Old 11-15-2012, 06:10 PM
jrcarter_2000's Avatar
jrcarter_2000 jrcarter_2000 is offline
16 Time Nat'l Champions
Mein Auto: 2012 328i
Question AT Fluid Change question
2000 323i ATF change, can someone that has changed their ATF on a GM trans let me know what ATF fluid they used please.
Need to do this asap and since there seem to be different opinions depending on what thread you read I wanted to get suggestions for some folks that have changed their ATF with good results.
Old 11-15-2012, 06:22 PM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
Dexron VI is the current version of GM`s long-time standby, and is marketed as being backward-compatible with all previous versions. However, some members (namely Starless Alex) have reported recently that all is not perfect, as the simple "Drain & Refill" leaves around 40% of the old ATF within the system, and it takes probably 3 repititions of the D&R procedure before almost all of the fluid has been replaced.
Good luck, and report back to let us know how you made out.
The road goes ever onward....
(R.I.P. Jever)
Old 11-15-2012, 06:34 PM
Thanks Bob,
Any brand of Dexron VI is compatible then? Heard of any difference in the brands?
Old 11-15-2012, 06:54 PM
Fast Bob's Avatar
Keeping it surreal
Originally Posted by jrcarter_2000 View Post
Thanks Bob,
You would THINK that they`re all basically the same, being manufacturered to GM specs, but who really knows ? You`re just gonna have to roll the dice to find out....
(R.I.P. Jever)
Old 11-16-2012, 04:23 AM
tttomttt tttomttt is offline
Mein Auto: 2003 330xi
When I changed mine some 30,000 miles ago I used Ac Delco Dex VI using Starless' initial DIY in conjunction with a few others. I had non of the symptoms recently noted with his current Tranny oil change. That being said most of the current makers of Dex VI are of the syn blend variety and it seems as though Valvoline is one of the few if not only maker of fully synthetic Dex VI. The remaining bottle of AC Delco Dex VI I have does not say whether or not it is a blend or a full synthetic. I'm not sure if this has any bearing on his issues whatsoever but just an observance on my part for the OP.
T
Old 11-16-2012, 01:54 PM
ventsyv ventsyv is offline
Mein Auto: 03 BMW 330ci
Go to the dealer and ask for it. They have it in big drums in the back, so you'll probably get a few puzzled looks and the rep will try to convince you that:
1. You don't need to replace it.
2. They don't sell it.
but if you are persistent enough, they'll sell it to you (you need to bring your own container) for about $7 - $8 bucks per quart. Just make sure you know the part number - there should be a sticker on the pan saying what fluid to use.
Old 11-20-2012, 05:44 PM
RPMFUN RPMFUN is offline
Mein Auto: 04 330cic
Just did mine with Mobil Dexron VI which is what is supplied to the dealer.
Paid $9.73/qt
Drained 6.5qts refilled same amount & of course changed the filter etc.
Shifts are smoother.
I plan to do another change in about 10 to 15k.
My 04 330cic Auto has 100k exact
Old 11-20-2012, 08:54 PM
jimvideopro jimvideopro is offline
Mein Auto: 2006 330CiC
That makes me feel better. My 06 has 71k on it and I'm thinking about the change, but worried about the switch in fluid. I'm guessing I want the full synthetic Dex VI....
Old 11-21-2012, 05:11 PM
venzon venzon is offline
Mein Auto: 04 330I ZHP 6MT, 00 540I
I use Valvoline QT-ATF Max Life VV324 for my cars all GM trannys. Works perfect for me $5/qt.
Old 11-21-2012, 06:27 PM
Scott ZHP's Avatar
We want the Lion!
Another vote for this. Valvoline says it is a direct replacement for Texaco ETL8072B, which was a Dex III based fluid.
Been using this in my wife's X5 and it works great.
Old 11-21-2012, 07:42 PM
QAfred QAfred is offline
Mein Auto: 328i, 330ci, R1200C
I used this in my daughter's 2004, 325I about two years ago with no issues.
http://www.castrol.com/castrol/secti...tentId=7028225
