics quality not good just got in and dark out will put up better ones as soon as i can. Thanks for your help
[ATTACH][ATTACH]349617
[/ATTACH][/ATTACH]
ID:	349616   Click image for larger version
ID:	349617   Click image for larger version
Old 11-14-2012, 09:01 PM
bmw330ci04's Avatar
bmw330ci04 bmw330ci04 is offline
Mein Auto: 04 330Ci 6 Spd, 07 335Cic
the inner light comes on when you flash your brights. when you keep them in the on position, then the outside lights become brighter. other than that they dont do anything. if you havent noticed though in the upper corner of each of the inner lights youll find a small hole. this is for the european cars, porbably a different protocol for lighting in the EU or something
oh, and, from the looks of it, you dont have halos. Halos are LED rings that go around each individual headlight. like this.
Not my picture, not my car. thanks google
Old 11-14-2012, 09:18 PM
When behind a good black SUV that was very reflective i have tried the the high beams and they still dont come on. If they dont do any thing thats fine it just seems like a waste. i just thought since they spent the money on bulbs they would do something. Thanks for your help.
Old 11-14-2012, 09:20 PM
bmw330ci04's Avatar
could be a fuse or something, because they are definately supposed to turn on
Old 11-14-2012, 09:25 PM
Thats what i thought but looking at the wireing diagram there was only one fuse that was only for the front lights and i swaped that with another one and it did not work. All the other fuses were for head lights and some other light. Since no other lights are not working i assumed these were good.
Old 11-14-2012, 09:35 PM
tturedraider's Avatar
Freedom isn't free!!
The inner lights do two things. They are "flash to pass" lights. They illuminate when you pull the turn signal stalk toward you. They do not stay on in that mode. They only illuminate while the stalk is pulled back.
They also function as the Daytime Running Lights, if your car is programmed to have them activated. The dealer does this programming. They light at a reduced intensity as DRLs.
Those are the ONLY two things those lights do. Your cars does not have coronas/angel eyes lights.
www.bmwcca.org
Old 11-15-2012, 05:55 AM
Hey Thanks for your help in clarifying this. After talking last night i started thinking and i had done the highbeam test prior to replacing the lights. Of course it was the only one i had not tried since replacing the bulbs. Tried it on the way into work this morning and you are correct i could see them come on. Thanks
One last note are there any DIY on programing them to have them come on in the day time.
