Old 11-15-2012, 06:55 PM
MikesE39's Avatar
MikesE39 MikesE39 is online now
Mein Auto: 03 530i Loaded
My car keeps Chocking. (please read)
Ok i posted this last week didnt get much help, sorry to make a new post about the same thing. maybe more people will see it this time, a week ago i started the car and it was chocking or sputtering kinda like when a lawn mower is about to run out of gas it just keeps chocking, it does it heavy at cold start and when i realy hit the gas it sputters through it. my dad who is a former mechanic bought a fuel filter and spark plugs for the car( not installed yet) and im going to replace those but i want to get an idea of whats going on first. The other day i got gas at chevron (93) and drove home 25 miles, as i got off the highway the car started shaking and chocking hard like it was about to die and SES light came on. i turned it off and waited a min and then started it again and ran fine with out a SES light. so now idk what to do because its been getting worse every day. the only way to describe it is like when you hit the choke on a pressure washer it begins to shake and cut off like it is about to die but does not. going to go get the codes checked out tomorrow.
Old 11-15-2012, 06:59 PM
Tiko530 Tiko530 is offline
Mein Auto: 2003 530i
Not very knowledgeable on this but my first guess from your description would be a possible fuel pump or fuel filter failure.
Old 11-15-2012, 07:02 PM
MikesE39's Avatar
So do you think its a fuel related issue?
Old 11-15-2012, 07:08 PM
bkgreene39's Avatar
bkgreene39 bkgreene39 is online now
Mein Auto: 1998 BMW 528i
Since you had a SES light kick on, its still stored in memory. Get that code read.
Old 11-15-2012, 07:14 PM
MikesE39's Avatar
ya im going to do that tomorrow. once i get the code will i be able to find what it means online?
Old 11-15-2012, 08:05 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
I believe your car is choking. Chocking is the act of placing wooden blocks in front of, and behind the wheels.
Did replacing the fuel filter help?
Yes, do report your codes.
Old 11-15-2012, 08:10 PM
JimLev JimLev is offline
Mein Auto: 540/6, S60 Volvo, Tribeca
You can, or you can post the Pxxxx code here and we'll tell you what it means.
Change your fuel filter and plugs. You already have the parts. Make sure there is no oil in the plug wells, if there is get a new valve cover gasket.
Old 11-15-2012, 10:26 PM
MikesE39's Avatar
^thanks for the info, so the plugs are supposed to be dry when they come out or is it okay to have a little oil on them? and sorry... choking.
Old 11-16-2012, 08:12 AM
bkgreene39's Avatar
I had a little oil in one of my spark plugs when I was changing them. Therefore I have a valve cover gasket job in my future. Is it supposed to be dry? Yes that would be preferable, but it is not that big of a deal. As long as it doesn't look like oil pissed onto the spark plugs it should be fine.
Old 11-16-2012, 11:36 AM
BigCo540i's Avatar
BigCo540i BigCo540i is offline
The Usual Suspect
Mein Auto: 98 E39 540i
Dang, well she may run like crap but at least it looks good.
Old 11-16-2012, 05:37 PM
Youngproexec Youngproexec is offline
CPR ..
Mein Auto: e39s..
Check your ignition coils. Last time I had the same symptoms and it was a faulty ignition coil starting the misfire. The car sounded like it was a gas rc car (idk best example I know) and held back tremendously. When I restarted the car it was fine then out of the blue the sputtering again. Make sure you check the ground straps and the coil connectors are fullt connected. I had one loose another time. Its easy to forget especially ifyou were doing work related to that area. Also my idle was rough.
And btw I like the M bumper. Your car came a long way I remember when you first signed up for the fest and made a welcome thread lol
Old 11-16-2012, 06:06 PM
Woodacre tom Woodacre tom is offline
Mein Auto: 330 rag 328i
I'm going with a fuel pump on this one.
Old 11-16-2012, 10:12 PM
MikesE39's Avatar
ok replaced fuel filter and spark plugs today no more chocking during warm driving, but i still gotta see it in cold start becuase thats when it does it strong. And lol thanks bigco540. LOl i remember when my car was rice and had time attack hahhahaha and you guys got on my ass daily.
Old 11-17-2012, 02:37 PM
poolman poolman is offline
Mein Auto: 525i station wagon
If it does this mostly when the temp outside is cold--Classic Vanos Seal Symptom--do a search on Vanos Seals
