Discussion pertaining to the flagship BMW here. |
I just realized my car doesn't have hoses coming from the ccv on either side of the motor. I don't believe it is supposed to be like that. Any input?
In that case you just have the caps( some came with hoses and some doesn't)
![]() 2001 X5 3.0i 200k miles & counting...( SOLD) Dinan Stage 1 Trans and Engine /SMG M3 Steering wheel/M5 SMG shifter/BMW rear entertainment/4.6IS body kit/4.8is Exhaust/ X-pipe/Turner HP Pulleys/E92 sport seats/Group M Intake/Brembo drilled rotors/Quart projector beams headlights 06 750Li with 19k miles. Bone stock. |
Non turbo cars will just have CCV vents. No hoses attached.
That's probably what it is. Thanks!
edit: Never mind i see what youre saying, some cars have hoses come from their CCV's and some don't, I wonder why they changed it
06 X5 3.0 Toledo Blue Metallic/Light Beige 2: Adaptive Xenon Headlamps, Panoramic Sunroof, Rear Sunshades, +Factory Aux Input in Ashtray, Bluetooth, Rear PDC Sensors, Rear Electronic Adjustable Seat Backs, +White Angel Eye LEDs, +4300K Foglight HIDs, +Blacked Out Chrome Grill Surround .. more updates to come PREVIOUS 2002 745i Last edited by 745iguy; 11-14-2012 at 07:46 PM. |
It has the nipples for the hoses but none there. That's why I wasn't sure
I might have to edit my original statement. The ones with nipples (connectors) are the old style. That was modified to the new style, that still has the vent but its just more integrated into the plastics so you dont notice it as much (nothing sticking out).
New ones dont have nipples, looks the same just no nipples..
Has anyone changed their air pump hoses? The ones that go connected to the CCV valves and air pump? I was changing my CCV and broke one of the hoses. I called the dealer and they said it was 2 hoses. On mine it looks like it's just 1 that connects to the CCV valves and 1 to the air pump and 1 to the engine. Total 4 connections. Please help
Early versions have a hose assembly that fits to each CCV valve on the top of the rocker covers and are joined together and connect to two ports on top and below of the throttle body on the inlet manifold. Later version use two individual insulated hoses If your referring to the secondary air pump, the hoses go to two metal valves at the rear of the cylinder heads, they are not called CCV's. Stuart Last edited by stuartjohn24; 11-20-2012 at 03:36 PM. |
im not sure if it's the secondary. I replaced the CCV and broke 1 of the brittle hoses. Now I need to replace. It looks like it's 1hose with 4 connections?
