Old 11-16-2012, 02:05 PM
e66fan e66fan is offline
Mein Auto: 2006 750iL
Engine smoking issue
Hello, I'm new to this forum...it appears that there are many members that know quite a bit about the cars we drive.
I own a 2006 750iL with 118,000. I took the car to get it smog checked and the car was runing great, no smoke or any other issues. When the smog technitian put the car on the dyno and reved up the engine to run the smog test and once he stoped the reving of the engine, I noticed a cloud of smoke that came out of the tail pipe.
Since then, I have noticed that the car will release a cloud of somoke every once in a while. It doesn't do it constantly, it happens every once in a while. Since this began happening, I have noticed that the car oil level drops and I have to add a quart of oil at least every 3 weeks.
I took the car to the dealer and they told me that the problem has to do with the "Engine Valves Guides". They said that these cars, once the mileage reaches 100K, that the engine heads need to be repaired.
My question is, has anyone out there experienced this type of problem with smoking and engine oil loss? Any idea what needs to be done? Is the dealer telling me the truth?
Please advise.
Thanks!
Old 11-16-2012, 02:33 PM
csmeance's Avatar
csmeance csmeance is offline
Mein Auto: 760Li
It's a pretty common issue and it's well known here. There are these seals called the Valve Stem Seals and they end up going bad and you start burning oil and seeing the "puff of white smoke". Replacing them can be troublesome but a lot of independent places can do it as well.
Old 11-16-2012, 03:20 PM
Thanks for the reply...I will look into a local shop in the L.A. area that is affordable. Dealer price is crazy!
Old 11-16-2012, 03:47 PM
Rookie2008's Avatar
Rookie2008 Rookie2008 is offline
Mein Auto: BMW 328GT/740LI/750LI
E66 fan where in L.A are you?
13 740LI W/Msport package. Executive Package
DRIVER ASSISTANCE PKG, HUD,
OYSTER; NAPPA LEATHER SEAT TRIM,
Lane departure, blind spot detection,
Collision Mitigation,
Side & Top View Cameras
Aftermarket Rear entertainment
Old 11-16-2012, 04:26 PM
cmpcpro cmpcpro is offline
Mein Auto: Nothing
All the engines out there that run to 200k plus and the dealer says, Oh yes, after 100k the heads have to be repaired.. sorry, I own an E65 too, but that makes me feel like my motor is junk and I am at 130k with no smoke after 20min idle..
Old 11-16-2012, 05:20 PM
csmeance's Avatar
Mein Auto: 760Li
The big thing is that these valve stem seals are going because of the EXTENDED 15K mile oil changes that people were doing in 2002-2005 with ****ty oil! The oil BMW uses got better over time to actually last that long without an issue!
Old 11-16-2012, 06:11 PM
Rookie2008's Avatar
I don't think there is any definitive answer for valve stem wear. There seems to be speculations that the cause is from extended oil changes etc.. which has yet to be proven. I beg to differ on that note. BMW just simply made a bad design of the N62 engine.
Old 11-22-2012, 02:19 AM
outlawd94cobra outlawd94cobra is offline
SR CITIZEN
Mein Auto: 2006 750Li
So my question is, did you pass smog? If so, would you mind posting the readings? Just curious to see what the levels are with the smoke problem.
2001 Alpine White BMW 325i
2006 Titanium Silver BMW 750Li
2001 Mica Blue Lexus IS300
1994 Meta Gold Lexus ES300
2009 Suzuki Silver/Gray GSX1300R Hayabusa
Old 01-20-2013, 06:38 PM
BMWbill7 BMWbill7 is offline
Mein Auto: 2003 BMW 745Li
Lightbulb RE: White Smoke at idle
Please advise.
Thanks!
Hello. I'm in Atlanta area, have a 2003 BMW 745Li with only 82k that I love, and owe on...haha. Experiencing the white smoke at idle issue, yes, I know, its the Valve Stem Seals passing oil thru the exhaust.
So...after conferring with my mechanic associates (I'm in the car biz) and reading these informative posts, I have found the 'Dirty Little secret #745' of the BMW shop manual.
As a good handfull of 7 Series owners have related, they're had the Valve Stem Seals replaced by BMW dealerships at anywhere from $4800. to $6500.. am I correct, posters?
I'm certain thats a thorough process...removing the entire engine, pulling the heads, all to replace these little Seal rings. Sounded too bad to be true. Especially in my case, as there are no other leaks or issues.
Well, there is another workaround, please correct or confirm if you're truly knowlegeable. An Indy or off-the-clock BMW tech can use compressed air (using a hose & fitting threaded for the spark plug hole) to bring up the valve stems so they're accessable, and they pull each one and replace, without removing the heads or the engine. See KeifR's Excellent Flickr Photo detail of the process...awesome pics. According to my sources, the replacement seals are superior to the Original ones, anyone know if that's a fact? I've seen the compressed air fitting, I have a former BMW Shop tech who confirms that this is the 'workaround', and he can perform it in 8-10 hours at his home shop, as opposed to 40-50 BMW Shop Labor Hours. we're talking less than $1000. as opposed to over $4500. I am going to let him do it and promise to post my results here for everyone to read. Feel free to correct or confirm, or tell the Forum that I dont know what the hell I am talking about, haha, I'm sure you all will! But, I've done my homework, and I must try it, don't have $5000. to invest in the issue, anyway. Good luck to all, feel free to message me for info. Thanks
Name:	2003 BMW 745Li Valve Stem Seals.jpg
Old 01-21-2013, 11:42 AM
Stephen Max Stephen Max is offline
Mein Auto: 1998 M3, 2004 545i
Yes, replacing valve seals with the head on the engine is a well-known and time honored procedure. I am going to do mine myself sometime this spring.
Old 01-21-2013, 12:28 PM
Rahulk Rahulk is offline
Mein Auto: E53 N62; E90 N52
How many People have actually had the Valve Stem Seals Changed? I have seen 1 DYI on here, but I think it is a common job on this car? Maybe 20% of engines over 100K miles.
Here are the symptoms (I have it too)
No problem at start up.
After car has warmed up, it produces a big puff of smoke after idling for a few minutes.
(Mine just produces the smoke from the driver side exhaust only.... (Is this the common, or do people see it on both sides?))
Repairs I have done.
Lower Oil Pan gasket
Both valve covers with upper timing covers
Alternator gasket
Vacuum Pump
Crank Case Valves PCV, and new hoses
(I also tried to pour Seafoam into the crankcase PCV, did nothing)
$1000 for this repair job is a deal!!! Most shops dont even want to talk about the work around, anyone know where to get a loaner cam adjusting tool set?
Old 01-21-2013, 02:21 PM
crystalgalaz crystalgalaz is offline
24'S on my Beamer!!
Send a message via Yahoo to crystalgalaz
Mein Auto: 2002 BMW 745 Li
help
I HAVE A 2002 BMW 745Li AND MY BMW STARTS SMOKING IF I LEAVE IT ON FOR LIKE THREE TO FIVE MINUTES OR SOMETIMES EVEN AT A STOP LIGHT, IS THERE ANYONE WHO CAN TELL ME WHERE CAN I GET THIS FIXED IN GLENDALE ARIZONA ?
Old 01-21-2013, 05:24 PM
Mein Auto: Nothing
Agreed.
I have 132k on my 03 745i and no smoke ever.. to me that means someone has already fixed this issue, correct? I don't see how they could be original..
Old 01-21-2013, 11:44 PM
Robz_745 Robz_745 is offline
Mein Auto: 2004 745li
1000 bucks is a great deal as long as your guy knows what he's doing. 10 hours seems a bit optimistic though. I did the stem seals myself (not a mechanic) and there is a lot of parts to come off, steps to follow, curse words to say, parts to clean, seals to replace..... Just saying, 10 hours would be very fast if possible.
My0.02
Old 01-22-2013, 05:28 AM
Robz, what is your smoking issue? From both exhausts?
Old 01-22-2013, 07:43 AM
Rahulk, the 545i, 645i and 745i muffler has a valve that closes off one side. At a certain rpm or load level (not sure exactly) the valve opens up and allows exhaust to flow through both pipes. So at idle, it is normal for exhaust to come out only one pipe. The fact that you are getting a puff of smoke after idling for a time is an indication of worn seals.
Old 01-22-2013, 08:14 AM
Oh man so it is both sides, not just one cylinder head.... I thought I could get away with just replacing one cylinder bank's seals.
Old 01-22-2013, 02:58 PM
Mine was smoke after idling a bit (3+ mins) then accelerate.
Why would you consider doing only 1 side?
Old 01-22-2013, 03:14 PM
FUKJDM FUKJDM is offline
Send a message via AIM to FUKJDM
Mein Auto: 745li
If you do find one, please share! have an 04 with 116k with the same issue.
btw: To those that have had this issue or are having this issue, will driving the car continuously be a bad idea? will it cause any kind of damage to the motor or cause more issues?
Old 01-22-2013, 05:00 PM
Robz - I forgot about the exhaust switch... And I thought it was only 1 side.
I'll tackle the issue later this year for sure, on a difficulty scale, I'd rank it a 5, doable with the right tools. But there are major risk if done wrong... Dropping parts into the engine, bending valves etc...
Another question, anyone overheat their engine? Usually that is what causes the stem seals to go bad... And from what I have heard, the water pump lasts a long time in this car, like 150k... Or so...
Old 01-31-2013, 09:46 AM
tazman30338 tazman30338 is offline
Mein Auto: 745i
Did you have this done? Did it work? I am in the same position/condition. I just tied the oil change to Mobil 1 0w40 and Lucas Stop Leak. After about a week there is very little smoke.
Old 01-31-2013, 11:31 AM
How common of a problem is this... And can the job be done with the heads on, on a X5? I got the same problem... The worst thing is I had the valve covers and the upper timing covers replaced last year... An right after the tech told me that the valve stems were fried... I was like, why did you tell me in advance! I would have paid the extra to get the stems replaced too... I'm almost thinking that it should be changed when the valve covers are removed as a preventative measure...
Old 01-31-2013, 11:49 AM
bmwoem1 bmwoem1 is offline
Past Sponsor
Mein Auto: X3
The dealer probably would have wanted an extra 6k to do the job
Old 01-31-2013, 11:54 AM
Past Sponsor
Mein Auto: X3
It can be done with the heads on in an x5 also, it doesn't matter what car it is. I'd say about 30% of the higher mileage (70k and more) have this issue. It's also just as common on the n62tu
Old 01-31-2013, 06:46 PM
Snowwhite750 Snowwhite750 is offline
Mein Auto: Camaro SS
I had a problem with mine smoking during long idles but would clear out when I pull off. I took it to the shop and was told that my Valve Seals were Bad and I had Numerous leaks. Thanks to the Warranty I fussed about paid 6,500 for the repairs and I paid 100.00 out of my pockets
