#376
Want to learn about your E39 5 Series? Click Me Albo's Official Upgrade Thread: http://www.bimmerfest.com/forums/sho...d.php?t=532572 ![]() 2003 530iA - Mumbo Jumbo |
#377
For the record, maybe Gary should PM this guy who is having trouble finding the DISA:
- - > E39 (1997 - 2003) > More trouble codes....
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! |
#378
Thanks for the info and the great photos guys, i have the codes logged in my computer and will be taking out the DISA to inspect as soon as i get a warm enough day!
2006 X3 3.0i aFe Dry Air Filter Mann-Filter Activated Charcoal Cabin Air Filter EBC Redstuff Ceramic Brake Pads |
#379
well i just bought your repair kit and i didn't even inspect my DISA. thats how much of a wild card I am. too much work for me, the new parts will motivate me... next weekend.
#380
I used the tip of a wooden chopstick. Depending on how narrow the chopstick tip is, use a needle nose plier (or any plier) to lightly crush the tip so that the tip fits into the O-ring slot. I used a small flat blade screw driver to get things started but the wooden chopstick did a great job of cleaning out the slot. The wood was hard enough to scrape away the O-ring material and soft enough not to damage the plastic grove. After crushing the tip, the wood fibers become a little flexible and can really get the corners cleaned out. I used it like an eraser, scrubbing back and forth to get the stubborn areas clean. It worked great. |
#381
- How the DISA valve operates (0) (1) (2) (3) (4) & how to test DISA operation (0) (1) (2) (3) (4) & a nice DISA autopsy (1) (2) Quote:
- How the disa valve o-ring fails (1) (2)
#382
My (long) DISA Story
Gary, Thanks so much for the DISA repair kit. The kit (possibly the O-ring alone) made an amazing difference and restored power I didn't realize was gone. The loss of power occurred slowly over time so I had no idea how much power I was missing. The car drives like it's new again (ok - I might be exaggerating just a little).
Here's my long DISA story. Years ago I was replacing the CCV and wasn't sure what method I was going to use so I started with trying to remove the intake manifold. One thing I removed at the time was the DISA. I decided not to continue along that path and installed the CCV without removing the intake manifold. When I put it all back together and started the car, I got a service engine light. I missed one of those connectors that come from that octopus of wires near the air intake (wires that go to many sensors and controls). I reconnected it but the light didn't go away. When I finally got the tools to look at and reset the codes. I was getting several codes related to unmetered air getting into the system. The codes I was getting regularly were 227 and 228, 'lambda contol tolerance Banks 1 and 2' as well as other related codes. The CCV connections were fine. I chased that air leak for years (whenever I had time). It was there after the OFH gasket change, after changing spark plugs and after changing the valve cover gasket. Codes 227 and 228 were always showing up. Two years ago, I decided to check the DISA valve again. I took it out and it seemed something was wrong with it. The flapper wasn't quite right, I thought maybe it needed to be in its installed position to function properly so I attempted to reinstall it but it wouldn't fit back in properly. It wouldn't sit flush against the manifold. The old me would have forced it in and tightened the bolts but I must have learned something over the years because when I pulled it out to see what was blocking it from fitting properly, I found the pin that holds the flapper in place sitting in the channel that the DISA slides into. I was lucky. I assembled the pin into the flapper. The DISA was functioning fine with the pin installed but I didn't know enough at the time to suspect the pre-formed O-ring. It seemed good to me. It wasn't until a couple of months ago when I tried again to track down the air leak that I came upon all of these DISA threads with discussions about how to change the O-Ring. I took the DISA out one more time and saw it was no longer functioning. The flapper moved freely. I ordered Gary's kit with the Fluorosilicone O-ring and did the repair (the bell crank was completely rounded). It's been a month and I notice an amazing improvement in power. I'd merge onto the freeway, look at the speedometer and notice I'm doing 80-85 without pushing the car at all. Best of all, I haven't seen codes 227 and 228 in a month (I think the O-ring solved that mystery). It's a great design, an easy fix and in my case solved a several year old air leak mystery. Thanks Gary. Last edited by geobrick; 03-10-2013 at 07:48 PM. |
#383
After reading many testimonials of the hazards and pitfalls of the "DISA valve" it seemed like a logical conclusion that this part WILL fail. It's not a matter of if, but when. And when it fails, it can have serious side effects; the imaginary animation of a metal pin flowing into one of my combustion chambers was not pretty.
I didn't want to remove the part for inspection without at least having a new sealing ring. I saw discussion of which O-ring would fit, and the arguments over which material was best suited. I heard about group buys on new DISA valves, but these parts were made the same and would also fail. Once I discovered the G.A.S. solution, I knew that only this was good enough for my E39. The price seemed VERY reasonable for a potentially permanent fix for this BMW albatross. I had to have the uprated O-ring, of course, and the transaction was silky smooth, shipping lighting fast. Machining is what sets aside the "proper" parts from the mass produced dregs of China and Taiwan. It's also what separates BMW from the likes of Ford...and Hyundai. They are getting better, but I bet they change the cutting heads a lot less frequently and accept a lot more slop in the whole process. With that in mind, when I opened the small box from German Auto Solutions, my eyes opened wide. These pieces are works of art! I had never seen the inside of my DISA valve, but I knew it didn't.....couldn't look this good. OK, so not only do they outdo themselves with the machining but they have complete directions, which are very easy to follow, with plenty of pictures. They go SO far out of their way to make sure you don't screw it up, I was starting to feel offended with all the disclaimers and warnings. C'mon, this aint my first ro-de-oh!!Enough already! On with the magnificence: ![]() Oh, yeah...... ![]() Now THAT'S what a DISA should look like! You just read that story above mine, how his pin was just floating around in the groove the DISA rests in, O - M to the ff'in G!! Here's what mine looked like after I removed it: ![]() First of all, the lever was so rounded, the flapper was spinning, unable to be activated at all. The pin was still in place (thank the maker), but VERY well worn. And you can see one of the flapper corners was eroded away from just hanging in the breeze rubbing against the rest of the setup. This was on a car with just 100K. Seriously, if you've never thought about this device, this is your wakeup call. If you have checked yours, good, but give yourself the piece of mind, and get this kit and install it. Grassroots tech like this needs to be in the spotlight, HUGE kudos to the G.A.S. team!
Speed, reliability and cost...
#384
Thanks Five30Eye for the glowing feedback.
The kit has been on the market almost a year now and has been a great success. If people only knew the amount of time and effort that went into the design of this kit. I'm a perfectionist at the very core and I think it shows up in the quality and attention to detail of the kit and the instructions. This is not a big money maker for us due to the number and extent of machining operations, plus bead blasting, anodizing and all the accessories that we include in the kit. The kit price was set based on what the market would bare based on the replacement cost of a new unit, not the actual cost to produce kit plus a normal profit margin. Now that replacement units have gone up in price by a $100.00 we are considering a small price increase in the kit. You will probably see the kit price increase in a month or so to $79.95 from the current price of $75.00. I hate to do that, but I have already tweaked every part of the production process to minimize machining time without sacrificing any quality. The $4.95 increase still won't bring the kit into a "normal" profit margin range, but it will help over time. I promise that we will cap the price at $79.95 (baring hyper inflation or something else beyond our control) to make sure that the kit remains a very good value over the cost of replacement. Thanks again everyone for your support and kind words over the past year. Keep checking the website for new products offerings, like maybe our new 1.2 bar coolant cap (hint, hint) that currently has an introductory sale price. http://germanautosolutions.com/ Gary
"I'm a little rascal on my Little Rascal" - unknown |
#385
This week the DISA valve on my 330 with 73k miles started audibly rattling quite loudly. Unplugged the DISA and the rattle went away immediately, so easy confirmation there. Was shocked to see the OEM part is almost $350! I'm really considering picking up this repair/upgrade kit - though by the sound of it I should first pull off my DISA unit and inspect it to make sure the housing is in good shape? I haven't noticed any real negative symptoms in the car beyond the occasional uneven idle so I expect the vacuum seal is still okay. I've unplugged it in the meantime to help avoid any plastic bits falling into the intake.
Looks like a quality kit, Gary, thank you for all your hard work. Last edited by GuinnessDraught; 03-02-2013 at 07:58 PM. |
#386
When trying to order the DISA/coolant cap combo, the DISA defaults to the 2.2/2.5 version but I have a 3.0. Is the combo price available for the 3.0 or do I need to order the parts separately? |
#387
Thanks for posting these photos of the inside of your manifold. Just inspected my DISA yesterday and looked very similar and the inside of the intake looked like that also ... some sludge and grit. I did discover my lean codes were probably being caused by cracks in the intake boot so maybe dirty air coming through there introduced some of the grit. I'd love to know how many others see this kind of sludge in their intakes?
#388
More than likely, the oil/ sand build-up is from the CCV not working properly - providing enough vacuum through the valve... So, instead of the CCV pulling blow-by down towards the oil pan, and out through the Valve to be vented, the blow-by and oil gunk is being sucked up through the Intake Manifold.... Not good...! You might check-out these threads: http://forums.bimmerforums.com/forum...5#post26059585 http://forums.bimmerforums.com/forum....php?t=1629018 Thanks! Jason
What if, which is very common, and which happened to me, the CCV vent hose to the dip stick guide tube snapped nearly in half (as shown below on my M54) at the 90° upper elbow nearest the CCV ... Would THAT huge hose tear also cause road grime to be sucked into the intake manifold?
#390
But, could probably mess up the CCV system by not allowing the system to pull sufficient vacuum through the system. Think of it as a giant straw, and you now poked a hole in the middle of the straw as you are sucking your drink up... Once the hole is there in the straw, it makes it pretty hard to suck and drink through that straw, huh...? ![]() Thanks! Jason
So, you're saying there'd be no vacuum, so, road grime would NOT get sucked into the intake manifold?
#392
That particular broken hose would be an unfiltered air inlet directly into the intake manifold. If left that way for very long in a dirty driving environment I could see it allowing a lot of grit into the intake manifold.
#393
Got the kit I ordered yesterday and did the repair/install today. Seems to have worked great! High quality parts and excellent instructions. Thank you, Gary!
Took me 2-3 hours to do start to finish as I was taking my time and in no hurry. The most tedious and time-consuming part was scraping off the old O-ring and cleaning it up real good before putting the new one on. Overall it was a pretty easy job. Also I'm glad that I did this now, as when I was taking my old DISA apart I caught this: ![]() The pin was starting to protrude from the housing it is supposed to be flush against. It is not a very long pin, nor is it threaded. It wasn't loose, but it did not take all that much effort to pull out. I'm actually pretty shocked by how bad of a design the OEM part is! ![]() Very impressed by the redesigned replacement parts that will ensure this sort of risk of metal bits falling into the intake manifold will never happen again! Just like the GAS page describes, the plastic lever's hexagonal stem had worn away and begun to get rounded off causing the flapper to rattle and have a much less precise motion. Gary's kit is how the DISA should have been designed by BMW in the first place! ![]() All fixed up: ![]() With the repaired/upgraded unit installed back into the car my DISA rattle is gone, my occasional drooping/hunting idle seems to have disappeared, my off-the-line power feels more even, and the kick you feel when VANOS engages at 4000-4500 RPM feels stronger. I imagine my DISA had been slowly dying and becoming less effective for quite some time before starting to make the racket that caught my attention. I hadn't even noticed how much it had been affecting performance as it degraded so slowly over time. |
#394
interested too look like a great fix
#395
There will be some vacuum I suppose, but no-where near the vacuum that is needed. To Gary... Your Disa Repair kit is OUT of Stock until the 15th...! ![]() Any update on the CCV build...? Thanks! Jason
#396
Thanks, Gary
#397
First post here:
I installed the G.A.S. kit last weekend on a 2002 330i with 114K miles. My original DISA valve was still in good shape with no noticeable play in the tapered hex joint, and it took a good deal of force to pry the bell crank off the flapper. I also purchased the 1.2 bar coolant cap. As everyone can attest, the kit is top notch. And as alluded to by Gary, the real issue is the hex joint. After a bit of clearance forms, it really is just a matter of time until the bell crank works itself free, and if left that way for too long, the free wheeling flapper could take out the frame and cause more serious damage. From what I can tell, the real benefit of an aluminum flapper is that it allows for a secure mounting point for the titanium screw and, therefore, a tight press fit for the tapered hex joint, which as noted is what starts the ball rolling toward gloom and doom for the OEM design. I also replaced my CCV unit with another OEM unit. I wish G.A.S's redesign were ready for purchase -- maybe next time. |
#398
Just placed an order for the DISA valve repair kit and coolant cap combo. I've read nothing but good review on Gary's redesigned product so I'm convinced. My car currently has 185,000 kms (115,000 miles) so I will be replacing it whenever I get a chance. Not in a rush but I know once I take care of that, I'll never have to worry about it ever again.
2002 530i Sport Package 5-speed Style 42s for summer Style 29s for winter CDV delete Skibag retrofit G.A.S. DISA Valve Repair Kit G.A.S. 1.2 Bar Expansion Tank Cap |
#399
Anything with the CCV...? Do you have any ideas on how to repair the rubber around the frame-work for the flapper on the Disa Valve...? Please let me know. Thanks! Jason
gary@germanautosolutions
'Fest Sponsor Location: Grand Rapids, Michigan Gary, I received one of your 3.0i DISA Valve rebuild kits back in Feb. I am so lucky that the original valve stayed together long enough to let me rebuild the thing. We have a 04 X3 3.0i. it now has 87,000 miles. The DISA valve was ready to fall apart. When I removed it, the yellow teflon pivot lever was worn to the point that it did not even hit the flapper valve. The stainless pin was partially out but the only thing keeping the flapper from falling into the intake manifold. The new kit installed, functions great. The fuel mileage is back to 20.5 combined and 24 Hwy. The performance is back. Thanks for such a great solution. |
