having to add a quart every 700 miles - Bimmerfest - BMW Forums
Old 11-12-2012, 12:02 PM
bkc0508 bkc0508 is offline
Mein Auto: 2006 750LI / 2012 2500HD
2006 750 I have found myself having to add a quart every 700 miles. I have replaced the crankcase vent valves both where bad. I have also checked for leaks and none found. I am not seeing any smoke in the mornings at start up. I have also followed my wife and I dont see the car smoking going down the road.
I know its got to be going somewhere but I cant figure out where.
Any ideas?
Old 11-12-2012, 08:30 PM
Anderson0329 Anderson0329 is offline
Mein Auto: 750li
Mine is doing the same thing and have change everything but head gasket seals
Old 11-13-2012, 02:28 AM
jdcraw's Avatar
jdcraw jdcraw is offline
Mein Auto: 760Li
It might be the head gasket seals. I had to get that done too. When they remove the cover under you car you might find all of the oil that you've been losing...
jdcraw
Old 11-13-2012, 03:42 AM
Well at least I am not alone on it. I have had the car on the lift and can find no oil leaking. It sucks I bought this car 2 mths ago and put a quart in it twice.
It's showing 9tmls on the oil service but I think I am going to change it this weekend and see if it helps. I wonder if the wrong type of oil could cause this?
Old 11-13-2012, 05:27 AM
745iguy's Avatar
745iguy 745iguy is offline
Besessen Deutsch Autos
Mein Auto: 2006 X5 3.0
you probably have an oil leak; check your valve cover gaskets, timing cover gaskets, look in ur spark plug wells and see if there is any oil down there, check your oil pressure switch, your vacuum pump, your oil filter housing, the oil pan gaskets, oil level switch, and last but not least ur alternator bracket gasket.. i doubt your car is burning that much oil. I was nearly doing the same until I changed driver side VCG and spark plug tubes, and then more recently my oil pressure switch and vacuum pump O rings.
06 X5 3.0 Toledo Blue Metallic/Light Beige 2:
Adaptive Xenon Headlamps, Panoramic Sunroof, Rear Sunshades,
+Factory Aux Input in Ashtray, Bluetooth, Rear PDC Sensors, Rear Electronic Adjustable Seat Backs,
+White Angel Eye LEDs, +5000k LED H11 Foglights, +Blacked Out Chrome Grill Surround, +Puddle Light Logo Projector
.. more updates to come
PREVIOUS 2002 745i
Old 11-13-2012, 07:07 AM
Thanks I will pull the plugs and see anything there. I ll check all the other items to
Old 11-13-2012, 08:02 AM
745on22s's Avatar
745on22s 745on22s is offline
Mein Auto: 04 745li
Your burning oil like the rest of us (bad valve seals) let it idle and see if it smokes! mine does
04 745Li on 22" Asanti af-128 Eibach Springs
08 Lincoln Navigator Elite
Old 11-13-2012, 05:06 PM
MOPAULY's Avatar
MOPAULY MOPAULY is offline
Mein Auto: Many things
Valve seals. I'm at 92k with the same issue. Replacing mine over the winter. If your not mechanically inclined it will cost you $$$. It's not abnormal for these cars, although as a whole valve seals should last a bit longer.
Old 11-13-2012, 05:41 PM
Rookie2008's Avatar
Rookie2008 Rookie2008 is offline
Mein Auto: BMW 328GT/740LI/750LI
I agree with others sounds like bad valve seals. Good Luck.
13 740LI W/Msport package. Executive Package
DRIVER ASSISTANCE PKG, HUD,
OYSTER; NAPPA LEATHER SEAT TRIM,
Lane departure, blind spot detection,
Collision Mitigation,
Side & Top View Cameras
Aftermarket Rear entertainment
Old 11-14-2012, 01:59 PM
jlombardi jlombardi is offline
Mein Auto: 2006 BMW 750i
mine does the samething.... its embarrasing especially in drive threw
Old 11-15-2012, 11:17 AM
Chris29817 Chris29817 is offline
Mein Auto: 2006 750i (E65)
I have the same issue too. I've been using M series oil 10w 60. It works out better.
Old 01-24-2013, 09:13 PM
JudyW JudyW is offline
Mein Auto: bmw 750i
Question head gasket replacement & spark plug tubes, etc
I was putting in a quart every 7-800 miles also.. Problem started to come to light at about 90,000 miles while car was under extended warranty. The dealer (A) did its best to ignore our concerns and then overstuffed the car with oil when we tried to get a true benchmark. To make a long story short, my husband got ill and passed away over the period of 18 moths and car concerns went on the back burner. Had an independent mechanic take care of car needs during this period and eventually he had me put in heavier weight oil for the last year which helped some...at his suggestion until I could contact BMW and get the repairs needed. He said he couldn't understand why a BMW flagship car should have the leakage at such low mileage and young age. I have now had the head gasket replaced, as well as some spark plug tubes and the 'snowman' is being watched by a local BMW dealership (B) (at least $3000) and I am sending the record and bill to BMW for reimbursement. Currently there are 138000 miles on the car and the driveway is full of old oil spots. I personally have not seen any leakage since the repair this past month, but it will be going back for another inspection the beginning of this month. Our previous 740iL (1995) had 369000 miles on it before it died with oil usage in the reasonable range and no burning. When we bought it it had about 30,000 miles on it. What gives?
