Tires touching on rear fender lip - Bimmerfest - BMW Forums
Old 10-19-2012, 08:22 PM
Trini BMW Trini BMW is offline
Mein Auto: 2000 E39 540i6
Can anyone give me advice on what to do....
I recently purchased a set of Staggered Rennen wheels 20x8.5 FR and 20x10 rear from my friend who drives a 2003 E39 M5.
The wheels and tires fit perfectly on his car without any touching issues.
I own a 2000 540i6 M Sport and the wheels fit perfect in the front but the back touches on the inside lip.
I was told to roll the lip but comparing the two cars it looks as if his car sits about two inches higher in the back.
Is the wheel well bigger in the M5 than my car?
Is the suspension interchangeable on the two models?
Can I use M5 springs on my struts?
Are they the same?
I am wondering if I could use the M5 springs to raise the ride height as well as is the springs stiffer?
Thank you all for any advise given.
It looks really good and I will put posts on later
Old 10-19-2012, 09:03 PM
freethrowdunk freethrowdunk is offline
Banned
Mein Auto: '03 525i
My advice: Have the fenders rolled.
But to answer one of your questions (as I'm not too sure on the others): Yes, the rear wheel wells on an M5 are bigger.
Old 10-20-2012, 05:02 AM
Topaz540i's Avatar
Topaz540i Topaz540i is offline
FTW Trump 2020!
Mein Auto: 2001 540i/6
The m5 has different black plastic liners in the wheel well
ESS Tuning m60 version software
m60 intake manifold
a.f.e. c.a.i.
3" obx catback
full powerflex urethane setup
545 ssk
cdv delete
m5 rear sway bar
M5 chassis rods
M5 3.15 lsd
Bc-r coilovers w/ swift springs
Akebono=suck
ss braided brake lines
coming soon:
Jb lwfw
Old 10-20-2012, 09:59 AM
doru's Avatar
doru doru is offline
Mein Auto: 2003 530iA
What was said above. You can search this problem - it has been discussed.
Another issue you're having is that the said wheels are bigger than the biggest OEM wheel. The rear wheel you purchased has a width of 0.5" larger than OEM. Hopefully the offset is within spec. Why did your friend sell these wheels?
Old 10-20-2012, 10:37 AM
chiefwej's Avatar
chiefwej chiefwej is offline
Freude am Fahren
Mein Auto: 2003 540i/6 //m-tech
20's, really, why?
chiefwej 2003 540i ///m-tech 6-speed
Black Sapphire Metallic w/gray
Old 10-20-2012, 10:40 AM
AnotherGeezer's Avatar
Entwicklung 39
Mein Auto: 2003 530i/5
Originally Posted by chiefwej View Post
20's, really, why?
^ This and no 20's, no problem.
Old 10-20-2012, 06:40 PM
my friend sold it because he wanted to go back to the oem.I could have seen on the tire there were no rubbing marks.It looks prettycol though I just need to roll the lip
Old 10-20-2012, 06:46 PM
how did the CDV delete work?Im thinking about trying it.Which one did u do?
Old 10-20-2012, 06:48 PM
what size is this?
Old 10-21-2012, 05:28 AM
Topaz540i's Avatar
FTW Trump 2020!
Cdv delete turns into into a normal car. Well worth it. And free.
m60 intake manifold
a.f.e. c.a.i.
3" obx catback
545 ssk
cdv delete
m5 rear sway bar
M5 chassis rods
M5 3.15 lsd
Akebono=suck
coming soon:
Jb lwfw
Old 10-21-2012, 06:38 AM
Cdv
Free?? what do u mean? Advise me please
Old 10-21-2012, 07:22 AM
DennisCooper!'s Avatar
DennisCooper! DennisCooper! is offline
Hi
Running 20's can be done on any E39, provided you get all the elements required to do so done correctly. Raising your car is not the right way, it'll look 'wrong'. You shouldn't interchange M5 springs/shocks with non M cars as they're differently rated - those who go ahead anyway tend to find the car sits too high at the front etc. 10.5 rear wheels work on an E39 and are within clearance and tolderances.
Have a look around here on some of the posts I've made about running 20's on an E39, to do it properly, you need to run low on coilovers and the design of the wheel is important as wheels with a deep lip blend in to the aesthetics and sizing of the car's looks much better than 'flat' faced/designed wheels.
You'll most likely need to roll your rear arches and perhaps even have them pulled by perhaps 5mm or so, it'll depend on the shape of the tyre shoulder you have/run into exactly how much.
Here on bimmerfest, you'll have more of the responses above as the views by most members is more of an 'oem' only level. 20's on an E39 and more importantly, done properly is in the realms of much higher levels of modifications and thus, other forums suit better where you'll get good information. Do have a look around online, speak to local reputable wheel/tyre specialists and bodyshops capable of doing this kind of work too.
Cheers, Dennis!
Old 11-14-2012, 09:51 PM
Higros Higros is offline
Pure Awesomness
Mein Auto: E39
I am running staggered 20's on my e39 and they look great. I had to roll my fenders though and my car is lowered. As long as all aspects are proper they'll fit fine. 20x8.5 20ET 245/35r20 in front 20x10 25ET 275/30r20 in rear. I'm lowered on H&R springs and Koni adjustables.
2003 BMW 530I - AFE intake, Magnaflow Exhaust, EvoSport Pulleys, Koni Struts, H&R Coils, Stoptech Rotors, Hawk HPS pads, BavAuto stainless brake lines, PIAA lighting, Umnitza Halo upgrade, XIX wheels, Falken Tires
Old 11-15-2012, 04:20 PM
540 M-Sport's Avatar
540 M-Sport 540 M-Sport is offline
Mein Auto: 01' 540 M-Sport, Scuderia
+1. Fenders are the same...but liners are different, which gives greater clearance.
See more info here in various fixes, to include M5 fender liners, fender lip rolling, and fender pulling.
http://www.bmwdiy.info/
www.bmw diy.info remove the space between bmw and diy...for some reason, the moderators are blocking the direct link.
540 M-Sport package (Canadian market), factory Bluetooth phone integration, factory M-Audio 10" dual voice coil subs, Homelink, M5 rear stabilizer bar, M5 rear subframe braces, H&R 15mm wheel spacers, ST X (KW) coilovers, Stop Tech ss brake lines, Akebono Euro Ceramic brake pads, oem Brembo and Zimmerman rotors, Dinan Stage 1 software, Strong Strut front upper stress bar, BMP strut tower reinforcement kit, USA Spec Ipod/Iphone integration.
Old 11-15-2012, 08:01 PM
Topaz540i's Avatar
FTW Trump 2020!
Its a delet mod. You remove the cdv from the clutch master and reconnect the line without it.
m60 intake manifold
a.f.e. c.a.i.
3" obx catback
545 ssk
cdv delete
m5 rear sway bar
M5 chassis rods
M5 3.15 lsd
Akebono=suck
coming soon:
Jb lwfw
