E34 (1989 - 1995)
Yet another issue - M60
I only experience this minor issue when the car is cold. I crank and it idles fine but when I put it in gear and start to move it starts stumbling but not to the point where it's gonna stall, just about to 500rpm (idle afaik is 650) it only happens when I first move it, doesn't happen after that until I have another cold start (sorry if it doesn't make that much sense)
I think I have a vacuum leak coming from one of the intake gaskets because they're old and have never been changed. What else could it be?
Then spray carb cleaner at all intake and vacuum ports and see and redo the test to see if the engine behaves better. Inspect everything in your intake that you can get your hands on without major disassembly, such are the main air hose. Make sure connections are tightened. I doubt rubber gaskets expand when heated. They are not made of metal. Your cold start problems could well be a defective crankshaft sensor. The resistance when cold could be falling outside its rated specs. Check the resistances, when cold, and when hot, and anyway, you know the drill sir, if you intend to keep the car and haven't changed it out in the past few years, do so to avoid the inevitable no-start situation. Last edited by robertobaggio20; 11-09-2012 at 05:43 PM. |
Rubber expands when it is heated.
Anyways, I can't replicate it any other way. It only happens when there is stress from the driveline on the motor ie. shifting into gear and starting to move. It can't be the CPS because the engine still starts no problem and idles fine. I also think it might be the ICV gasket. It looks like it's not sitting properly in it's space.
![]() I've read more than one article that suggests that rubber shrinks when heated. http://www.ehow.com/how_7902518_shri...ber-seals.html http://www.ehow.com/about_6544441_te...bber-band.html http://www.physlink.com/education/askexperts/ae478.cfm So i would treat that theory with caution. Clearly too, gaskets not sitting properly, or being too old and brittle, can only lead to trouble eventually. The ICV gasket really screws with idling and the engine when its not fixed properly, so you're probably spot on there. The difficulties occuring while shifting, and when cold, invoke the possibility of low tranny fluid. Tranny fluid expands when heated and may be too low when cold. Thirdly, you might want to clean your throttle position sensor and its switch, with contact cleaner, and then apply dielectric grease before fixing it back. That can occasionally cause problems as well. Are there any relevant error codes ? Last edited by robertobaggio20; 11-09-2012 at 07:24 PM. |
More basics for you bobby.... http://en.wikipedia.org/wiki/Thermal_expansion Also consider that the metals that are seperated by the gasket expand, sealing gaps. This really is quite common bobby.
Winter Rules
This article needs additional citations for verification. Please help improve this article by adding citations to reliable sources. Unsourced material may be challenged and removed. (March 2010) " The portal I referred to earlier is a physic portal. Here's one from a university's lecture material : http://www2.le.ac.uk/Members/mr6/lec...s-students.pdf To quote " The properties of elastomers are remarkable and very different to almost any other solids. For example, ideal rubber does not expand when heated. In fact, loaded rubber will actually contract if heat is applied. " Applying a layman's "things expand when heated" understanding is quite clearly unsafe when it comes to elastomers, which react differently to changes in entropy from undisordered solids. rgds, Roberto Last edited by robertobaggio20; 11-10-2012 at 02:13 PM. |
Your point that metal expands when heated is well taken and I'm sure the op took note of it accordingly. I didn't refer to it simply because it had nothing to do with my points about rubber and so was not directly relevant to your response to that.
Aside from that, metal expands when heated, but usually extremely little....unlikely to cover up a hole sizable enough to cause the problems the op has mentioned. Op, please check everything, tighten everything, inspect everything for cracks, maybe even look in the air box, etc. I think you need to check everything from scratch...wouldn't take you more than 15 minutes. And clean out that tps (throttle position sensor), it could be responsible. I assume you don't have any useful error codes. I don't think its your intake manifold gaskets, they usually stay put and stay that way unless you have done something in that area recently. Unmetered air usually does not lead to near-stall situations, just poor running, fuel economy and poor idling, maybe o2 sensor codes as well. Double check that you don't have any leaks from your transmission. Double check your cps's resistance when cold. I've cable tied my cps connection to the oil dipstick to make it easy to access for any reason, I suggest you do the same for as long as its not a new unit in there. Lets wait to hear back from him after this weekend (hopefully). Last edited by robertobaggio20; 11-10-2012 at 03:20 PM. |
REALLY? MY posts are being deleted yet advice like this is allowed to stand? It is COMMON knowledge that expansion and contraction of engine parts causes leaks that cause running issues. Since my last response was removed, even though it contained further advice for the OP, actual good advice, I will try once again. Check the coolant temp sensor at the back of the engine, in the crossover tube. It could cause a cold/hot drivability issue, and is reportedly a common failure.
Winter Rules
Actually, the post that was removed was not flagged by me. In fact, it was very mild, by your standards.
Bimmerfest does not remove posts for bad advice. Their acceptable use policy makes no reference to this. I'm driving a 20 year old and I've never heard of a situation that expansion and contraction of engine parts leads to running issues, at least not in a general sense. I've never seen it on these forums either, except for one member's case which my mechanic suggested could be a head gasket issue. He had a cold start problem, which disappeared when the engine warmed up. The head gasket could expand and fix this. So its certainly not common snowsled7 and therefore it is unlikely to be common knowledge either. That being said, I just came back from an.....intervention, shall we say, where the problem concerned (the story is too long) was traced to a buggy coolant temperature sensor. It caused major engine problems and emptied half the gas tank by the time we figured it out (we had many red herrings to work through). So snowsled may well be right about that. OP, the way to check it is to disconnect the sensor he refers to and start the car and drive off when its cold and see if the problem recurs. If it doesn't, then its the problem, change that out and you're done. If the problem recurs then its something else, reconnect the sensor and delete the error code that disconnecting it would have generated. Quote:
rgds, Roberto Last edited by robertobaggio20; 11-11-2012 at 08:25 AM. |
-Finished testing- No vacuum leaks ECT fine O2 sensor works Now I don't know where else to look.
Year: 1990 Model: 525i Transmission: 5 speed Mileage: 250k Last edited by Microtesties; 11-11-2012 at 12:50 PM. |
I have no record of it ever being replaced. It will probably be swapped out within the next two weeks. I am barely driving my car because I got my exploder running properly again. I am in no rush to fix this but I will update this thread as soon as I find a fix for my issue.
If this solves the problems, then you'll just have to replace the coolant temp sensor. Oh and of course, please do the stomp test if it works on your car and see if there are any useful error codes there. OP. we'll hold you to your promise to update your thread. Too many people fail to do that after posting an interesting issue that invites contributions. ![]() rgds, Roberto Last edited by robertobaggio20; 11-11-2012 at 04:54 PM. |
Check voltage of the car running and when It's off. A healthy battery should be somewhere around 12.6 dead I think 12.1. Running should be around 14.4, I havnt checked my car but i would be worried with anything lower than 13.5 volts.
And it is common sense that when heat is applied molecules expand, air metal, and yes rubber, expand with heat.
2003 GMC Sierra SLT 2500HD CC/SB |
Not according to Dr Werner Kuhn's paper on rubber published 82 years ago. |
Less power to the coils?
HSW "Expansion"
![]() 1995 525iA 250k mi Shifted Performance E34 2006 325i/6 48k mi 2003 350Z 87k mi Shifted Performance 350Z Garden State Euros |
I think this was the padre's missing link....
http://science.howstuffworks.com/dic...nsion-info.htm Well....i've not seen this happen in practice, so I wouldn't go for this when tracing the suspects for your situation here. Last edited by robertobaggio20; 11-12-2012 at 03:28 PM. |
I've seen low voltage cause many running issues. When the car is cold its obviously been sitting for awhile without the battery being charged by the alternator. When It's warm It's the exact opposite. The Car os Either charging or has residual voltage in the system.
So that's why it would happen when It's cold. And yes with low voltage everything is starved for power. You can have such a weak spark that It's actually off timing. And after thinking about yeah rubber shrinks with heat. Like shrink wraping lol. But most gaskets aren't rubber.
2003 GMC Sierra SLT 2500HD CC/SB Last edited by Josh429er; 11-12-2012 at 08:16 PM. |
My M60 didn't do that but it was moody when cold too. I put royal purple 20w-50 in it, dinan chip, New o2 sensors, and replaced the resonator with an X-pipe and it was much happier in general and especially when cold. I also did a tune up and changed the fuel filter and added a K&N stock replacement filter. It ran like night and day after all these changes. Just make sure the throttle body is clean and your intake snorkel doesn't have a hole in it. Also check your throttle position sensor.
All those changes should fix the issue, each of them decrease the work and load on the engine. But it almost sounds like an intake leak. Smoke tested?
Sent from my PH44100 using Bimmer App |
I think I figured out my problem by accident today lol. I was playing around with my ICV and I noticed the little rubber boot going into the intake manifold wasn't seated properly. I took it out and properly put it back together and voila already better response and no hesitation. Hopefully this is the fix. Not too sure because I haven't experienced a cold start yet. That will be left for tomorrow morning.
Glad you found the issue Costa.
