Old 11-15-2012, 09:34 AM
Primer Primer is offline
Mein Auto: 3 series
Unhappy Crank pulley
Help! Have any members heard of this happening? The crank pulley has come completely off my 320 d, there was no vibration or prior warning before this happened.
Would really appreciate your views.
Old 11-15-2012, 12:09 PM
DSXMachina's Avatar
Bimmerdex 7.4!
I haven't heard of it happening prior to this. Is the dealer taking care of you?
Old 11-15-2012, 02:49 PM
Mein Auto: 3 series
Crank Pulley
Unfortunately vehicle is 2008 and not still under warranty. Contact dealership today and will cost £90.00 to have them investigate but BMW UK will not offer any possible help without this assessment.
Old 11-15-2012, 06:58 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
What happened after?
Old 11-16-2012, 12:52 PM
Mein Auto: 3 series
Crank Pulley
Started and drove the vehicle about 800m, no problems, stopped at traffic lights and battery warning light came on, turned out of junction and heard a clank and dragging on the road, stopped car immediately and when I looked underneath oil was pouring out. There was no vibration or any other warning. Belt was fully intact, only saw two bolts, one bent and the other thread was stripped. Called breakdown assistance who towed car to garage.
Apparently crank pulley hit pipe on the block of the engine and has caused damage which requires engine replacement.
Sorry its not very technical but I know very little about cars but this is how it has been explained to me!
Old 11-16-2012, 01:27 PM
twhisten twhisten is offline
Drive it like u stole it!
Mein Auto: 2016 M3
Engine has to be replaced?? YIKES!!
1997 328i- retired
2007 328i- retired- lease
2006 330xi- retired
2011 335xi-PCD-12/13/10 - DINAN3-----retired
2013 M3-Laguna Seca-6 speed-EDC ------retired
2016 M3
2006 X5- retired
2011 X5- retired- buy back
bmw cca#443379
Old 11-16-2012, 11:04 PM
alpinweiss alpinweiss is offline
Mein Auto: E46, E83, E90 (all MT)
...Apparently crank pulley hit pipe on the block of the engine and has caused damage which requires engine replacement.
The crank pulley failure is a known issue on the 320d engine, although I thought the E46 models were more problematic than the E90 models. The remedy is normally replacing the the front pulley assembly. I was not aware this could cause complete engine failure, and I am having trouble understanding what happened on your car.
I would certainly recommend talking to your nearest BMW dealer, and maybe BMW UK. Ask about a goodwill repair, even though your car is out of warranty. The worst they can say is "no".
Alpinweiß
E46, E83, E90 (all with three pedals)
F25
BMW CCA member
Old 11-17-2012, 10:36 AM
Mein Auto: 3 series
Thank you for your replies, I do appreciate all the information I can get. As said previously I am not technical minded but I have been explained that when the crank pulley came off, it hit the bottom of the engine causing damage which requires complete engine replacement.
I have contacted BMW UK they will not offer any goodwill gesture if any until the vehicle has been assessed by one of their dealership garages, this will cost £90.00 plus cost of getting the car to them but it seems like the best action to take and maybe worth the money?
Have be lent a car by a friend but I really miss my bimmer!
Old 11-17-2012, 10:59 AM
Oddly fragile, especially for a diesel, don't you think?
Old 04-21-2015, 08:32 AM
Imran689 Imran689 is offline
Mein Auto: 320d
Eeeeee
Well lads as this is my first Beemer im slightly dis heartned ... Bought a 2002 320 d last night and yeah ive done 400 miles with good pace since the ... But the crank shaft pulley has just fallen off completely luckily for me looks like no engine damage but can someone advise what to do? Anything I need to be weary of on fixing this?
Old 04-21-2015, 09:47 AM
Phil325i's Avatar
Phil325i Phil325i is offline
Mein Auto: 325i E92 Coupe
I think the problem stems from the rubber damper/shock absorber element incorporated into the pulley. Over time this can suffer from perishing/oil contamination etc and fail. Worth a careful inspection at each service and preventative replacement if problems are suspected. But prepare yourself, as these damped pulleys aren't cheap...
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; BMS clutch stop; BMS CDV; RE g/box mounts; Saikoumichi OCC; K&N; Cyba scoops; BMW Perf Exhaust; M3 rear spoiler; M3 white dash LEDs; LED Angels; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof
Old 05-23-2015, 02:15 PM
SollyAdrian SollyAdrian is offline
Mein Auto: BMW 320D (2010)
The crankshaft pulley on my 320D (2010) broke off without any warning. Cost me nearly £430 (pulley, belt, labour, VAT). Not impressed as only had the car for a few weeks.
Old 05-24-2015, 08:45 AM
cazzopazzo cazzopazzo is offline
Mein Auto:
Mine is making some noise since I had my dealer flush and change antifreeze and I notice the pulley Warbles at the center of the engine any suggestions ?
It's a 2011 335xi sports package.. Made in Germany
Please advise I'm concerned .
Thank you!
Old 05-24-2015, 09:01 AM
Get it changed ASAP as if it breaks it could damage much more than the pulley.
Old 05-24-2015, 07:07 PM
Mein Auto:
Thank you for the advise I will call dealer on Tuesday ! Have a great weekend !
