E30 (1982 - 1993)
God's Chariot. The E30 was produced primarily from 1982 through 1991. The cabriolet was the one exception which was produced through 1993. |
I've seen a cheap 1996 BMW 318i Sedan, I have an '85 E30 318i wreck, are the engines interchangeable? They are both manuals.
not easily no.
+1 E30Andy
Good - Fast - Cheap: Pick any two. Current: E23 735i; E30 318i; E32 735iL; E38 735iL; R50 Cooper; R55 Cooper Clubman. Previous: E21 318i; E32 735iL; E34 535i; E38 730iL; E53 4.4i
which motor to which car
I know a lot about cars. I can look at a car's headlights and tell you exactly which way it's coming |
So much will be different it won't make a lot of odds which way you are swaping. A nice 6 month project.
![]() Sent from my DROIDX using Bimmer App |
what is an engine swap and how do i do it ?
if you want to lead the orchestra, you must turn your back on the crowd ![]() build: http://www.bimmerfest.com/forums/sho...d.php?t=382667 |
Uhhh I think that's where you take your engine out and give it to your friend for his. But I don't know..
Sent from my MB860 using Bimmer App
Quotes to live by: guessing gets expensive...drivinfaster nothing is more expensive than a cheap BMW...c4harpe13 Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff BMW-CCA #441426 1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia" I NEED A NAP, DANG IT! |
Code:
Isn't it when you swap your 'significant other' (wife gf etc) for a more powerful engine?
Questions dont hurt do they?
Not everyone knows the differences in engine mounts of the two models. |
Aometimes I think I am better off not knowing & not particularly caring...
Ignorance is bliss
Were not trying to be rude but when you give us stupid questions on any forum your going to get responses like this. Why might you ask? You have a M10B18 from factory 104 hp Then you ask if you could swap that into a 95 E36 which has a M43B18. Or did you mean the other way around? If so swap in a 325i motor and call it done.
I meant it that way. E30 into E36. Just wanted to check if the mounting bolts were the same, thanks for letting me know.
Engine mounts are the easy bit. Its all the electrics, connectors, senors and other related bits that are going to make it a loooooong and frustrating project (even if you go the 325 - then you have springs etc to swap). Stick with 'vehicle original' parts.
| Tags |
| swap e30 engine head |
