Old 11-12-2012, 08:35 AM
mrderp83 mrderp83 is offline
Mein Auto: 1998 740il
Exclamation Heater
I am having an issue with my heater on a 1998 740il. The blower motor is working fine, however the heat will not come out until I start to drive the car (only blows cold until i drive). I do not know what causes this. Anyone have any solutions? Thanks.
Old 11-12-2012, 10:23 AM
rrtec's Avatar
rrtec rrtec is offline
Bored Worker
Mein Auto: 540i/6 4/99
Check your coolant level, be sure that the system is properly bled out as trapped air in the heater coil can cause this. Have you recently serviced the cooling system?
2001 740il Sport- Needs maintenance.. Parts ordered..
2006 Volvo XC90- Kid Hauler
FC3S LS1/6Speed
1992 BMW K75s Cafe build
Old 11-12-2012, 12:10 PM
The radiator was flushed out about a month ago. Not sure if this problem existed before the radiator being flushed. I will check the coolant level, however I am not sure on how to bleed the coolant system. Any insight would be much appreciated! Thanks for your help.
Old 11-12-2012, 06:26 PM
setconstr setconstr is online now
Mein Auto: 2001 740i spt 2008 cl550
bleeding
http://www.bimmerboard.com/forums/posts/704107
Old 11-15-2012, 01:56 AM
BMWFatherFigure's Avatar
Old School
From memory there is a valve or switch that prevents the heater (heat) working until the engine is up to temp. This item may be giving problems.
Current:
E38 Parts Car
Previous:
Old 11-15-2012, 11:58 AM
Well the thermostat shows that the car is warm. I will be trying to bleed the system this weekend. Do you guys know where this bleeder screw is for the cooling system? Thanks!
heater
